Remote Start by Android Auto App ?
by LoneRanger. 04/19/19 04:53 PM
Continental PureContact LS
by The Critic. 04/19/19 03:31 PM
Dark/Black Rear Differential Oil - UOA?
by The Critic. 04/19/19 03:25 PM
Best oil for Honda Rancher?
by jayjr1105. 04/19/19 03:20 PM
Store bought kimchi?
by Quattro Pete. 04/19/19 03:15 PM
2020 KIA Soul Turbo
by Malo83. 04/19/19 03:03 PM
erratic Speedometer
by tookien. 04/19/19 02:59 PM
Another airbag recall
by mclasser. 04/19/19 02:44 PM
Which barb fitting is less likely to leak?
by zorobabel. 04/19/19 02:36 PM
Can these bucket style tappets be reused?
by atikovi. 04/19/19 01:34 PM
Scratched My New Car. Help Me Fix
by GeorgeKaplan. 04/19/19 01:23 PM
Talk about manual labor...
by AZjeff. 04/19/19 12:42 PM
Car didn't burn an ounce of oil... 7K OCI
by jayjr1105. 04/19/19 12:13 PM
Top 6 OEM Passenger Tire Sizes in 2018
by SubLGT. 04/19/19 11:12 AM
CRC intake valve cleaner, safe to use?
by Backstache. 04/19/19 10:06 AM
'94 Grand Am Steering Column Pivot Pins
by benjamming. 04/19/19 10:02 AM
Why the need to replace suspension springs?
by WyrTwister. 04/19/19 09:47 AM
incorrect mileage on reciept
by 1978elcamino. 04/19/19 09:17 AM
Oregon PowerSharp for chainsaw
by Fitter30. 04/19/19 09:16 AM
new tire 4 years old
by 1978elcamino. 04/19/19 08:51 AM
carve200, Harteeco, fatafox, CurtC, LockCracker
67850 Registered Users
90 registered members (2015_PSD, 2009Edge, bdcardinal, bbhero, ArrestMeRedZ, 15 invisible), 2,130 guests, and 34 spiders.
Topics287,749
Posts4,933,806
Members67,850
Most Online2,967
Mar 10th, 2019
Oil recommendation for 2.0L Ecoboost #4729081
04/16/18 05:11 PM
04/16/18 05:11 PM
KY
SilverZ71 Offline OP
KY
So we bought an used 2016 Ford Fusion SE with the 2.0L Ecoboost engine a few weeks ago and this is my first DI or Turbo vehicle I have owned. The owner's manual calls for 5w30 that meets Ford specification WSS-M2C946-A. I was just going to run the Motorcraft Full Synthetic 5w30, but my local WM and AAP only carry the Motorcraft synthetic blend. I also plan to go by the OLM for my change intervals and will use the Motorcraft FL-910S filter until the warranty expires. Thanks
2008 GMC Sierra Z71 5.3L
2016 Ford Fusion SE 2.0L Ecoboost
Re: Oil recommendation for 2.0L Ecoboost [Re: SilverZ71] #4729086
04/16/18 05:17 PM
04/16/18 05:17 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Pennzoil Platinum 5W30 is approved by Ford and is available/reasonable priced at Walmart.
http://www.pennzoil.com/en_us/products/f...c-Motor-Oil.pdf
Me: 13' VW GTI 3 door 6 speed manual
Re: Oil recommendation for 2.0L Ecoboost [Re: SilverZ71] #4729115
04/16/18 05:54 PM
04/16/18 05:54 PM
TX
KJSmith Offline
KJSmith  Offline
TX
Castrol Magnatec 5-30
Re: Oil recommendation for 2.0L Ecoboost [Re: SilverZ71] #4729136
04/16/18 06:09 PM
04/16/18 06:09 PM
New York
pbm Offline
pbm  Offline
New York
Any of those previously mentioned would work fine as would Mobil 1.
'Journalism is Dead'
Re: Oil recommendation for 2.0L Ecoboost [Re: SilverZ71] #4729193
04/16/18 07:02 PM
04/16/18 07:02 PM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
welcome
Use any full synthetic 5w30 smile
Re: Oil recommendation for 2.0L Ecoboost [Re: SilverZ71] #4729229
04/16/18 07:36 PM
04/16/18 07:36 PM
Maryland
walterjay Offline
walterjay  Offline
Maryland
+1
Re: Oil recommendation for 2.0L Ecoboost [Re: skyactiv] #4729283
04/16/18 08:20 PM
04/16/18 08:20 PM
Canyon County Idaho
CT8 Online content
CT8  Online Content
Canyon County Idaho
Too thin.
2015 F150 2.7
2018 F350 6.2
Re: Oil recommendation for 2.0L Ecoboost [Re: SilverZ71] #4729313
04/16/18 08:35 PM
04/16/18 08:35 PM
PimTac Offline
PimTac  Offline
Any major brand that meets specs will do fine.
Cannot see signatures any longer so it doesn’t matter.
Re: Oil recommendation for 2.0L Ecoboost [Re: CT8] #4729391
04/16/18 09:31 PM
04/16/18 09:31 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Too thin.
What thicker 5w-30 will you find meeting this spec on the shelf? Note that every ILSAC 5w-30 out there has an HTHS of within 0.2 of each other anyhow.
Plain, simple Garak.
Re: Oil recommendation for 2.0L Ecoboost [Re: SilverZ71] #4729430
04/16/18 10:29 PM
04/16/18 10:29 PM
pa
benjy Offline
benjy  Offline
pa
although 10W30's are rarely used any more for those in a warmer climate its a better choice of a better oil!!
Re: Oil recommendation for 2.0L Ecoboost [Re: Garak] #4729439
04/16/18 10:39 PM
04/16/18 10:39 PM
Virginia
bbhero Online sick
bbhero  Online Sick
Virginia
Interesting but true.
Pennzoil does not make available HTHS of their oils.... For that motor... Give me 3.2 HTHS or higher or possibly Castrol Magnatec 5w30 which gas proven itself to be very good in direct injection motors. Two other oils which I know the high temp high shear ratings of are Valvoline Advanced full synthetic is 3.2 or Mobil Super Synthetic which is 3.3 HTHS. I'd rather have those above one that 3.0 or 2.9 HTHS in there.
Nissan Altima 3.5 Coupe
Carquest Full synthetic HM 5w30 84356 Carquest blue
"Treat your family like your friends and treat your friends like your family."
Re: Oil recommendation for 2.0L Ecoboost [Re: SilverZ71] #4729449
04/16/18 10:55 PM
04/16/18 10:55 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Ecoboost is known to be extremely hard on oil. My main recommendation would be to change it often.
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: Castrol 0W-40
Re: Oil recommendation for 2.0L Ecoboost [Re: bbhero] #4729508
04/17/18 01:53 AM
04/17/18 01:53 AM
Garak Offline
Garak  Offline
If it's out of warranty or one doesn't care, and it were me, I'd be using an E6 5w-30 in there.
Re: Oil recommendation for 2.0L Ecoboost [Re: SilverZ71] #4729632
04/17/18 07:48 AM
04/17/18 07:48 AM
New England
Virtus_Probi Offline
New England
I would use a 5W30 that meets the Ford spec as well as GM's dexos1 Gen 2 for its LSPI test...for example, the Valvoline 5W30 FS that I am running now meets both specs and has a high HTHS for a GF5/SN oil as bbhero has already mentioned. Probably not a fantastic super cold weather (meaning -25F and below) performer based upon Valvoline's data sheet, but you probably don't care about that in Kentucky.
Once SN Plus oils become commonplace, dexos1 Gen 2 won't be a big deal...right now, d1G2 is the only standard that tests for LSPI in DIT engines like Ecoboosts.
2014 Forester XT, 95000 miles
Last Change;
M1 0W30 AFE d1G2
Tokyo Roki 15208AA170 filter
Re: Oil recommendation for 2.0L Ecoboost [Re: SilverZ71] #4729733
04/17/18 09:33 AM
04/17/18 09:33 AM
orlando fl
tojo1968 Offline
tojo1968  Offline
orlando fl
I had a 14 Focus ST. Ran the MC synblend and MC filter, 5k OCI and never had any issues.
2016 Frontier SL Crew Cab
