CASIO G-SHOCK
by Char Baby. 04/18/19 05:23 AM
Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
61 registered members (antik, 87sammy, Anthony, 2015_PSD, A1O, 7 invisible), 735 guests, and 27 spiders.
Topics287,674
Posts4,932,035
Members67,838
Most Online2,967
Mar 10th, 2019
Generator not starting... check your plugs! (pics) #4728902
04/16/18 01:52 PM
04/16/18 01:52 PM
Great White North.. eh
webfors Offline OP
webfors  Offline OP
I've had a Champion 4kw generator patched into my panel via 6 circuit transfer switch for years. Ever since new the generator would take a while with the electric start to get going. This morning I was prepping for the ice storm happening and couldn't get the darn thing started.
Checked oil level, ok.
Checked fuel, ok.
Sprayed quick start into the carb, nope.
Changed the spark plug - vrooom
The darn things starts on first pull now. A huge difference. It feels brand new.
Reading some history on these Chinese made Champion generators, they apparently come with really cheap Chinese made plugs.
I replaced it with a NGK BR7ES and she starts easy and purrs like a kitten now.
17 Cadillac ATS 2.0T, Edge D1G2 5w30, XG10575
17 Dodge GC, VWB 5w30, Mopar MO-349
15 DL650, Rotella T6 5w40, KN-138
Small engines; RT5 10w30
Re: Generator not starting... check your plugs! [Re: webfors] #4728907
04/16/18 01:55 PM
04/16/18 01:55 PM
Illinois
mrsilv04 Offline
mrsilv04  Offline
Illinois
Torch brand plug, maybe?
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: Generator not starting... check your plugs! [Re: webfors] #4728914
04/16/18 01:58 PM
04/16/18 01:58 PM
webfors Offline OP
webfors  Offline OP
Re: Generator not starting... check your plugs! [Re: webfors] #4728915
04/16/18 01:59 PM
04/16/18 01:59 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
Edit:
Gap doesnt appear ridiculous but that carbon buildup though.
There's no replacement...'scosity for natural viscosity
Re: Generator not starting... check your plugs! [Re: mrsilv04] #4728918
04/16/18 02:00 PM
04/16/18 02:00 PM
webfors Offline OP
webfors  Offline OP
Not sure. Pics above. Thoughts?
Re: Generator not starting... check your plugs! [Re: PeterPolyol] #4728919
04/16/18 02:01 PM
04/16/18 02:01 PM
webfors Offline OP
webfors  Offline OP
Originally Posted By: PeterPolyol
What was the gap like on the old one? Any buildup?
Pics above, gap was definitely wider than the new NGK I put in.
Thoughts on the buildup? I don't have much of a reference point for that.
Re: Generator not starting... check your plugs! [Re: webfors] #4728920
04/16/18 02:01 PM
04/16/18 02:01 PM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
This happened to me too last summer. Honda generator, NGK plug. Tried everything and put a new plug in and it fired off first pull. Weird,never had plugs go in four strokes before.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Generator not starting... check your plugs! [Re: PeterPolyol] #4728921
04/16/18 02:01 PM
04/16/18 02:01 PM
webfors Offline OP
webfors  Offline OP
Edit:
Some chunks of the carbon fell off before the picture too. Had to wipe it off my laptop grin
Re: Generator not starting... check your plugs! [Re: Panzerman] #4728922
04/16/18 02:02 PM
04/16/18 02:02 PM
webfors Offline OP
webfors  Offline OP
Me either. First time. The limited use they get... they should last a good long time.
Re: Generator not starting... check your plugs! [Re: webfors] #4728931
04/16/18 02:10 PM
04/16/18 02:10 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
Edit:
Eek-barba-durkle oh yeah, that'll do it! Maybe the ol girl is running really rich
Re: Generator not starting... check your plugs! [Re: webfors] #4728955
04/16/18 02:36 PM
04/16/18 02:36 PM
Ohio
Dave Sherman Offline
Ohio
Agree on plugs making a difference in starting.
Strangely, my Powerhouse PH2100PRi generator has managed to ruin two NGK CR7HSA in fairly short order. They quickly got harder and harder to start before failing completely with no spark. One of them had cracked the center insulator and I could see a faint spark between it and the shell, but it would not run. For as bad as the Torch spark plugs are reputed to be, that's what got it started again after the NGKs died.
2015 Honda Pilot EX AWD Valvoline 0W-20 Bosch filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: Generator not starting... check your plugs! [Re: webfors] #4728974
04/16/18 02:51 PM
04/16/18 02:51 PM
webfors Offline OP
webfors  Offline OP
Can anyone tell what brand of plug is in the pictures above?
Re: Generator not starting... check your plugs! [Re: mrsilv04] #4728981
04/16/18 02:56 PM
04/16/18 02:56 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Or a Bonan. Both are junk.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Generator not starting... check your plugs! [Re: webfors] #4729002
04/16/18 03:22 PM
04/16/18 03:22 PM
Canada
boraticus Offline
boraticus  Offline
Canada
Plug looks sooty but not carboned enough to prevent it from functioning. Something else probably failed.
It's rare when a spark plug fails. However, occasionally they do. I think I've had a total of four plugs fail over five decades or so and I have a lot of engines.
Seems that it's becoming more of an issue with the influx of cheap Chinese plugs now available on the market.
Re: Generator not starting... check your plugs! [Re: webfors] #4729006
04/16/18 03:31 PM
04/16/18 03:31 PM
USA
mk378 Offline
mk378  Offline
USA
When you test the generator you should put a load on it and run for several minutes to burn the carbon off the plug.
