Originally Posted By: car51
Odd filter here...
Indeed, for several reasons. Obviously the coo, UK. Also though, not a typical/spec 1334 (9688/3593a application) oil filter. Typical US Wix 1334 has a sealing gasket more central to outlet/mounting hole, a wider filter. Topic filter has sealing gasket on outer edge diameter of filter, like the 7317 applications. And the no endcap type construction, not seen US Wix or Wix 'made fors'. So unique. Not sure where the Napa seller/supplier dug this one up, but out of the norm for sure.
Thanks for c&p.
