Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
35 registered members (ArrestMeRedZ, Bailes1992, AndyB, Atesz792, bmod305, Brad_C, 3 invisible), 652 guests, and 61 spiders.
Topics286,442
Posts4,908,228
Members67,622
Most Online2,967
Mar 10th, 2019
What is your opinion on my tire wear? #4727481
04/15/18 08:37 AM
04/15/18 08:37 AM
Fort Smith, AR
Roger Offline OP
Roger  Offline OP
Fort Smith, AR
I rotated the tires on my Honda Pilot yesterday at 21,000 miles for the 3rd time since I bought the vehicle new 1 1/2 years ago. When I do this I always check the tread depth. The tires are Bridgestone Dueler H/P Sport AS tires with 4 tread groves that allow me to get, you guessed it ... 4 depth readings on each tire. Two on the middle and two on each edge.
The two rear tires had the same even readings across the width of the whole tire at 8, 8, 8, & 8 32nds. The two front tires also had the same readings across the width of the tire, but they were 7, 6, 6, & 7 32nds each. I have not had an alignment done since buying the car and keep the pressure at the manufacturer's spec - 32 psi. Other than the difference in tread depth I did not see any abnormal wear. Factory specs show the tread depth to be 10/32nds when new.
My suspicion is that the wear in the middle of the front tires is simply due to turning and steering. What do you think?
Re: What is your opinion on my tire wear? [Re: Roger] #4727503
04/15/18 08:56 AM
04/15/18 08:56 AM
TX
parshisa Offline
parshisa  Offline
TX
Same thing on my pilot. Ive had alignment done twice and it still pulls to the right. Not sure what is up with this
Re: What is your opinion on my tire wear? [Re: Roger] #4727509
04/15/18 09:01 AM
04/15/18 09:01 AM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
When a tire wears more in the middle is a sign of overinflation.
Re: What is your opinion on my tire wear? [Re: Roger] #4727518
04/15/18 09:08 AM
04/15/18 09:08 AM
Roswell GA
eagle23 Offline
eagle23  Offline
Roswell GA
In general, if the centers wear faster, it's over-inflation. If the outer treads wear faster, it's under-inflation. Cornering wear (or alignment not suited to your driving style; either one) would show as the outer treads being shallower.
With the center treads a bit shallower, it looks like the inflation is a bit higher than needed. Some people like that for a bit better gas mileage and a bit more responsiveness to changes in direction; some don't. But I would choose that over under-inflation. Either comes at the cost of uneven tire wear.
Given what you described, I wouldn't change anything. The differences are too small at this point to worry about over the life of the tire.
If the car pulled to one side or another, that could be either alignment or a tire with potential belt separation.
HTH.
Re: What is your opinion on my tire wear? [Re: Roger] #4727520
04/15/18 09:11 AM
04/15/18 09:11 AM
CA
raytseng Offline
raytseng  Offline
CA
i would not read into this unless this is your 2nd set of tires.
OEM tires are always a bit wonky and maybe designed to different specs and wear faster or unevenly. even if they are the exact same name as a consumer tire, they maybe a one off spec run for OEM.
Re: What is your opinion on my tire wear? [Re: Roger] #4727540
04/15/18 09:26 AM
04/15/18 09:26 AM
Nevada, USA
gaijinnv Offline
gaijinnv  Offline
Nevada, USA
Can't delete mad
USN NAVSECGRU 1970-1974
Re: What is your opinion on my tire wear? [Re: Roger] #4727620
04/15/18 10:29 AM
04/15/18 10:29 AM
ME
eljefino Offline
eljefino  Offline
ME
I'm with Eagle-- I hate when tires wear out on the shoulders. I'd like to keep "sharp" shoulder blocks for the life of the tire.
You're rotating, so rotate away and drive
Re: What is your opinion on my tire wear? [Re: eagle23] #4727626
04/15/18 10:34 AM
04/15/18 10:34 AM
Fort Smith, AR
Roger Offline OP
Roger  Offline OP
Fort Smith, AR
You got me thinking. I'd guess that 80% of the miles lately have been sustained highway driving ... 60 - 75 mph. When that happens the tire pressure always increases due to heat. Sometimes the dash TPMS shows tire pressure up to 37 - 39 psi on hot days even though the cold pressure started out at 32 psi. My Pilot does get good gas mileage on the highway ... usually 29 mpg, sometimes up to 33 mpg with a strong tail wind. But only 23 - 25 into the wind cry
Re: What is your opinion on my tire wear? [Re: Roger] #4727684
04/15/18 11:22 AM
04/15/18 11:22 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
I gave up planning my trips in accordance with wind direction years ago.
Re: What is your opinion on my tire wear? [Re: Roger] #4727760
04/15/18 12:31 PM
04/15/18 12:31 PM
US
JLTD Offline
JLTD  Offline
US
Your wear is fine. I bet after another 7k you can swap the measurements...
I use the overseas owner's manual to choose my oil.
Using AMSOIL
Hers: 2008 Jeep Liberty 143k, SS 5w30/Amsoil
His: 2015 4Runner 51k, OE 5w30/Wix
Re: What is your opinion on my tire wear? [Re: Roger] #4727771
04/15/18 12:42 PM
04/15/18 12:42 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
The shallow center on the fronts is curious, however I'd keep on driving and rotating. If it was mine I think I'd be running the pressure much higher, as I do with all FWD vehicles. I've checked tire wear and inflation on hundreds of vehicles and have yet to see any front-wheel drive vehicle clearly wearing the centers out of the tires.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: What is your opinion on my tire wear? [Re: Roger] #4727772
04/15/18 12:42 PM
04/15/18 12:42 PM
Roswell GA
eagle23 Offline
eagle23  Offline
Roswell GA
Okay, now you got me thinking... wink
IDK how accurate the TPMS is. The only way to know would be to be on the highway where the TPMS shows elevated pressures (the 37-39 you referred to), and then make a normal stop and check them.
Reason I say that is it seems a lot of the tires I've had in recent years don't seem to raise pressure much. Maybe 2-4 psi, which I expect, but not the 5-7 psi you mention. Obviously, that may vary with tire, vehicle loading, road conditions (hot vs. cold weather), etc.
Short of actually checking pressures, you may want to use the TPMS as an indicator and value it, but not take it literally at small psi differences. Just a thought.
Re: What is your opinion on my tire wear? [Re: parshisa] #4727831
04/15/18 01:50 PM
04/15/18 01:50 PM
Roswell GA
eagle23 Offline
eagle23  Offline
Roswell GA
Have you rotated the tires front to rear? If one of them is going bad that can cause a pull, even though the tire balances fine and there is no obvious vibration. If you haven't rotated them, putting the offending tire (whichever one it may be) in the back may remove the pull.
One other thought...how much can the shop align the front end? Some cars require special camber alignment cams to do that. Not sure if yours is one of them.
Did the shop offer a printout of the final alignment settings? Some places call it a day when the settings are "within factory specs" no matter how the car drove or how far off the settings are from each other. They may claim "But they're within spec." Yeah, but it drives lousy, so please fix the problem!
Okay, one MORE thought smile I can't recall, but ages ago it seemed good practice to dial in just a bit more caster on the right side, to allow for road surfaces with crowns on them (meant to help water runoff). If the crown is more pronounced, the pull to the right can be there. Does it pull on all roads or just some?
I am curious if those with more alignment background than I have can speak to this.
HTH
Re: What is your opinion on my tire wear? [Re: eagle23] #4727861
04/15/18 02:22 PM
04/15/18 02:22 PM
TX
parshisa Offline
parshisa  Offline
TX
I've had one rotation done thus far and car is at 17K now. The printout I was given basically said it was all 'green' and within spec. And it pulls harder on some roads and less on the other. not sure what's up with that. I might give it another try and do alignment again. If that won't help probably re-balance the wheels
Re: What is your opinion on my tire wear? [Re: Roger] #4727875
04/15/18 02:42 PM
04/15/18 02:42 PM
TX
parshisa Offline
parshisa  Offline
TX
I just checked all 4 tires with the gauge and fronts measured 7-7-7-6 (the last number is the grove closest to the face of the tire). Rear tires read pretty much the same but instead of 6 I'd say it is 6.5 and closer to 7. Current odo reading is 17.5K and the car doesn't see much of the highway. Would that be considered normal wear for this mileage?
