Very Basic Engine Question
by Ducked
Yesterday at 11:16 PM
K&N Air Filter for FJ
by CCI
Yesterday at 10:41 PM
Shoutout of the day... Thanks car51!
by SubieRubyRoo
Yesterday at 10:15 PM
PTFE rear main seal installed NOT dry
by eyeofthetiger
Yesterday at 09:22 PM
Why call standard spark plugs “copper plugs”?
by y_p_w
Yesterday at 08:58 PM
Sesame seed oil for chicken marinade?
by aquariuscsm
Yesterday at 08:39 PM
Microgreen M G 201-7 6k, CUT OPEN
by car51
Yesterday at 08:34 PM
NAPA PLATINUM 41516, 17.2k CUT OPEN
by car51
Yesterday at 08:24 PM
They don't make 'em like they used to...
by Alex_V
Yesterday at 06:55 PM
5W-20 P.U.P. at Walmart (yes, in stock!) $24.97
by Linctex
Yesterday at 06:37 PM
Havoline ProDS 10w30 on Rollback at Walmart
by JohnnyJohnson
Yesterday at 05:43 PM
Richmond Raceway
by Warstud
Yesterday at 05:40 PM
2009 Mustang GT
by GMFan
Yesterday at 05:22 PM
Is your A/C ready for the summer?
by Nick1994
Yesterday at 04:51 PM
Pennzoil Synthetic Rollback Walmart
by FordBroncoVWJeta
Yesterday at 04:48 PM
Alternators, A just in case Scenario.
by rollinpete
Yesterday at 04:38 PM
Palm Ratchets
by 2015_PSD
Yesterday at 04:32 PM
2013 Equinox ATF change
by Dave Sherman
Yesterday at 04:13 PM
Champion vs NGK Spark Plugs ?? Iridium
by fins
Yesterday at 03:46 PM
Are you driving the same car since 2010
by CourierDriver
Yesterday at 03:45 PM
Marc32275Jax, puma4440, zeroyon223, wade12345, rdatman
64806 Registered Users
28 registered (Blkstanger, AMC, aquariuscsm, bdcardinal, AZjeff, 3 invisible), 689 Guests and 36 Spiders online.
64806 Members
68 Forums
282100 Topics
Page 1 of 2 1 2 >
#4727550 - 04/15/18 09:32 AM Using saved Brake Fluid
Touring5 Offline
Loc: Indiana
I know that brake fluid absorbs moisture and we always want to use fresh fluid, but I have a situation that I'm curious about and would be interested in others' opinion.
A couple of years ago I flushed the brakes in one of my cars using ATE 200 fluid. I used one can and only about 15% of a second one. I screwed the cap on the second can tightly as soon as I poured out what I needed. I then put that can in a ziplock bag and then that into a second ziplock bag and have kept it in my basement for a couple of years (pretty constant temperature of 65 F and 50% humidity).
How much do you think the fluid has been "compromised". I know that PE ziplock bags are far from being totally impervious, but would two be effective in preventing any further moisture absorption in the closed can? Also, I now have some mylar ziplock bags at my disposal and wonder if using one of those would be more effective for future storage.
I don't have a huge problem with throwing out the saved brake fluid, but if it can be saved effectively I'd prefer to avoid waste.
FIRST LAW OF DEBATE
Never argue with a fool - people might
not know the difference.
#4727569 - 04/15/18 09:49 AM Re: Using saved Brake Fluid [Re: Touring5]
DBMaster Offline
Loc: DFW
I simply screw the cap back on and use it until it's gone. I never gave a second thought to whether or not it has absorbed moisture. Oh, the humanity! YMMV
#4727571 - 04/15/18 09:52 AM Re: Using saved Brake Fluid [Re: DBMaster]
NormanBuntz Offline
Loc: Outer Banks, NC
+1. Use it up.
"What is it, the first hole I dug?"
2017 Honda Odyssey SE
2013 Honda Accord LX
2007 Honda Ridgeline RTS
2007 Infiniti M35
#4727577 - 04/15/18 09:57 AM Re: Using saved Brake Fluid [Re: Touring5]
Snagglefoot Offline
Loc: Alberta
+2 Use it up.
#4727581 - 04/15/18 09:58 AM Re: Using saved Brake Fluid [Re: Touring5]
old1 Offline
Loc: Columbus Nebraska
+3 +++
2014 Fusion 2.5 engine 5/20 QSUD
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 15/40 Delo
1929 ford model A No filters, and 15/40 oil
#4727594 - 04/15/18 10:06 AM Re: Using saved Brake Fluid [Re: Touring5]
Touring5 Offline
Loc: Indiana
I think I'll do just that. I'll put the 'open' fluid in my secondary car and use new for my main vehicle (they're still old by most standards, LOL).
FIRST LAW OF DEBATE
#4727615 - 04/15/18 10:25 AM Re: Using saved Brake Fluid [Re: Touring5]
eljefino Offline
Loc: ME
It's fine.
#4727625 - 04/15/18 10:34 AM Re: Using saved Brake Fluid [Re: Touring5]
Jimzz Offline
Loc: NoVA
I do the same, put it in a freezer zip bag after sealing. I use it up like that for many decades now and never had an issue.
yup
#4727658 - 04/15/18 11:01 AM Re: Using saved Brake Fluid [Re: Touring5]
slacktide_bitog Offline
Loc: USA
ATE comes in a metal can, so it is fine smile
The issue is with plastic bottles crzy
#4727690 - 04/15/18 11:28 AM Re: Using saved Brake Fluid [Re: Touring5]
Reddy45 Offline
Loc: USA
On the same note, if you run the car at the track and do some heavy braking then that fluid is going to heat up. Will that cleanse the brake fluid of moisture?
#4727770 - 04/15/18 12:39 PM Re: Using saved Brake Fluid [Re: Touring5]
Yah-Tah-Hey Offline
Loc: Columbus,Nebraska
Have never found a place that will take brake fluid. Mention brake fluid at a hazardous material collection event and eyeballs roll around like you have the plague. sick
#4727779 - 04/15/18 12:44 PM Re: Using saved Brake Fluid [Re: Reddy45]
Uphill_Both_Ways Offline
Loc: Winnipeg
No.
http://tiltonracing.com/brake-fluid-stay-safe-and-go-fast/
Quote:
When the brake fluid becomes saturated with water (3.7 percent by volume), that water can boil in the lines and produce steam (the gaseous form of water). Unlike a liquid, a gas is highly compressible. To some [sic] this up, when a compressible substance (steam) is introduced into a hydraulic system (the brakes), that system can no longer function and the pedal will likely go to the floor –not good! Replacing the fluid before it becomes saturated with water (which we will touch on later) is the key to maintaining the dry boiling point. . . .
2008 Impala 3.5
#4727841 - 04/15/18 02:00 PM Re: Using saved Brake Fluid [Re: Touring5]
Reddy45 Offline
Loc: USA
I guess I should have framed my question as : If your brake fluid has picked up moisture, could you heat it up (like in a clean pot) and cook off the moisture and then use it again in the car?
#4727900 - 04/15/18 03:13 PM Re: Using saved Brake Fluid [Re: Touring5]
barryh Offline
Loc: Cheshire, England
We are all happy to use fluid in a vented master cylinder reservoir for 2 years and in many cases much longer yet the fluid in a sealed can somehow deteriorates immediately on opening. That's a ridiculous notion, in a sealed can it has to last a lot longer than in does in the cars brake system.
The OP took good precautions and I think the fluid will be just fine. It could always be tested for moisture content if there was any concern.
Barry
1979 BMW R45 (Triple QX 5W40)
2009 Mercedes C180K (Shell Helix Ultra 5W40)
#4727914 - 04/15/18 03:33 PM Re: Using saved Brake Fluid [Re: Yah-Tah-Hey]
Warstud Offline
Loc: MIchigan
You can mix it in with your used oil,trans fluid, ps fluid and gear oil.
Page 1 of 2 1 2 >
