'15 6.7 Powerstroke UOA
by roadrunner1. 01/18/19 10:18 AM
Automotive Battery Voltage -What is ur reading?
by Patrick0525. 01/18/19 10:10 AM
Amsoil 0w-40 vs 5w-40
by Buddyp. 01/18/19 10:07 AM
M1 is changing their oils, site and adding a new oil
by Flashlightboy. 01/18/19 10:01 AM
Boiler/baseboard valve corrosion
by wormwood1978. 01/18/19 09:24 AM
Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
(NEW) STP S3675 Cut Open
by rooflessVW. 01/17/19 10:00 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
95 registered members (AndyB, 69GTX, anndel, 97f150, Anduril, 14Accent, 5 invisible), 2,116 guests, and 51 spiders.
Topics296,780
Posts4,958,724
Members66,969
Most Online2,577
Jan 14th, 2019
Need brake suggestions for my GFs 02 Honda Odysse #4728231
04/15/18 07:12 PM
04/15/18 07:12 PM
NE Indiana
Elijah1 Offline OP
Elijah1  Offline OP
NE Indiana
My girlfriend is tired of me complaining about her dismal maintenance on her van. She would like to get about two more years out of it, so shes willing to buy reasonable quality parts. Her driving habits, typically involve braking harder than others, and a majority of her driving is city. Im planning on doing front and rear discs and pads. Probably going to convince her to replace shocks/struts too. So any feedback is appreciated.
The van has 212,xxx miles if that helps. Very little other than an occasional oil change has been done to this van, and quite frankly, I really dont know how its still running.
2003 Honda Accord: Mobil 1 high mileage 0w-20
Re: Need brake suggestions for my GFs 02 Honda Odysse [Re: Elijah1] #4728253
04/15/18 07:28 PM
04/15/18 07:28 PM
CA
The Critic Offline
The Critic  Offline
CA
Akebono Coated or Centric 120 series rotors. Dealer pads from Honda. Clean hub flange really well with a 3M hub cleaning kit and wire wheel (attached to a drill).
How is the transmission on that car? The 99-04 Odysseys have very unreliable automatics. If it has made it this far, I am guessing that the trans has been replaced at some point? If not I would get rid of it while it is still running.
2011 Toyota Prius - 181k - M1 EP/EP HM Mix 0W-20
2007 Honda Accord 2.4 - 134K - Mobil 1 EP HM 5W-30
Re: Need brake suggestions for my GFs 02 Honda Odysse [Re: The Critic] #4728260
04/15/18 07:34 PM
04/15/18 07:34 PM
NE Indiana
Elijah1 Offline OP
Elijah1  Offline OP
NE Indiana
Transmission slips occasionally, but not nearly as bad as Id expect. She wants to get a new-ish Pilot so the longer she keeps this van, the newer Pilot she can get. She already knows that shell get next to nothing for the Odyssey, so shes willing to roll the dice on the transmission.
Re: Need brake suggestions for my GFs 02 Honda Odysse [Re: Elijah1] #4728277
04/15/18 07:51 PM
04/15/18 07:51 PM
CA
The Critic Offline
The Critic  Offline
CA
In that case, don't put any money into this van unless it is truly a safety issue. That transmission can go at any minute and you will lose any money you invest.
Re: Need brake suggestions for my GFs 02 Honda Odysse [Re: Elijah1] #4728288
04/15/18 07:57 PM
04/15/18 07:57 PM
Outer Banks, NC
NormanBuntz Online content
NormanBuntz  Online Content
Outer Banks, NC
On my 2007 Ridgeline, I had really good results pairing Beck Arnley ceramic pads (Sangsin brand) with AC Delco Professional Durastop rotors. Bought them at www.oscaroparts.com.
2017 Honda Odyssey SE, 17K
2013 Honda Accord LX, 58K
2007 Honda Ridgeline RTS, 89K
2007 Infiniti M35, 107K
Re: Need brake suggestions for my GFs 02 Honda Odysse [Re: Elijah1] #4728292
04/15/18 08:00 PM
04/15/18 08:00 PM
The land of USA-made Subies!
SubieRubyRoo Offline
Buy the cheapest pads and rotors from Advance or AZ or OReilly... they all come with lifetime warranties.
Buy at least 3 gallons of Valvoline Maxlife ATF and do a drain, fill, drive for 5 minutes then repeat two more times. When we bought our 06 Odyssey it had 134k and was slipping on upshifts and banging on downshifts. 4 gallons of Maxlife later, it shifts like there was never a problem. Just be sure to disconnect the battery after the final D&F and let everything reset and relearn.
Re: Need brake suggestions for my GFs 02 Honda Odysse [Re: Elijah1] #4728299
04/15/18 08:05 PM
04/15/18 08:05 PM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
I like Akebono pads and Centric rotors. I generally get them on Amazon.
But any quality parts will work.
Suck the brake fluid outta the master resovoir and pedal bleed at least the front calipers.
I would do a couple of spill and fills on the tranny. MaxLife is pretty cheap.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Need brake suggestions for my GFs 02 Honda Odysse [Re: Elijah1] #4728303
04/15/18 08:13 PM
04/15/18 08:13 PM
USA
slacktide_bitog Offline
USA
This generation Odyssey is known for its transmission issues, so even if it was well-maintained, you'd still have to worry about transmission failure crzy
Change the ATF soon, and use Maxlife ATF. It is a quality synthetic fluid at a great price. Change it annually.
For the brakes, use Akebono or Advics pads, along with Wagner E-coated rotors.
For the shocks, use KYB quick struts for the front, and the KYB shocks for the rear.
Re: Need brake suggestions for my GFs 02 Honda Odysse [Re: The Critic] #4728435
04/16/18 03:31 AM
04/16/18 03:31 AM
NE Indiana
Elijah1 Offline OP
Elijah1  Offline OP
NE Indiana
Im not putting a dame in that beast. Im only investing time. Shes in a position that she can buy a new Pilot any time she needs, she however would like to put it off as long as she can.
Re: Need brake suggestions for my GFs 02 Honda Odysse [Re: Elijah1] #4728436
04/16/18 03:33 AM
04/16/18 03:33 AM
NE Indiana
Elijah1 Offline OP
Elijah1  Offline OP
NE Indiana
What fails in these transmissions? Is it a valve body issue?
Re: Need brake suggestions for my GFs 02 Honda Odysse [Re: Elijah1] #4728443
04/16/18 04:13 AM
04/16/18 04:13 AM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
Heat buildup and a gear that breaks.
2019 Cherokee, 2018 Jetta, 2014 Sentra, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Need brake suggestions for my GFs 02 Honda Odysse [Re: Elijah1] #4728447
04/16/18 04:26 AM
04/16/18 04:26 AM
Atlanta
DuckRyder Offline
DuckRyder  Offline
Atlanta
Im curious if there is actually an issue with the shocks/struts/brakes or if this is simply maintenance.
I agree with the crowd that says dont do anything that isnt an actual safety issue. I would not touch anything that didnt REQUIRE touching. Of course I wouldnt have my girl drive around in something with a slipping transmission either.
At any rate, actual Honda pads are generally quite reasonable sourced from some of the usual online dealers, they typically include the required anti-squeal shims too.
Robert
  • 2007 Toyota Prius Touring
  • 2005 Honda Civic Sedan
  • 1972 Ford F100
Re: Need brake suggestions for my GFs 02 Honda Odysse [Re: The Critic] #4728462
04/16/18 05:10 AM
04/16/18 05:10 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
^ This!
https://www.transmissionrepaircostguide.com/honda-odyssey-transmission-problems/
Changing the transmission fluid on this is a waste of time and money. Personally I would be hard pressed to even invest in a set of new wiper blades for this thing.
Re: Need brake suggestions for my GFs 02 Honda Odysse [Re: Elijah1] #4728496
04/16/18 06:15 AM
04/16/18 06:15 AM
USA
SOHCman Offline
SOHCman  Offline
USA
+1 Akebono pro-act
I urge people not to wait 100K to change out the fluid in their transfer case units. -Kestas
Re: Need brake suggestions for my GFs 02 Honda Odysse [Re: Elijah1] #4728508
04/16/18 06:43 AM
04/16/18 06:43 AM
Canada
camrydriver111 Offline
Canada
I was very impressed with Wagner ThermoQuiet pads when I used them. For rotors Centric is fine.
BITOG or: How I Learned to Stop Worrying and Love the Extended OCI
