Remote Start by Android Auto App ?
by LoneRanger. 04/19/19 04:53 PM
Continental PureContact LS
by The Critic. 04/19/19 03:31 PM
Dark/Black Rear Differential Oil - UOA?
by The Critic. 04/19/19 03:25 PM
Best oil for Honda Rancher?
by jayjr1105. 04/19/19 03:20 PM
Store bought kimchi?
by Quattro Pete. 04/19/19 03:15 PM
2020 KIA Soul Turbo
by Malo83. 04/19/19 03:03 PM
erratic Speedometer
by tookien. 04/19/19 02:59 PM
Another airbag recall
by mclasser. 04/19/19 02:44 PM
Which barb fitting is less likely to leak?
by zorobabel. 04/19/19 02:36 PM
Can these bucket style tappets be reused?
by atikovi. 04/19/19 01:34 PM
Scratched My New Car. Help Me Fix
by GeorgeKaplan. 04/19/19 01:23 PM
Talk about manual labor...
by AZjeff. 04/19/19 12:42 PM
Car didn't burn an ounce of oil... 7K OCI
by jayjr1105. 04/19/19 12:13 PM
Top 6 OEM Passenger Tire Sizes in 2018
by SubLGT. 04/19/19 11:12 AM
CRC intake valve cleaner, safe to use?
by Backstache. 04/19/19 10:06 AM
'94 Grand Am Steering Column Pivot Pins
by benjamming. 04/19/19 10:02 AM
Why the need to replace suspension springs?
by WyrTwister. 04/19/19 09:47 AM
incorrect mileage on reciept
by 1978elcamino. 04/19/19 09:17 AM
Oregon PowerSharp for chainsaw
by Fitter30. 04/19/19 09:16 AM
new tire 4 years old
by 1978elcamino. 04/19/19 08:51 AM
carve200, Harteeco, fatafox, CurtC, LockCracker
67850 Registered Users
99 registered members (bbhero, ArrestMeRedZ, 2015_PSD, Anduril, Astro14, 17 invisible), 2,156 guests, and 31 spiders.
Topics287,749
Posts4,933,796
Members67,850
Most Online2,967
Mar 10th, 2019
Motorguard Coolant Filter Change #4727095
04/14/18 08:12 PM
04/14/18 08:12 PM
Alaska
AlaskaMike Offline OP
Alaska
I couldn't find it, but in an earlier thread last year I mentioned that I would post some pics when the time came this spring to change out the TP roll in the Motorguard I'm using as a coolant filter on my 2000 Dodge. It's that time, and I just changed it out and grabbed a couple of photos.
The roll shown in these two pics was installed at the same time as I replaced my water pump last spring and refilled with new coolant and distilled water.
The TP changes at this point don't really catch a whole lot. The really nasty stuff was caught with the first couple of rolls. It does kind of surprise me how much it does filter out of new fresh coolant though.
Re: Motorguard Coolant Filter Change [Re: AlaskaMike] #4727222
04/14/18 10:23 PM
04/14/18 10:23 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
How does the TP not disintegrate? I thought most TP are designed to break down in the presence of water for the sake of sewers?
Re: Motorguard Coolant Filter Change [Re: AlaskaMike] #4727290
04/15/18 01:09 AM
04/15/18 01:09 AM
Alaska
Alaska
Completely different environment. In the Motorguard housing the TP is compressed and under slight pressure from the coolant flow.
In a septic system there's probably also some bacterial metabolic action going on since the TP is organic material.
Re: Motorguard Coolant Filter Change [Re: AlaskaMike] #4728888
04/16/18 01:36 PM
04/16/18 01:36 PM
Charles City, Iowa
rideahorse Offline
rideahorse  Offline
Charles City, Iowa
There are 2 types of TP. One is for septic systems and breaks down very fast and the other is for city systems and is much stronger.
Re: Motorguard Coolant Filter Change [Re: AlaskaMike] #4760525
05/18/18 02:54 AM
05/18/18 02:54 AM
Virginia, usa
Shata Offline
Shata  Offline
Virginia, usa
TP tightly wrapped like that and slightly under pressure and compressed in housing wont break down. They been using this TP method since mid 50s. I use TP based one on my truck also. Works great and its cheap. I dont have coolant one but for oil.
16 Silverado 2500 LML 22k Miles
Rotella 15w-40 T4
ST 75w-90 Diff.
ST Full Syn Dexron VI ATF
Fram Ultra XG9100, AC Delco Fuel
CAT Coolant filter, K&N Air, K&N Cabin
Filter Mags: Fuel, Allison, LML
Re: Motorguard Coolant Filter Change [Re: AlaskaMike] #4843762
08/18/18 12:59 PM
08/18/18 12:59 PM
Home
Lost Pup Offline
Lost Pup  Offline
Home
I did notice that my coolant recovery tank remains clear and clean since I have installed the Motorguard on my F150.
Re: Motorguard Coolant Filter Change [Re: AlaskaMike] #4844199
08/19/18 01:02 AM
08/19/18 01:02 AM
Alaska
Alaska
My recovery tank has always been pretty clean, and I can't say that the bypass filter made any difference in that regard. My installation was part academic experiment, and part intention to lengthen the life of the water pump.
I can't say yet whether my coolant bypass filter has helped my water pump life, but it obviously isn't hurting anything and is clearly filtering crud out of the system. On that basis alone I'm happy with it.
How often are you changing elements on your F150?
I'm curious to know if you saw the same thing I did with mine--the first element change was absolutely nasty, appearing to have captured rust and casting sand, but subsequent changes captured far less, resulting in my decision to change out elements every 2 years or so.
Re: Motorguard Coolant Filter Change [Re: AlaskaMike] #4871707
09/18/18 08:40 AM
09/18/18 08:40 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Which model of Motor Guard is that?
Re: Motorguard Coolant Filter Change [Re: DoubleWasp] #4873239
09/19/18 11:19 PM
09/19/18 11:19 PM
Alaska
Alaska
I believe it's an M30, but I don't know for certain. The M60 apparently uses 1/2" NPT fittings, and the M30 uses 1/4" NPT fittings, which is what mine uses.
Re: Motorguard Coolant Filter Change [Re: AlaskaMike] #4876221
09/22/18 08:31 PM
09/22/18 08:31 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Did you convert it to run TP, or did it already do that. I only seem to find them as compressed air filters.
Re: Motorguard Coolant Filter Change [Re: AlaskaMike] #4876256
09/22/18 09:02 PM
09/22/18 09:02 PM
Kelowna, BC, Canada
A310 Offline
A310  Offline
Kelowna, BC, Canada
Looks like a stock standard M30 with extra cores cut to fit the M30's 1.5" center, still has the polypropylene center core as well.
2009 Ford F-350 (Detroit 4-53T)
2000 Ford Excursion (Triton V10)
1993 Dodge D250 (Cummins 6BT)
Re: Motorguard Coolant Filter Change [Re: AlaskaMike] #4901464
10/20/18 08:19 PM
10/20/18 08:19 PM
Alaska
Alaska
Sorry I was so long in replying to this--I haven't been to the site in a while. Yes, A310 is correct. Mine is totally unmodified.
Is it possible to buy replacement cores that are larger diameter and made out of aluminum or steel?
Re: Motorguard Coolant Filter Change [Re: AlaskaMike] #4905908
10/25/18 05:43 PM
10/25/18 05:43 PM
Kelowna, BC, Canada
A310 Offline
A310  Offline
Kelowna, BC, Canada
Not that I'm aware of, the earlier M30's did have aluminum cores but were switched out in favour of the existing polypropylene.
