4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
88 registered members (4WD, AlaskaMike, 2010Civic, AdditiveOCD, agpatel, 69Torino, 10 invisible), 1,579 guests, and 68 spiders.
Topics286,042
Posts4,901,383
Members67,551
Most Online2,967
Mar 10th, 2019
2004 -2008 F150 Front Rotor Hub Assembly #4725702
04/13/18 11:37 AM
04/13/18 11:37 AM
midwest
Billy_D Offline OP
Billy_D  Offline OP
midwest
The 2004-2008 F150 2wd use a Rotor/Hub assembly. If you need to replace the rotor you will have to buy the assembly, you can't just replace the rotor. Because it is one unit I am reluctant to buy a cheaper part instead of buying the Motorcraft Hub&Rotor part number 5U2Z-1V102-E. Does anyone have Any experience with the aftermarket assembly?
Napa is selling the assembly for as low as $90 vs $213 from my local Ford Dealership.
Re: 2004 -2008 F150 Front Rotor Hub Assembly [Re: Billy_D] #4725726
04/13/18 12:10 PM
04/13/18 12:10 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
I had an '02 F150 with that type of front rotor/hub assembly (2WD model), so my experience is not 100% relevant.
However, I used 2 different aftermarket assembles with no issues:
1st set: Advance Auto Parts
2nd set: R1 Concepts Slotted rotors (eBay brand)
I was glad to have the Haynes manual since it described the proper way to preload the axle nut. It's a good opportunity to clean and regrease the taper bearings. Buy a few dust covers since they have a tendency to get jacked up during the removal/install process.
Re: 2004 -2008 F150 Front Rotor Hub Assembly [Re: Billy_D] #4725734
04/13/18 12:18 PM
04/13/18 12:18 PM
Florida
bbartow Offline
bbartow  Offline
Florida
Rockauto carries the motorcraft part for $100 if you really want oem
Re: 2004 -2008 F150 Front Rotor Hub Assembly [Re: Billy_D] #4725750
04/13/18 12:38 PM
04/13/18 12:38 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
Just note the newest part number does not come with the locknut that you are supposed to replace whenever you take the rotor off. The old number did come with it but it was removed from the new number.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: 2004 -2008 F150 Front Rotor Hub Assembly [Re: Billy_D] #4725798
04/13/18 01:21 PM
04/13/18 01:21 PM
midwest
Billy_D Offline OP
Billy_D  Offline OP
midwest
Thanks Everyone. I have part number 6L3Z-3C294-AA for the locknut that I need to replace. I also found out that Centric makes a kit with a hub and a rotor sold separately. I don't have the part number for the kit. The Motorcraft lasted 70k miles, which is pretty good for a truck. Now for $100 that's not a bad deal.
Re: 2004 -2008 F150 Front Rotor Hub Assembly [Re: Billy_D] #4725828
04/13/18 02:00 PM
04/13/18 02:00 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Definitely go with Motorcraft from Rock auto, match with Motorcraft pads and you will have a good service life out of them.
That's not to say the MC pads are the be all and end all its just they will probably match the rotor properties from the same manufacturer to give the longest life.
