How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
I need a filter cutter person
by Marco620. 03/24/19 03:21 PM
VIRGIN BOSCH D+ 3421 CUT OPEN
by 53' Stude. 03/24/19 02:45 PM
My first cut. Donaldson P502503
by BeerCan. 03/24/19 02:25 PM
Sludge and Facebook's infinite wisdom
by RDY4WAR. 03/24/19 02:05 PM
Gear lube 75W90 Synthetic GM# 88900401
by rcbob. 03/24/19 01:47 PM
Rislone Rebates
by Nickdfresh. 03/24/19 01:42 PM
IndyCar Classic at COTA
by bdcardinal. 03/24/19 12:29 PM
STP 500 at Martinsville
by bdcardinal. 03/24/19 12:27 PM
Source For Microfiber Towels
by Wrenchturner44. 03/24/19 12:26 PM
Jcountry, CMichael, dude59, Petrolhead, stp
67608 Registered Users
113 registered members (53' Stude, 2010Civic, 92saturnsl2, 2004tdigls, 2015_PSD, 13 invisible), 2,173 guests, and 59 spiders.
Topics286,352
Posts4,906,918
Members67,608
Most Online2,967
Mar 10th, 2019
1990 VW 1.8L - Need advice #4725688
04/13/18 11:24 AM
04/13/18 11:24 AM
Bay Area, CA
ReadTheBook Offline OP
Bay Area, CA
We have a very low miles '90 VW Cabriolet just under 37K original miles on the original 1.8L motor.
As far as I know, based on records obtained with the car, it's always had conventional oil. When we got it last summer, I changed it with Castrol GTX 20W-50 per the Viscosity Requirement vs Ambient Temperature table in the Bently Manual for the MK1 platform.
I'm wondering a few things:
1. How often should I be changing the oil in this car? It gets driven ~1000 miles a year in spirts. It will sit 2-4 weeks without being started then get driven 30-100 miles on a weekend day cruising around.
2. Can/Should I switch to full Syth like 0w-40 M1 that I run in my other VWs?
3. Are there risks to switching?
Thanks!
Re: 1990 VW 1.8L - Need advice [Re: ReadTheBook] #4725709
04/13/18 11:46 AM
04/13/18 11:46 AM
Kevil,Ky
vwmaniaman Offline
vwmaniaman  Offline
Kevil,Ky
I have a 1987 VW Cabriolet that we use like you do but did do a recent trip to Florida. Ours has around 187K on it and still uses no oil. I run Rotella T and a Mann filter The oil is 15-40. Getting 30-34 mpg even running the AC. It is a great little car that we bought in Phoenix. Be sure to replace that timing belt if it has not been done. if it is 18 years old it is probably ready.. Not a hard job if you like wrenching on it.
Don't waste your time on a slipshod repair.
Re: 1990 VW 1.8L - Need advice [Re: ReadTheBook] #4725752
04/13/18 12:40 PM
04/13/18 12:40 PM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
Castrol GTX once a year is all you need.
"Zed's dead baby, Zed's dead."
Re: 1990 VW 1.8L - Need advice [Re: ReadTheBook] #4725774
04/13/18 12:56 PM
04/13/18 12:56 PM
Phoenix, AZ
Nick1994 Online content
Nick1994  Online Content
Phoenix, AZ
20w50 sounds awfully thick for your environment. Id use a 10w40 and change it once a year.
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: 1990 VW 1.8L - Need advice [Re: ReadTheBook] #4725786
04/13/18 01:09 PM
04/13/18 01:09 PM
California
nthach Offline
nthach  Offline
California
Those old German motors love viscosity, 20W-50 is fine but I prefer a 15W-40 diesel engine oil for a stouter add pack. Even though the latest Delo/Delvac/Rotella CK-4/SN rated oils have less Zn/P than their CJ-4/SM(L), there's still more than your typical 20W-50 oil which uses the same add pack as an ILSAC-compliant oil but is much less volatile than a xW-20/30.
I'd use Delo, Delvac or Rotella if were you. I doubt your MKII VW is going to Tahoe or up Diablo/Hamilton in the winter - you can get away with 20W-50 as well. But 15W-40 is more of a sweet spot between MPG, protection and easy starting when it gets cold.
Re: 1990 VW 1.8L - Need advice [Re: Nick1994] #4725790
04/13/18 01:13 PM
04/13/18 01:13 PM
North Carolina
North Carolina
And what exactly are you basing that on?
There it is. 20W-50 is what you need unless it will regularly see sub-freezing temperatures. GTX is the classic choice, but nearly any 20W-50 once a year would work well.
I ran M1 15W-50 in my G60 swapped Cabriolet.
Re: 1990 VW 1.8L - Need advice [Re: ReadTheBook] #4725930
04/13/18 03:59 PM
04/13/18 03:59 PM
North Carolina
North Carolina
Re: 1990 VW 1.8L - Need advice [Re: rooflessVW] #4725971
04/13/18 04:50 PM
04/13/18 04:50 PM
Phoenix, AZ
Phoenix, AZ
Ok, Ill change that to 15w40, according to your link
Quote:
This can be quite controversial; positive and negative comments are said about all oil types and brands. Most agreed upon, however, is using 20W-50 in the warm summer months and 10W-30 in the cold winter months, or 15W-40 year-round (those in year-round warm climates can use 20W50 year-round)
It doesnt get that warm in San Francisco. If it needs 20w50, then VWs cylinder clearances must be like shooting pool with a rope.
Re: 1990 VW 1.8L - Need advice [Re: rooflessVW] #4726004
04/13/18 05:31 PM
04/13/18 05:31 PM
Bay Area, CA
Bay Area, CA
Thanks for the responses. Ill stick to once a year and look for a 15w-40.
I do know about cabby info, but thanks for that..
Re: 1990 VW 1.8L - Need advice [Re: Nick1994] #4726384
04/14/18 01:38 AM
04/14/18 01:38 AM
California
nthach Offline
nthach  Offline
California
Buslab in Berkeley recommends O'Reilly(WPP, same as SuperTech and Service Pro) 20W-50 for the Wasserboxers in the Vanagons. San Francisco proper is colder than Oakland/Berkeley but the Bay Area once you pass through the Caldecott or north/south of Oakland/SF can get hot in the summertime. A lot of Mercedes and BMW shops as well as the dealer pumped in Castrol or Valvoline 20W-50 as default in the 1980s-1990s, I remember an old 420SEL Benz my family had saw nothing but Pennzoil Multi-Vis 20W-50 until I switched over to Delo 400 when I was starting to wrench.
For some reason like I said the Germans love thick oil, while Toyota and Honda specified 10W-30/40 back then. Now with 0W-XX making its way at BMW/VAG/Daimler, things have changed. I still wouldn't use anything API SM/SN single-rated in a 80-eras Euro car.
Re: 1990 VW 1.8L - Need advice [Re: ReadTheBook] #4726394
04/14/18 02:29 AM
04/14/18 02:29 AM
Balearic Islands , Spain
FordCapriDriver Offline
20W-50 is fine for it but i would use Shell Rotella T5 15W-40, a syn blend HDEO with 1200-ish ppm of Zddp ( assuming it has a flat tappet cam ? )even if it's a fairly tame cam a little extra Zddp is never a bad thing with flat tappets.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort XR3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Re: 1990 VW 1.8L - Need advice [Re: nthach] #4726395
04/14/18 02:34 AM
04/14/18 02:34 AM
Most German, British and Italian cars up until the early 80s used 20w50 as default.
and 10w40 was probably the most common recomended grade until the early 2000s.
Re: 1990 VW 1.8L - Need advice [Re: ReadTheBook] #4726419
04/14/18 05:40 AM
04/14/18 05:40 AM
North Carolina
North Carolina
Right, and we're talking about an engine that didn't change much at all from it's initial design - in the 70s.
You can run a 15W-40, but don't be surprised if your oil light flickers at hot idle in 90 weather.
It's just the name of the game - these engines take a 20W-50, as you saw indicated in your Bentley manual. If I still had mine I'd flip through the owner's manual and show you the same chart.
Re: 1990 VW 1.8L - Need advice [Re: ReadTheBook] #4726425
04/14/18 06:03 AM
04/14/18 06:03 AM
My Capri's Essex V6 engine ( designed in 1965 ) on a hot 100F summer day will barely, just barely have enough oil pressure on a 10w40 at hot idle, on a 20W-50 Dino it's happy at 1/4 of the way up the o.p gauge at idle.
It recomends 20W-50 for my climate, so can't say the manual is wrong.
