The 2004-2008 F150 2wd use a Rotor/Hub assembly. If you need to replace the rotor you will have to buy the assembly, you can't just replace the rotor. Because it is one unit I am reluctant to buy a cheaper part instead of buying the Motorcraft Hub&Rotor part number 5U2Z-1V102-E. Does anyone have Any experience with the aftermarket assembly?
Napa is selling the assembly for as low as $90 vs $213 from my local Ford Dealership.
