Originally Posted By: jakeyjohn1
I think I have narrowed my choices down to Castrol 0W40 A3/B4 and Mobil 1 ESP 5W30.
I'm still looking for an oil that has:
dexos1gen2
MB 229.5
Porsche A40
BMW LL-01
VW 502 00
But I'm starting to think dexos1gen2 contradicts the others? Are these sequences published publicly? I can't find them, just lists of certified oils.
Mobil 1 ESP 5W30 has what I think are the equivalent mid-SAPS versions of all the above (please correct me if that's a bad way of thinking about these):
dexos2
MB 229.51
Porsche C30
BMW LL-04
VW 504 00
Is the dexos2 specification giving me more benefit (in terms of wear and engine longevity) than the high-SAPS versions of the others specs?
Would either dexos specification be relevant in a 2L turbo DI engine with some reports of misfires on cold starts?
Forget Dexos. It is not particularly stringent application compare to MB or BMW or VW 504.00/507.00.
Also, M1 5W30 ESP is lo-SAPS oil, not really Mid-SAPS. It ahs very low SA at 0.6.
If you choose Castrol 0W40, change it every 5 to 7.5k, and enjoy the car.
If you choose M1 5W30 ESP use it for 3K and do used oil analysis (UOA). IMO, Mobil1 5W30 ESP is the best VW504.00/507.00 oil you can find on the market. It meets ACEA C3 (and it has numerous other approvals) but also ACEA C2, which means it is fuel efficient. I actually can notice MPG increase in BMW using that compare to BMW TPT LL-04 or Valvoline 5W40 MST I used.
However, and this is BIG however, I tried M1 5W30 ESP in Tiguan I have and VW CC I had before. It did not do good in this EA888 first generation engines. TBN depleted fast and at 3K it was at 1.9. Kinematic viscosity was great, all other indicators were good, but TBN was low.
So, if you choose ESP, do 3K and send it for analysis to Blackstone so you know how it is performing.
dexos1gen2
MB 229.5
Porsche A40
BMW LL-01
VW 502 00
dexos2
MB 229.51
Porsche C30
BMW LL-04
VW 504 00
