.05 Cent haynes manual
by Jman26063. 03/26/19 09:02 PM
Pennzoil Canada Rebate
by Snagglefoot. 03/26/19 09:01 PM
Burned out blinker
by Chris142. 03/26/19 09:00 PM
Best Moly add for timing chain health?
by RichR. 03/26/19 08:53 PM
Kenmore dishwasher quit.
by Trotter. 03/26/19 08:49 PM
Urethane with integrated clear coat cure time?
by FixItDad28. 03/26/19 08:39 PM
Chevron rykon premium mv alternative?
by Framer. 03/26/19 08:12 PM
Got a bunch of new old stock oil and filters...
by dogememe. 03/26/19 07:04 PM
Right turn signal blinking super fast
by das_peikko. 03/26/19 06:55 PM
Another fun car to work on.
by Chris142. 03/26/19 06:48 PM
Equivalent LED T8/T12 tubes?
by y_p_w. 03/26/19 06:37 PM
Do you use chemicals on your lawn?
by ZZman. 03/26/19 05:21 PM
Baked Cabbage Steaks
by StevieC. 03/26/19 02:57 PM
Best Store Bought BBQ Sauce?
by Redright9. 03/26/19 02:26 PM
Hankook tire rebate
by FordBroncoVWJeta. 03/26/19 01:14 PM
Dave Graham repair manual?
by HangFire. 03/26/19 01:02 PM
Framer, Joe_Gibbs, PerryPerrister, brak132, mike001100
67635 Registered Users
133 registered members (4WD, 2002 Maxima SE, 2004tdigls, 01rangerxl, 13 invisible), 2,142 guests, and 98 spiders.
Topics286,474
Posts4,909,095
Members67,635
Most Online2,967
Mar 10th, 2019
add my maxlife 5 30 #4726343
04/13/18 11:26 PM
04/13/18 11:26 PM
California
Hybrid Offline OP
Hybrid  Offline OP
California
hi all !
i have a few jugs of Valvoline maxlife 5 30 and was wondering if its ok
to add it to my 2 other vehicles requiring 0w 20?. and how much to add.
thx
Re: add my maxlife 5 30 [Re: Hybrid] #4726347
04/13/18 11:30 PM
04/13/18 11:30 PM
Western Ma.
rollinpete Offline
rollinpete  Offline
Western Ma.
50 50
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive187k miles
03 Saturn Ion 2.2 L4 5spddrive238K miles
PPHM 5w30 and Fram Ultra x 2
Currently under the influence of oil shocked2
Re: add my maxlife 5 30 [Re: Hybrid] #4726349
04/13/18 11:33 PM
04/13/18 11:33 PM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
I would avoid that unless they're burning oil, at least not put more than a quart in at each oil change if that. Maxlife contains seal swellers which if you don't have worn out seals, will cause them to wear faster.
Re: add my maxlife 5 30 [Re: rollinpete] #4726350
04/13/18 11:35 PM
04/13/18 11:35 PM
California
Hybrid Offline OP
Hybrid  Offline OP
California
thx
i was thinking 25% or 3:1 ??
Re: add my maxlife 5 30 [Re: Dave9] #4726351
04/13/18 11:36 PM
04/13/18 11:36 PM
California
Hybrid Offline OP
Hybrid  Offline OP
California
... even in summer in cali ??
Re: add my maxlife 5 30 [Re: Hybrid] #4726358
04/13/18 11:47 PM
04/13/18 11:47 PM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
You have some reason to believe that seal swellers in Cali go on vacation during the summer? Adding a little 5W30 of regular oil (not maxlife) would be fine but there's a reason that those seal swellers aren't put in ALL oil, only for worn engines. Once you start using it you'll want to keep using it.
Re: add my maxlife 5 30 [Re: Hybrid] #4726476
04/14/18 07:40 AM
04/14/18 07:40 AM
MO
Carbon12 Offline
Carbon12  Offline
MO
No oil company or auto manufacturer that I am aware of makes any kind of claim that once a high mileage oil is used it must continue to be used. Maxlife full synthetic carries Dexos (GM) approval so it's suitable even in a new car. The maxlife syn blend carried in the past as well. All oils, regular or HM are said to contain seal conditioners but they are a little higher in HM oils. It's very doubtful you will have any problems adding some HM oil to regular even in a lower mileage vehicle and then switch back to all non HM
Re: add my maxlife 5 30 [Re: Hybrid] #4726487
04/14/18 07:58 AM
04/14/18 07:58 AM
Oshawa, Ontario Canada
JC1 Online content
JC1  Online Content
What are the two cars you want to use it in and what's the mileage of each car?
I would agree that using a 3:1 ratio should be fine.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: add my maxlife 5 30 [Re: Hybrid] #4726542
04/14/18 09:22 AM
04/14/18 09:22 AM
Wishin' I was in Wi
mjk Offline
mjk  Offline
Wishin' I was in Wi
I thought that one of the conditions of API SN oil, was seal conditioners were included in ALL oils that met this spec.
At least, I thought I read about that years ago, when we moved to SN.
Re: add my maxlife 5 30 [Re: Hybrid] #4726569
04/14/18 09:52 AM
04/14/18 09:52 AM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Originally Posted By: Hybrid
thx
That would be my approach. And I'd only blend it with valvoline, preferably maxlife oil.
Would result in a viscous 20wt a very thin 30. Either should be just fine. Since we're not in the winter, startup viscosity is less of an issue.
Re: add my maxlife 5 30 [Re: Hybrid] #4726605
04/14/18 10:21 AM
04/14/18 10:21 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
I always have left over top off oil buying 5 Qt. Jugs. I'm not brand loyal. I use whatever oil I have left over for top off. Then what I don't use gets put in the mower at the beginning and middle of mowing season.
2004 Corolla 130107
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: add my maxlife 5 30 [Re: Hybrid] #4726656
04/14/18 11:20 AM
04/14/18 11:20 AM
St. Charles County, Missouri
csandste Offline
csandste  Offline
Haven't been to a Valvoline Instant Oil Change place for over a year, but at least before losing Dexos 1.2 status, Maxlife was the only semi syn they carried. As referred above, it's good to go in any car, even new and seal softeners are no big deal.
2017 Kia Soul Plus-- Super Tech Synthetic 5w30 59000 miles
Re: add my maxlife 5 30 [Re: JC1] #4727259
04/14/18 11:21 PM
04/14/18 11:21 PM
California
Hybrid Offline OP
Hybrid  Offline OP
California
2013 CRV 55k mi. and 2016 highlander 30k mi.
Re: add my maxlife 5 30 [Re: Hybrid] #4727277
04/15/18 12:30 AM
04/15/18 12:30 AM
USA
oldhp Offline
oldhp  Offline
USA
I thought it has seal conditioners, to keep them soft and pliable, not seal swellers. No?
2018 RAM 1500 3.6/8 speed.
2017 Jeep Sahara Unlimited 3.6
"U kan't fixe it......if'n it ain't broke."
Re: add my maxlife 5 30 [Re: oldhp] #4727283
04/15/18 12:52 AM
04/15/18 12:52 AM
California
Hybrid Offline OP
Hybrid  Offline OP
California
well maybe, according to him, seal conditioners become seal swellers if not
used properly. not ??
