Gas trimmers
by weeksjake. 01/22/19 09:11 AM
Supertech Heavy Duty 15W40 ...$9.64
by dblshock. 01/22/19 08:53 AM
Trooper recommends dash cameras
by FordBroncoVWJeta. 01/22/19 07:14 AM
New Harley synthetic 80w-140 gear released
by shanneba. 01/22/19 06:43 AM
Registering a Vacation Car
by ssamaroo01. 01/22/19 06:23 AM
Starter cross reference?
by dlundblad. 01/22/19 05:11 AM
Barkeepers Friend
by jerseyguy123. 01/22/19 02:23 AM
Bag-in-a-box motor oils
by jtr990. 01/22/19 02:10 AM
Inventions of the 1950's - 1970's
by StevieC. 01/21/19 10:26 PM
Fireplace cleaners and price
by 97prizm. 01/21/19 10:23 PM
M1 0w40 extended oci??
by Pinoak. 01/21/19 09:46 PM
Best propane fireplace insert?
by SOHCman. 01/21/19 08:51 PM
Save 1/4 on gas!! Guaranteed!!
by Linctex. 01/21/19 08:50 PM
Funny names
by Chris142. 01/21/19 08:45 PM
Kendall vs Total Qaurtz
by zeke1985. 01/21/19 08:32 PM
Got a weird one - Helping a friend
by StevieC. 01/21/19 08:32 PM
Thanks 14Accent
by clinebarger. 01/21/19 08:07 PM
Mobil 1 5W30 C7 Z06
by PLRX. 01/21/19 07:40 PM
Binco, Coolbreez1973, jmcast1127, DF8005, FT86dude11
67009 Registered Users
91 registered members (4WD, 2015_PSD, 53' Stude, A310, 69Torino, 11 invisible), 1,883 guests, and 35 spiders.
Topics296,969
Posts4,962,601
Members67,009
Most Online2,821
Jan 21st, 2019
toilet fill flush valve question #4728568
04/16/18 08:01 AM
04/16/18 08:01 AM
NJ
raaizin Offline OP
raaizin  Offline OP
NJ
Why does the tube from flush valve go right into flush valve tube. It seems like it is dumping clean water down the drain Isnt this tube there so toilet doesnt overflow if valve malfinctions. What is the purpose
Re: toilet fill flush valve question [Re: raaizin] #4728573
04/16/18 08:08 AM
04/16/18 08:08 AM
MN
tmorris1 Offline
tmorris1  Offline
MN
To fill the bowl back up.
Re: toilet fill flush valve question [Re: raaizin] #4728575
04/16/18 08:10 AM
04/16/18 08:10 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
After the flush the flapper on the tank closes to refill. The clean water your talking about is bringing the water in the bowl back up to level after the flush.
2004 Corolla 128335
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74615
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: toilet fill flush valve question [Re: JohnnyJohnson] #4728577
04/16/18 08:12 AM
04/16/18 08:12 AM
NJ
raaizin Offline OP
raaizin  Offline OP
NJ
Wouldnt it fill faster if it didnt fill in the tube, but directly into the tank
Re: toilet fill flush valve question [Re: tmorris1] #4728579
04/16/18 08:16 AM
04/16/18 08:16 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
This. Refill tube fills the bowl, fill valve refills tank.
http://www.factsfacts.com/MyHomeRepair/ToiletFlush.htm
Re: toilet fill flush valve question [Re: raaizin] #4728586
04/16/18 08:18 AM
04/16/18 08:18 AM
Ontario Canada
cjcride Offline
cjcride  Offline
Ontario Canada
It also helps the flush by running water through the hidden sprinkler holes.
Re: toilet fill flush valve question [Re: raaizin] #4728588
04/16/18 08:20 AM
04/16/18 08:20 AM
Ohio
Dave Sherman Offline
Ohio
The fill valve is filling the tank directly, and at the same time some water is going through the little hose to fill the bowl because the flapper valve is closed.
2015 Honda Pilot EX AWD Valvoline 0W-20 Bosch filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: toilet fill flush valve question [Re: raaizin] #4728592
04/16/18 08:23 AM
04/16/18 08:23 AM
PimTac Offline
PimTac  Offline
You need a certain level of water in your bowl for everything to work right. There are two items filling here, your bowl and your tank.
Cannot see signatures any longer so it doesn’t matter.
Re: toilet fill flush valve question [Re: Sayjac] #4728593
04/16/18 08:23 AM
04/16/18 08:23 AM
NJ
raaizin Offline OP
raaizin  Offline OP
NJ
perfect explanation...thanks
Re: toilet fill flush valve question [Re: raaizin] #4728596
04/16/18 08:25 AM
04/16/18 08:25 AM
Europe
SonofJoe Offline
SonofJoe  Offline
Europe
Funny you should raise this as I had this very problem a couple of months ago.
We had both of our toilets replaced about five years ago. They worked fine for most of that time but then water started to 'leak' from the cistern into the pan for both toilets. At first it was a tiny dribble but it progressed to a noticeable constant flow. Sometime you could stop it by reflushing but not always.
I called out the bathroom fitter who had installed both toilets and he played around with them but he couldn't cure the problem. He did say in advance that he wasn't a proper plumber.
So I hit Google & YouTube and gave myself a crash course in lavvy mechanics! Blimey! It's so much more complicated now than the days when it was simple valve, an arm and a ball float. Anyway, it seems today, you twist out the entire flush assembly, locate the 3" rubber seal on the bottom of the assembly, peel it off and replace with a new one. I have to confess I was somewhat shocked by the state of the two old seals I took off as they were absolutely caked in limescale. No wonder that the valves weren't sealing properly.
Once you know what you're doing, this is a two minute job which anyone should be able to tackle.
Re: toilet fill flush valve question [Re: raaizin] #4728830
04/16/18 11:40 AM
04/16/18 11:40 AM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
I have often heard that the Soviet Union plundered Berlin of toilets after World War II was over but couldn't make them work back home. Any truth to that?
Re: toilet fill flush valve question [Re: raaizin] #4729761
04/17/18 09:09 AM
04/17/18 09:09 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
I'm sure a lot of it has to do with the quality of the commode, but the refill tube/hose on the fill valves of 3 toilets in my home will do nothing other than waste more water during a flush.
The bowl will maintain the same level if the hose is directed down the overflow tube or directed into the tank. If the hose is set in the overflow tube it just dumps water down the drain until the float shuts off the fill valve.
I'm more concerned about waste water than water usage, given I'm on a ~45yr/old septic system.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: toilet fill flush valve question [Re: raaizin] #4730179
04/17/18 04:24 PM
04/17/18 04:24 PM
Cajun Country, La.
BlueOvalFitter Offline
Cajun Country, La.
If you have very hard water and the water jets/holes are clogged in your bowl, get a 7/32" 7018 welding rod and remove the flux. Bend it about 2/3's the way up from one end into an "L" shape and start probing the jets/holes. "I GARE-ROWN-TEE" it will make your bowl flow water like new again.
Re: toilet fill flush valve question [Re: raaizin] #4730591
04/18/18 01:07 AM
04/18/18 01:07 AM
SF Bay Area
y_p_w Offline
y_p_w  Offline
SF Bay Area
I know others have answered, but yeah it's to make sure that the level of the water in the bowl is at its maximum. Some people who think it's a waste of water just redirect it into the tank and find that the flush is rather poor as a result. It also reduces the chance of sewer gas coming into the bowl. The bowl fill tube has to be at a certain height or it won't shut off. Also - the big plastic tube is really the overflow tube. If the fill valve malfunctions (it can happen) then the overflow tube prevents it from just pouring out the top of the toilet tank and onto the floor.
There is a problem though. Most tubes aren't regulated and once it fills bowl at the height of the trap it's just dumping more water into the trap until the tank is filled, when it shuts off the water into the bowl. So in that case it is wasting water. However, there is a solution for it. Lavelle has an knob on some of their models - several of the OEM versions as well as their "Platinum" version. Fluidmaster uses a roller clamp on their tube to adjust the water flow. This roller clamp comes with the deluxe version of their fill valves but can be bought separately to use with their basic valve. I actually got one for the 400A that came with my American Standard toilet. The idea is to adjust the flow of water into the bowl such that it fills to the top of the bowl at about the same time as the tank is full.
The valve to control it is the little black thing on the top. The fill tube connects to the top.
The Fluidmaster part cost me maybe $3 at Home Depot. I wasn't going to spend $13 on a complete fill valve when the one that came with my toilet was still working perfectly except for overfilling the bowl. It just replaces the original fill tube, but with that roller clamp to adjust how wide the opening is. The roller basically pinches the tube to reduce the flow.
https://www.fluidmaster.com/products/toilet/fill-valves/215-water-saving-roller-clamp-refill-tube/
I can't find a good photo that shows the roller, but this video shows one of these being installed as part of a "pro" version of their fill valve:
Re: toilet fill flush valve question [Re: raaizin] #4730852
04/18/18 09:03 AM
04/18/18 09:03 AM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
When those Fluidmaster-types start to freeze-up after 10 years or-so and won't move up and down, shoot them liberally (both inside and out) with WD-40. Mine has gained another three years of life since I did that. When it acts-up again. I'll shoot it again with WD-40.
The oil from WD-40 will sit in that overflow thank for a few flushes, then it's gone. Wipe down the water-flush area of the toilet with any cleaner like Scrubbing Bubbles. That will eliminate any leftover oil there.
2019 Hyundai Santa Fe 2.4 factory fill and OEM filter
2004 Chevrolet Colorado 3.5 QS / Valvo syn 5w30/20 blend K&N filter
2003 Chevrolet Malibu 3.1 QS / Valvo Syn 5w30/20 blend Fram EG filter
