Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
33 registered members (das_peikko, carlprop, alcyon, clinebarger, csandste, Ag76), 717 guests, and 67 spiders.
Topics286,441
Posts4,908,218
Members67,622
Most Online2,967
Mar 10th, 2019
Dexos 1 Gen 2? #4727536
04/15/18 09:24 AM
04/15/18 09:24 AM
Bucks, PA
zfasts03 Offline OP
zfasts03  Offline OP
Bucks, PA
I understand the new formulation benefits of Dexos 1 Gen 2 by the oil companies to minimized LSPI events is better for engines that are Direct Injected, especially turbo direct injected.
BUT! Is this new formulation also better for port injected engines (non-direct injected)? Not pre-ignition wise, but lubrication wise.
It seems as with some of the newest formulations, some have mentioned a cheapened/lesser product with shearing/viscosity loss, low temp pour point is not as good, etc. Possibly due to the new GTL base stocks?
- 03 Corvette Z06
Amsoil 5w-30 SS
- 07 Honda Accord 2.4L
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Amsoil 0w-20 SS, XG10575(16-28 by-pass)
- 18 4Runner TRD Off Road
Amsoil 0w-30 SS, TRD filter
Re: Dexos 1 Gen 2? [Re: zfasts03] #4727554
04/15/18 09:37 AM
04/15/18 09:37 AM
Colorado Springs
Drew99GT Offline
Drew99GT  Offline
Colorado Springs
Thanks for asking this question! I've been wanting to ask this as well. The reduction in calcium as me worried, but I guess it's not a big deal since all companies are adopting this standard it seems. There isn't really a choice now to have a synthetic GF-5 oil that is not Dexos 1 Gen 2
Re: Dexos 1 Gen 2? [Re: zfasts03] #4727559
04/15/18 09:40 AM
04/15/18 09:40 AM
PimTac Offline
PimTac  Offline
The reduction in calcium is usually offset by increases in other detergent components, magnesium being one.
Cannot see signatures any longer so it doesn’t matter.
Re: Dexos 1 Gen 2? [Re: zfasts03] #4727562
04/15/18 09:41 AM
04/15/18 09:41 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
GM in Europe spec Dexos 2 for all gas and light diesel engines even in climates similar to the the US north east even for the same engines available in US. I think its a fair question to ask why.
Re: Dexos 1 Gen 2? [Re: PimTac] #4727564
04/15/18 09:46 AM
04/15/18 09:46 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Yes, the D1G2 seem to have pretty good magnesium and molybdenum numbers.
If you want the job done right......do it yourself.
Re: Dexos 1 Gen 2? [Re: Snagglefoot] #4727572
04/15/18 09:52 AM
04/15/18 09:52 AM
Snagglefoot Offline
Snagglefoot  Offline
If anyone has seen problems with UOA’s from D1G2 oils, please post them because so far I have not seen any problems.
Re: Dexos 1 Gen 2? [Re: zfasts03] #4727585
04/15/18 10:00 AM
04/15/18 10:00 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
If you look up what the new oils need to meet how can some say they are a in anyway a lesser oil?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Dexos 1 Gen 2? [Re: Snagglefoot] #4727588
04/15/18 10:03 AM
04/15/18 10:03 AM
PimTac Offline
PimTac  Offline
I don’t think we would be able to trace any issue back to the oil itself unless we see a wider trend like older cars sludging up. Even then it would be difficult to blame the oil as there are too many variables to consider.
I for one think the move has improved the oils. The idea that more of something means it is better is a misnomer. We see lots of uoa’s here from oils with hardly any add pack yet the numbers are excellent.
Re: Dexos 1 Gen 2? [Re: zfasts03] #4727632
04/15/18 10:40 AM
04/15/18 10:40 AM
So. Calif.
turnbowm Offline
turnbowm  Offline
So. Calif.
The Dexos1 Gen2 spec addresses timing chain wear as well as LSPI. Something to consider even for older port-injected engines.
2015 Kia Optima EX 2.4L GDI
2015 Chevy Volt
Re: Dexos 1 Gen 2? [Re: zfasts03] #4727637
04/15/18 10:46 AM
04/15/18 10:46 AM
Alberta
BigJakeChevy Offline
Alberta
My concerns with these new formulations are the low levels of zddp and in my application 5w30 they're so thin now! Is there any chance that in an older V8 like my gm 5.3 will i see increased wear due to the lower viscosity?
2007 Silverado Classic 1500 Crewcab 5.3L 470,000KM
Engine oil Mobil 1 0w40fs
Oil Filter Fram Ultra 10575
Trans Oil Amsoil Torque Drive
Front Diff Amsoil SG75w90
T-Case Autotrak II
Rear Diff Amsoil SG75w110
Re: Dexos 1 Gen 2? [Re: zfasts03] #4727638
04/15/18 10:48 AM
04/15/18 10:48 AM
Great White North.. eh
webfors Offline
webfors  Offline
It would be good to know the hths specs between old D1 and new D1G2 formulations. For timing chain wear I would assume a higher hths.
17 Cadillac ATS 2.0T, Edge D1G2 5w30, XG10575
17 Dodge GC, VWB 5w30, Mopar MO-349
15 DL650, Rotella T6 5w40, KN-138
Small engines; RT5 10w30
Re: Dexos 1 Gen 2? [Re: zfasts03] #4727650
04/15/18 10:58 AM
04/15/18 10:58 AM
PimTac Offline
PimTac  Offline
Valvoline’s reformulation bumped their HTHS on the 0w20 from 2.6 to 2.7. That may not seem like much but it’s still a 4-5% increase which is something. This is one example but I suspect we may see similar results among the other companies as well.
The other standout change is the use of titanium in the add pack.
Re: Dexos 1 Gen 2? [Re: turnbowm] #4727689
04/15/18 11:28 AM
04/15/18 11:28 AM
Danh Offline
Danh  Offline
I think part of the reason for added timing chain wear protection is the soot all DI engines produce that winds up in sump oil. Still, added protection can’t be a bad thing.
Re: Dexos 1 Gen 2? [Re: Danh] #4727692
04/15/18 11:30 AM
04/15/18 11:30 AM
webfors Offline
webfors  Offline
Good argument for more frequent OCIs.
Re: Dexos 1 Gen 2? [Re: Danh] #4727769
04/15/18 12:39 PM
04/15/18 12:39 PM
The land of USA-made Subies!
SubieRubyRoo Online happy
SubieRubyRoo  Online Happy
Do you have any UOAs that back up that assumption? Soot typically is something a diesel engine deals with. Fuel dilution in T/GDI, sure, but no soot. I think most of the reason for timing chain wear is the low HTHS oils more than anything- there are millions of SBCs/BBCs/SBFs running around for hundreds of millions of miles without the issues seen on timing chains on today's new cars. Chains are essentially still the same as they ever have been, the only real thing to change in that ecosystem is the oil lubricating the whole mess.
