Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
75 registered members (alarmguy, avi1777, Bailes1992, aquariuscsm, Astro_Guy, bcossa2001, 8 invisible), 1,064 guests, and 50 spiders.
Topics286,107
Posts4,902,709
Members67,563
Most Online2,967
Mar 10th, 2019
Help, I have a dumb question #4729030
04/16/18 03:53 PM
04/16/18 03:53 PM
NE Indiana
Elijah1 Offline OP
Elijah1  Offline OP
NE Indiana
2003 Honda Accord 4cylinder. Doing the spill and fill thing. Bought a magnafine filter to replace the Honda one. Anyone want to tell me which way the filter goes, Iím guessing arrow (direction of flow) towards the radiator? Thanks!
2003 Honda Accord: Mobil 1 high mileage 0w-20
Re: Help, I have a dumb question [Re: Elijah1] #4729043
04/16/18 04:13 PM
04/16/18 04:13 PM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
You must remove a line to see which way it flows. Unless a shop manual shows it.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Help, I have a dumb question [Re: Chris142] #4729048
04/16/18 04:18 PM
04/16/18 04:18 PM
NE Indiana
Elijah1 Offline OP
Elijah1  Offline OP
NE Indiana
And to think I just cleaned my garage floor
Re: Help, I have a dumb question [Re: Elijah1] #4729049
04/16/18 04:20 PM
04/16/18 04:20 PM
Middlesex County CT
simple_gifts Offline
Middlesex County CT
Best not to compound your dumb question with a dumb post title. j/k
Some relevant info as to be courteous to potential responders and not responders
thank you.
2004 Prius; 110K; ASL
2007 Yaris 86K 0w-40 Castrol
2006 B2300;132K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: Help, I have a dumb question [Re: Elijah1] #4729058
04/16/18 04:39 PM
04/16/18 04:39 PM
Winnipeg MB CA
Number_35 Offline
Number_35  Offline
Winnipeg MB CA
"The only dumb question is the one you don't ask." - Many teachers in my distant past
I'm pretty sure the arrow on the filter would point in the direction of the fluid flow. So in what direction does the ATF flow? There will be two lines from the transmission to the rad - one will be a supply line from the tranny to the heat exchanger (in the rad), and the other will be a return line from the heat changer to the tranny.
You need to determine which line is which, as Chris142 has said, and the only way I can think of is to pull one line at the rad and see which fluid flows (i.e. does it come out of the line, or out of the heat exchanger?).
Having determined the direction of fluid flow, I don't think it matters which line (supply or return) you tap into as long as the filter is oriented correctly.
Re: Help, I have a dumb question [Re: simple_gifts] #4729065
04/16/18 04:52 PM
04/16/18 04:52 PM
NE Indiana
Elijah1 Offline OP
Elijah1  Offline OP
NE Indiana
thank you.
Unfortunately too much time has elapsed to edit the title
Re: Help, I have a dumb question [Re: Elijah1] #4729067
04/16/18 04:54 PM
04/16/18 04:54 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Another dumb question is why are you using a sketchy plastic leaker instead of a quality metal OE filter?
hide
Re: Help, I have a dumb question [Re: Trav] #4729075
04/16/18 05:04 PM
04/16/18 05:04 PM
NE Indiana
Elijah1 Offline OP
Elijah1  Offline OP
NE Indiana
hide
Itís now a metal filter.
Re: Help, I have a dumb question [Re: Elijah1] #4729106
04/16/18 05:41 PM
04/16/18 05:41 PM
MI
doitmyself Offline
doitmyself  Offline
MI
What a coincidence. I was just going to post a thread asking about the changes at Magnafine: https://magnefinefilters.com/
Re: Help, I have a dumb question [Re: Elijah1] #4729108
04/16/18 05:43 PM
04/16/18 05:43 PM
Trav Offline
Trav  Offline
Then its probably okay. Try to use Honda OE constant tension clamps from the dealer, avoid using worm clamps if you can.
Re: Help, I have a dumb question [Re: doitmyself] #4729122
04/16/18 06:00 PM
04/16/18 06:00 PM
NE Indiana
Elijah1 Offline OP
Elijah1  Offline OP
NE Indiana
Iíll let you know, when I have someone to turn the key for me while I remove a hose.
