The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
Rough idle... Only in drive
by nicholas. 03/23/19 07:02 PM
Using synthetic blend or full synthetic oil
by FixItDad28. 03/23/19 07:01 PM
What's in Maxima oil?
by Truckedup. 03/23/19 06:29 PM
2015 Acura TLX 3.5L V6
by blackdiamond. 03/23/19 06:20 PM
Group 3 oil with best heat stability?
by LSXHitman. 03/23/19 05:24 PM
FixItDad28, RandomJoe, Sciascia, sosp197, peppercorn
67597 Registered Users
25 registered members (c502cid, dishdude, carlprop, csandste, Blkstanger, 3 invisible), 740 guests, and 56 spiders.
Topics286,320
Posts4,906,408
Members67,597
Most Online2,967
Mar 10th, 2019
Lubricating 9x7 Garage Doors #4726630
04/14/18 10:52 AM
04/14/18 10:52 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Since I have broken a torsion spring and am having to replace it, I am gonna do a few upgrades on my garage doors. Doors have been up since 1994 and are noising as heck. Wind blows them as I have a lot of slop in the current wheels.
I am considering purchasing the nylon sealed roller bearing and maybe get new end plates. Gonna get the next "higher" spring size to double my cycles from 10k to 21K
$25 per door for the sealed lifetime roller bearings.
But, is there a consensus as to what to use to lubricate the torsion spring and chain drive?
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Schaeffer in the first two.
Re: Lubricating 9x7 Garage Doors [Re: Gebo] #4726640
04/14/18 10:59 AM
04/14/18 10:59 AM
Raleigh ,NC CSA
rshaw125 Offline
rshaw125  Offline
Raleigh ,NC CSA
They make one just for it.
2012 Porsche Carrera S
2016 Ford Edge 2.0
2002 Taurus Vulcan SOLD
2006 Explorer SOLD
Re: Lubricating 9x7 Garage Doors [Re: Gebo] #4726641
04/14/18 11:02 AM
04/14/18 11:02 AM
USA
oldhp Offline
oldhp  Offline
USA
I've use the spray on tacky grease (it foams and goes into the links) that you use on motorcycle chains. I would think it would also work on the springs too.
2018 RAM 1500 3.6/8 speed.
2017 Jeep Sahara Unlimited 3.6
"U kan't fixe it......if'n it ain't broke."
Re: Lubricating 9x7 Garage Doors [Re: rshaw125] #4726647
04/14/18 11:13 AM
04/14/18 11:13 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Which one is it? smile
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Re: Lubricating 9x7 Garage Doors [Re: Gebo] #4726663
04/14/18 11:27 AM
04/14/18 11:27 AM
Raleigh ,NC CSA
rshaw125 Offline
rshaw125  Offline
Raleigh ,NC CSA
They sell it at Home Depot where they have the openers and parts. Blue spray can.
2016 Ford Edge 2.0
2006 Explorer SOLD
Re: Lubricating 9x7 Garage Doors [Re: rshaw125] #4726669
04/14/18 11:34 AM
04/14/18 11:34 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Gotcha!
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Re: Lubricating 9x7 Garage Doors [Re: Gebo] #4726675
04/14/18 11:43 AM
04/14/18 11:43 AM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Watch this video before lubicating anything.
Re: Lubricating 9x7 Garage Doors [Re: Gebo] #4726683
04/14/18 12:01 PM
04/14/18 12:01 PM
Alaska
AlaskaMike Offline
AlaskaMike  Offline
Alaska
It's just simple silicone spray lube. You can buy specialized "garage door" spray lube for excessive prices, or you can buy generic silicone, but it's the very same stuff.
I usually use PB Blaster Silicone lube because I can find it for about three bucks a can.
By the way--if you're replacing one spring because it broke, you might as well replace the other one at the same time. It's gone through the same number of cycles, and presumably it's the same age.
Re: Lubricating 9x7 Garage Doors [Re: Gebo] #4726700
04/14/18 12:16 PM
04/14/18 12:16 PM
Mississippi
TheLawnRanger Offline
Mississippi
I used to always use WD-40 when I lived in a house with a garage. I would just apply when I started to hear the squeaking again which was usually after 8 months to a year. I started using it when I had the door serviced by a professional garage door service. I asked the guy where I could buy the spray he was using. He said WD-40 was similar and cheaper. I would likely use the real product now if not an outrageous price.
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Filters: Wix 51522 for both
Re: Lubricating 9x7 Garage Doors [Re: Gebo] #4726706
04/14/18 12:28 PM
04/14/18 12:28 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Great video!
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Re: Lubricating 9x7 Garage Doors [Re: Gebo] #4726946
04/14/18 04:55 PM
04/14/18 04:55 PM
Glendale, Arizona
billt460 Offline
billt460  Offline
Glendale, Arizona
I just had all the rollers replaced last year when I had my new door opener installed. The installer told me to ONLY use a silicone based garage door lube, and nothing else. He was quite insistent about it. He installs several garage doors a day. So I figure he's seen it all, and has no reason to misdirect.
Re: Lubricating 9x7 Garage Doors [Re: Gebo] #4726970
04/14/18 05:45 PM
04/14/18 05:45 PM
USA
SOHCman Offline
SOHCman  Offline
USA
gear lube works fine.
I urge people not to wait 100K to change out the fluid in their transfer case units. -Kestas
Re: Lubricating 9x7 Garage Doors [Re: Gebo] #4726982
04/14/18 06:06 PM
04/14/18 06:06 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
The place where I am buying my torsion springs told me to use 40 weight nondetergent Motor oil. Isnít it amazing how many different points of view you can get from the professionals?
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Re: Lubricating 9x7 Garage Doors [Re: Gebo] #4727009
04/14/18 06:39 PM
04/14/18 06:39 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
less lube is better too much just gets all nasty with dirt.
Make sure you read how to do it.. most people spray on wrong stuff.
Re: Lubricating 9x7 Garage Doors [Re: Gebo] #4727015
04/14/18 06:45 PM
04/14/18 06:45 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Probably depends on how cold it gets in the winter.
