Air Fryer....whose got'em?
by Schmoe. 01/16/19 01:59 PM
ebates - anyone a member?
by Papa Bear. 01/16/19 01:29 PM
Ordered a 2019 X5 for the Wife
by gofast182. 01/16/19 12:48 PM
Today, I ride
by SirTanon. 01/16/19 12:02 PM
2019 Nissan Rogue SL
by JTK. 01/16/19 11:19 AM
Does GM oil life monitor % go down without driving?
by Corollaman. 01/16/19 10:37 AM
Ford tire wear issues?
by Redright9. 01/16/19 10:23 AM
New Battery
by CarlGR. 01/16/19 10:21 AM
It's January and I Need My Motorcycling "Therapy" !!
by LoneRanger. 01/16/19 10:13 AM
Are New Vehicles Too Expensive?
by SubLGT. 01/16/19 10:02 AM
Manual transmission fluid in Europe for Mazda
by zsero. 01/16/19 07:31 AM
Affected by the gov't shutdown?
by xBa380. 01/16/19 07:04 AM
Opinion Needed / 1998 Olds 88
by Mark72. 01/16/19 06:24 AM
Chevron Supreme color change
by OilUzer. 01/16/19 05:14 AM
Dual exhaust benefits
by OilUzer. 01/16/19 03:02 AM
M1 0w40
by Pinoak. 01/16/19 01:55 AM
M1 0w40
by Pinoak. 01/16/19 01:51 AM
The best in personal defense (Humor)
by StevieC. 01/15/19 11:10 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
107 registered members (AandPDan, 97f150, advocate, anndel, 2015_PSD, Ag76, 12 invisible), 2,284 guests, and 30 spiders.
Topics296,642
Posts4,956,475
Members66,950
Most Online2,577
Jan 14th, 2019
Page 1 of 4 1 2 3 4
Ford 460 Oil info? #4728633
04/16/18 09:05 AM
04/16/18 09:05 AM
oh
wewsnu Offline OP
wewsnu  Offline OP
oh
Hello again!
Are there any members here with 460ci Ford experience? The search engine makes me add another word to "460" in order to bring up any results so I tried numerous combinations, truck, ford, etc, with zero luck obtaining anything relevant.
This car is from 1976, and very heavy. The owner's manual is calling for 20W-40 and 20W-50 for temps above 10*F. I checked the Ford parts website for revisions or updated recommendations but there isn't oil or fluids listed for my year range. I know the 460 spanned more than 3 decades, so I'm assuming tolerances, clearances, valley hole locations, oiling systems, etc, are different depending on year, so I'm reluctant to look up the specs for a 1996 460 motor and just go with what it calls for either.
The car it's in will be driven casually, rarely, and the most revs it will see would be spirited highway on-ramp acceleration followed by a gentle drive at 75-80mph down a quiet rural 4-lane highway to a town an hour or so away. More wear will probably occur at slow speed short events like parades and car shows. I'm going to modernize the engine a little this winter to get rid of the 70's era concepts of efficiency and smog reduction. Altering the rear gears from 2.75 to 3.55 will raise the revs some but this engine will still be far from abused.
My question is mainly viscosity weights. 20W-50 or even the lighter spec 20W-40 seems wildly antiquated. The manual does spec of a 10W-30 in temps under 10*F, but there is an asterisk that says if towing or driving for long periods is going to take place then to not use it.
Does this motor really need something that thick? I'm a fanatic about clean oil, this will probably be changed twice just in the summer. There will be no winter or cold weather driving. I do have some Porsche spec 0W-40 laying around, I think it's Castrol brand and can get more.. but was wondering if a fully syn 5W-30 or even a 5 or 0 W-20 would work. What's been your experience? What do you run in your 460? I see a lot of people running thicker stuff in these motors but they're all modified and used for racing, marine use, or mud truck racing. Suggestions of old large engine oils will be highly appreciated. I look forward to reading everyone's input.
Thank you!
Re: Ford 460 Oil info? [Re: wewsnu] #4728636
04/16/18 09:09 AM
04/16/18 09:09 AM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Being a smogger, I'd assume the output is relatively low. I'd just run a 15w-40 HDEO or even 10w-30 HDEO and call it a day (diesel lube). That engine isn't going to require anything exotic for lubrication.
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: Ford 460 Oil info? [Re: wewsnu] #4728640
04/16/18 09:14 AM
04/16/18 09:14 AM
Idaho
CT8 Online content
CT8  Online Content
Idaho
The company van I had with a 460, got HDEO straight 30 or 15W-40 The E350 weighed a bit over 8,500lbs. Choose an oil with the proper W for start up temps. The 460 is a great engine.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Ford 460 Oil info? [Re: wewsnu] #4728642
04/16/18 09:14 AM
04/16/18 09:14 AM
USA
SOHCman Offline
SOHCman  Offline
USA
+1 a good name brand (rotella, delo, etc) 10w-30 HDEO or 15w-40 HDEO is just what that motor ordered. It likely has flat tappets and will require the ZDDP from a HDEO as opposed to a modern passenger car oil.
I urge people not to wait 100K to change out the fluid in their transfer case units. -Kestas
Re: Ford 460 Oil info? [Re: wewsnu] #4728644
04/16/18 09:14 AM
04/16/18 09:14 AM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
I ran Castrol GTX 20W50 in all my big blocks back in the day-a 429 '70 Thunderbird, and a 440 '73 Class A RV, but I would think that any big name HDEO would get the job done. I wouldn't go any thinner than 10W30 due to the inevitable carburetor caused fuel dilution.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Ford 460 Oil info? [Re: SOHCman] #4728649
04/16/18 09:20 AM
04/16/18 09:20 AM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Even then, that camshaft is a smogger broomstick, its ZDDP requirements won't be anything a modern PCMO couldn't handle easily. It's also well broken-in. But an HDEO for more additives and bit more viscosity reserve due to fuel dilution and blow by is, IMHO, the best choice here.
Re: Ford 460 Oil info? [Re: wewsnu] #4728659
04/16/18 09:26 AM
04/16/18 09:26 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
+1 smile
I'd just run 15W-40 year round and be as happy as a clam smile
Re: Ford 460 Oil info? [Re: wewsnu] #4728674
04/16/18 09:39 AM
04/16/18 09:39 AM
San Antonio, Texas
sasilverbullet Offline
San Antonio, Texas
Had a 70 Lincoln MKIII with a 460 in it recently.
You didn't mention how many miles were on the engine.
I ran Castrol GTX High Mileage 20W-50 and a WIX oil filter and OCI was about 4K miles or one year.
03 Porsche 911 Liqui Moly Leichtlauf High Tech 5w-40 & Mahle filter
14 Honda Accord 4dr EX-L 4cyl-M1 0W-20 & WIX XP
02 Chevy 5.7L van-GTX HM 10W-40 & WIX filter
Re: Ford 460 Oil info? [Re: wewsnu] #4728680
04/16/18 09:41 AM
04/16/18 09:41 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I'm thinking Mobil 1 TDT 5W40, if you don't mind paying for synthetic oil.
God Bless Our Troops
Re: Ford 460 Oil info? [Re: wewsnu] #4728712
04/16/18 10:11 AM
04/16/18 10:11 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
The cheapest 15W40 fleet/diesel oil you can find. No synthetic oil in old engines. It will leak and consume and accomplishes nothing.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: Ford 460 Oil info? [Re: wewsnu] #4728742
04/16/18 10:24 AM
04/16/18 10:24 AM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
I agree with those saying 15w40. A good friend has an E150 short van with a 300-6 in it which he runs good ol' Rotella T4 15w40 in, and nothing he or I did with it ever seemed to bother the engine in the slightest.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: Ford 460 Oil info? [Re: wewsnu] #4728745
04/16/18 10:26 AM
04/16/18 10:26 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
A nice 10w40. Mobil Clean or Quackerstate - Not Diesel. wrong package
2019 VW Jetta S,6M OCI#0 62mi-Castrol Edge Prof VW508+OE Filter; '17 Subaru Crosstrek CVT OC#5 37K mi-SOA/Idemitsu 0w20 + SOA Filter
Re: Ford 460 Oil info? [Re: wewsnu] #4728760
04/16/18 10:36 AM
04/16/18 10:36 AM
The Motor City
Kestas Offline
Kestas  Offline
The Motor City
My 1971 Oldsmobile gets Rotella 15W-40. This covers the proper viscosity and additives for the flat tappets.
Re: Ford 460 Oil info? [Re: OVERKILL] #4728782
04/16/18 10:56 AM
04/16/18 10:56 AM
Northeastern Vermont
littleant Offline
littleant  Offline
What overkill said. I had a 1973 mark 4 with 460. Ran 10w30. Go with 15w-40 HDEO or even 10w-30 HDEO. Good engine tough to kill with reasonable care.
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
Re: Ford 460 Oil info? [Re: OVERKILL] #4728834
04/16/18 11:43 AM
04/16/18 11:43 AM
Cajun Country, La.
BlueOvalFitter Offline
Cajun Country, La.
^^^ THIS. ^^^
My dad owns a '72 Town Car (147K original miles) with a 460. He runs Mobil Delvac 15W40 with a MC oil filter. He has a friend do an OCI on it once a year. He drives it an average of 2-5K miles a year.
He also owns a '57 Plymouth Belvedere sitting under his carport covered up. That's a future project car.
Page 1 of 4 1 2 3 4
