air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
40 registered members (Ag76, carlprop, clinebarger, Bailes1992, Chris142, anndel, 1 invisible), 788 guests, and 61 spiders.
Topics286,440
Posts4,908,208
Members67,622
Most Online2,967
Mar 10th, 2019
Pennzoil Platinum 5w20 / 5w30 mix #4727774
04/15/18 12:43 PM
04/15/18 12:43 PM
GA
Anthony Offline OP
Anthony  Offline OP
GA
My 17 GT runs just fine with 5w20 but I am hard on it at times and while 5w20 has long proven itself, is it the best choice for a fairly high strung V8? For 2018 ford made changes to the Coyote V8 but I imagine the clearances are similar. The 18 manual states to use 5w30 on the track but switch back to 5w20 on the street. Surely that has to be CAFE driven. My car holds 8 quarts. I was thinking of going 4 quarts of 5w20 and 4 quarts of 5w30.
Or maybe just a full fill of 5w30. I know mixing is usually not a big deal. I just wonder if there are any chemistry differences that would ultimately make the mix less effective vs just picking a weight and running it.
I know Iím over thinking this lol!
What are your thoughts?
95 Nissan Hardbody V6 - M1 HM 5w30
13 Nissan Titan - Pennzoil Platinum 5w30
17 Ford Mustang GT - Pennzoil Platinum 5w20
Re: Pennzoil Platinum 5w20 / 5w30 mix [Re: Anthony] #4727782
04/15/18 12:47 PM
04/15/18 12:47 PM
socal
barkingspider Offline
socal
5w20 for now. If you track it, 5w30. After warranty, use whatever oil u like
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: Pennzoil Platinum 5w20 / 5w30 mix [Re: Anthony] #4727785
04/15/18 12:48 PM
04/15/18 12:48 PM
The land of USA-made Subies!
SubieRubyRoo Online happy
SubieRubyRoo  Online Happy
Just stick to the 30 weight. You never know when the itch will strike to drive a hole thru the carpet with the accelerator. Your engine will thank you, plus you can eliminate a separate weight from your oil shopping routine.
Re: Pennzoil Platinum 5w20 / 5w30 mix [Re: Anthony] #4727793
04/15/18 01:00 PM
04/15/18 01:00 PM
Chattanooga, TN
Spector Offline
Spector  Offline
Chattanooga, TN
I have been doing the 50-50 5W20-5W30 mix for the past 5 years on my Hyundai. In my climate I could easily do the 5W30 and manual says acceptable as is a 10W but the 5W20 is on the oil cap. Cannot remember why I decided to go with the 50-50 mix but kind of a habit now. Will never know if any difference over the 5W20.
Re: Pennzoil Platinum 5w20 / 5w30 mix [Re: SubieRubyRoo] #4727799
04/15/18 01:07 PM
04/15/18 01:07 PM
NY
demarpaint Offline
demarpaint  Offline
NY
That's what I would do. The truth is with the 50/50 mix you're really not sure without some kind of analysis what the viscosity of the finished product is anyway.
God Bless Our Troops
Re: Pennzoil Platinum 5w20 / 5w30 mix [Re: demarpaint] #4727801
04/15/18 01:12 PM
04/15/18 01:12 PM
New Braunfels
Bryanccfshr Offline
Bryanccfshr  Offline
New Braunfels
just use 5w30 and you are covered for harder driving.
2018 Trd Pro 4Runner
2018 Tacoma off-road
Dealer 0w20 to M1 0w40 FS -it depends
Re: Pennzoil Platinum 5w20 / 5w30 mix [Re: Anthony] #4727803
04/15/18 01:19 PM
04/15/18 01:19 PM
Michigan
ZZman Offline
ZZman  Offline
Michigan
Way too much thinking. 5w-30!
2003 Mercury Grand Marquis. PP HM 5w-30 and Fram TG
2008 Sebring Hardtop convertible. PP HM 5w-30 and Fram Ultra
2006 Kawasaki Vulcan 900 LT. Motul 7100 10w-40 and K&N
Re: Pennzoil Platinum 5w20 / 5w30 mix [Re: Anthony] #4727805
04/15/18 01:24 PM
04/15/18 01:24 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Just use the 5w-30 if you are concerned.
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: Pennzoil Platinum 5w20 / 5w30 mix [Re: OVERKILL] #4727815
04/15/18 01:34 PM
04/15/18 01:34 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
That recommendation to use 5w-30 when tracking could also apply to those driving the car routinely in hot climates. After all, the factory recommendation has to "work" from South Texas to Canada. Neither 5w-20 or 5w-30 could possibly be optimum for both regions. I'd consider Georgia in summer to be fairly "hot" such that a 5w-30 makes a lot more sense than someone driving in Northern Maine. You could always just use a somewhat thinner 30 grade...which I think Pennz Plat still is.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Pennzoil Platinum 5w20 / 5w30 mix [Re: Anthony] #4727818
04/15/18 01:36 PM
04/15/18 01:36 PM
pa
benjy Offline
benjy  Offline
pa
being in a hot climate a 10 W would serve you better and a 30 for sure as 20's are as noted for CAFE and NOT your engines health. the 10-30 will have less viscosity improvers and its noack will be better as well
Re: Pennzoil Platinum 5w20 / 5w30 mix [Re: Anthony] #4727827
04/15/18 01:46 PM
04/15/18 01:46 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
For what itís worth, I dropped 5w20 and went to 5w30 for the summer. Might go back to 5w20 this winter but maybe not. My UOA on a 5,000 mile run with 5w20 was excellent.
If you want the job done right......do it yourself.
Re: Pennzoil Platinum 5w20 / 5w30 mix [Re: Anthony] #4727854
04/15/18 02:16 PM
04/15/18 02:16 PM
Maricopa, Arizona.
dave1251 Offline
dave1251  Offline
Maricopa, Arizona.
Just use 5W-30. Your engine will not grenade on 5W-20 but it's nice to have a bit of reserve.
don't use.
Re: Pennzoil Platinum 5w20 / 5w30 mix [Re: Anthony] #4727855
04/15/18 02:17 PM
04/15/18 02:17 PM
Maricopa, Arizona.
dave1251 Offline
dave1251  Offline
Maricopa, Arizona.
I use 30 grades in both vehicles were 5W-20 is recommended.
don't use.
Re: Pennzoil Platinum 5w20 / 5w30 mix [Re: Anthony] #4727856
04/15/18 02:18 PM
04/15/18 02:18 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
5W20 is CAFE driven, and you already know that 5W30 will offer better protection for your engine. So, we already know the answer. Just use 5W30 from now.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: Pennzoil Platinum 5w20 / 5w30 mix [Re: ZZman] #4727913
04/15/18 03:32 PM
04/15/18 03:32 PM
Kentucky
fordman65 Offline
fordman65  Offline
Kentucky
Agreed.
Amen.
97 Mercury Gran Marquis GS 4.6L V-8 255k miles
Castrol FS HM 5W-30
WIX Oil 51372 or M1210A
2004 Buick Rainer CL 4.2 6 cyl DOHC
140,000 miles
Castrol Magnatec 5w-30
WIX 51522 or Mobil 1 M1-206
