Air Fryer....whose got'em?
by Schmoe. 01/16/19 01:59 PM
ebates - anyone a member?
by Papa Bear. 01/16/19 01:29 PM
Ordered a 2019 X5 for the Wife
by gofast182. 01/16/19 12:48 PM
Today, I ride
by SirTanon. 01/16/19 12:02 PM
2019 Nissan Rogue SL
by JTK. 01/16/19 11:19 AM
Does GM oil life monitor % go down without driving?
by Corollaman. 01/16/19 10:37 AM
Ford tire wear issues?
by Redright9. 01/16/19 10:23 AM
New Battery
by CarlGR. 01/16/19 10:21 AM
It's January and I Need My Motorcycling "Therapy" !!
by LoneRanger. 01/16/19 10:13 AM
Are New Vehicles Too Expensive?
by SubLGT. 01/16/19 10:02 AM
Manual transmission fluid in Europe for Mazda
by zsero. 01/16/19 07:31 AM
Affected by the gov't shutdown?
by xBa380. 01/16/19 07:04 AM
Opinion Needed / 1998 Olds 88
by Mark72. 01/16/19 06:24 AM
Chevron Supreme color change
by OilUzer. 01/16/19 05:14 AM
Dual exhaust benefits
by OilUzer. 01/16/19 03:02 AM
M1 0w40
by Pinoak. 01/16/19 01:55 AM
M1 0w40
by Pinoak. 01/16/19 01:51 AM
The best in personal defense (Humor)
by StevieC. 01/15/19 11:10 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
97 registered members (240_Ed, AandPDan, 97f150, advocate, anndel, 2015_PSD, 11 invisible), 2,260 guests, and 30 spiders.
Topics296,643
Posts4,956,486
Members66,950
Most Online2,577
Jan 14th, 2019
My Garage Door Spring Has Sprung #4725423
04/13/18 06:33 AM
04/13/18 06:33 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Well, I am locked in my garage. The spring on my Clopay garage door is split in two and I cannot physically lift the door. That spring has a lot of tension on it!
What do I do next?
I guess I could start removing panels.
'98 LEX LS400 280K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 60K
Amsoil in all engines, transmissions and differentials
Re: My Garage Door Spring Has Sprung [Re: Gebo] #4725434
04/13/18 06:42 AM
04/13/18 06:42 AM
New England
Virtus_Probi Offline
New England
Get some strong friends to help?
This happened to my dad's wooden single door, he was elderly and could not lift it and neither could my sister, but I lived nearby and was able to raise it and prop it open for him. His sister's boyfriend had been a garage door installer and put a new spring in for him, but it was actually too strong and it was sometimes hard to get the door down all the way! I think my dad told me the broken spring lashed the top of his Marquis, but didn't expose any metal and he was really happy that it didn't shatter any glass.
2014 Forester XT, 95000 miles
Last Change;
M1 0W30 AFE d1G2
Tokyo Roki 15208AA170 filter
Re: My Garage Door Spring Has Sprung [Re: Gebo] #4725435
04/13/18 06:42 AM
04/13/18 06:42 AM
Ohio
Dave Sherman Offline
Ohio
Does it have an electric opener? I once had the same situation and used the electric opener while lifting by hand to get it open.
If there's no electric opener, maybe try a pry bar or shovel and carefully lifting it enough to get a floor jack under it to help it up. Once the upper panel is horizontal it should be lighter.
2015 Honda Pilot EX AWD Valvoline 0W-20 Bosch filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: My Garage Door Spring Has Sprung [Re: Gebo] #4725436
04/13/18 06:43 AM
04/13/18 06:43 AM
Alberta
tcp71 Offline
tcp71  Offline
Alberta
Pry a longer 2x4 under the door. Use it as a lever to lift the door, then prop ever longer pieces of 2x4 under each side of the door until it is high enough to drive the vehicle(s) out. Then call an overhead door company to replace the spring. Wonít be too expensive. Itís not an uncommon failure.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: mobil 0w40 (varies)
Re: My Garage Door Spring Has Sprung [Re: Gebo] #4725437
04/13/18 06:44 AM
04/13/18 06:44 AM
Chicago,IL,USA
pandus13 Offline
pandus13  Offline
Chicago,IL,USA
pictures?
Are they torsion springs (on a big pipe in kind of front upper of door) or tension springs (two on the upper sides of door)?
are you having back problem or is this a wooden/insulated steel double door (120+ #s)?
If you didn't did this before, call a garage door guy.
I did it , but I could lift the door: in steps, about 2 feet at a time, and place something under to hold in place (clamps on both side of track would be best or something wide like 5gallon paint buckets with lids on, stacked).
DO NOT USE JUST A 2x4, wood board: too much weight in one tiny spot.
Do you have somebody to help you?
If not, again, just call a garage door guy.
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
Re: My Garage Door Spring Has Sprung [Re: Gebo] #4725525
04/13/18 08:02 AM
04/13/18 08:02 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Got a helper. Door is up and stable. Here is the pic of the broken spring and another pic of the good one. What type of spring would you go back with? They have this EZ spring kit from Clopay in addition to the regular spring like this one. There are no Clopay dealers other than Home Depot near me. It's a Clopay 4050 with either SN 1012947599 or 1012947598
'98 LEX LS400 280K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 60K
Re: My Garage Door Spring Has Sprung [Re: Gebo] #4725527
04/13/18 08:03 AM
04/13/18 08:03 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Replacing a torsion spring on a garage door is best done by the garage door guy. There are lots of other do-it-yourself projects to concentrate on that donít have the same potential to hurt yourself.
If you want the job done right......do it yourself.
Re: My Garage Door Spring Has Sprung [Re: Gebo] #4725546
04/13/18 08:22 AM
04/13/18 08:22 AM
NC
ruhroh Offline
ruhroh  Offline
NC
That's a torsion spring. Replace with the same spring though doesn't have to be from the same manufacturer. You'll need to measure the inside diameter, spring thickness - better estimated by counting 20 or so coils then dividing by the number of coils you've counted, spring direction, and total length. Check out a youtube video if you're not sure how. The last 36" replacement spring I ordered cost about $40 on amazon.
Re: My Garage Door Spring Has Sprung [Re: Snagglefoot] #4725549
04/13/18 08:25 AM
04/13/18 08:25 AM
Chicago,IL,USA
pandus13 Offline
pandus13  Offline
Chicago,IL,USA
while there are dyi guides and youtube videos, and even the formulas for what springs and how many turns,
This is the time I would leave it to pros.
Also there is a good chance they may get the springs quicker than you.
If you do it, take your time, and don't use screwdrivers.
use freshly FLAT cut and grounded rods.
use 2 locking pliers as your safety stoppers.
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
Re: My Garage Door Spring Has Sprung [Re: Gebo] #4725572
04/13/18 08:38 AM
04/13/18 08:38 AM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
There are a lot of garage door company that can come the same day or next day.
It is probably cost around $200 - $250 for a pro to do it.
Yes, it is kind of dangerous and you need a set of tool to wind the spring back on.
It usually breaks every 15 years or so.
  • 2017 Toyota Sienna
Re: My Garage Door Spring Has Sprung [Re: Gebo] #4725586
04/13/18 08:54 AM
04/13/18 08:54 AM
alabama
wayne50 Offline
wayne50  Offline
alabama
I had both torsion springs replaced recently for an 18 ft. wide wooden door. The cost was $220.
Re: My Garage Door Spring Has Sprung [Re: Gebo] #4725591
04/13/18 08:56 AM
04/13/18 08:56 AM
St. Charles County, Missouri
csandste Online content
csandste  Online Content
Same advice here. Had a broken spring and had a pro out in an hour or so at a cost under $200. I'm not overly handy but even if I was I wouldn't tackle this one. Getting a spring lodged in your eye socket might be painful.
2017 Kia Soul Plus-- VWB 5-30, 54,000 miles.
Re: My Garage Door Spring Has Sprung [Re: wayne50] #4725623
04/13/18 09:25 AM
04/13/18 09:25 AM
Charlotte, NC
Oldmoparguy1 Offline
Charlotte, NC
Good price.
I have an 10'X18' commercial steel door on my workshop. One of the 2 springs broke last fall. going to get it repaired next week. Door was installed in 1972, so needs some repairs. New lift cables, new rollers, and an a insulation package. All in all, about $1k. I raised my door a few inches with an old fashioned bumper jack, just enough to get my engine hoist legs under the door, then lifted the door just pass the half way point, at that point the electric opener was able to open it the rest of the way.
A Randomly Selected Thought For The Day:
If Noah had used Zip, he could have used a smaller boat.
Re: My Garage Door Spring Has Sprung [Re: Gebo] #4725632
04/13/18 09:31 AM
04/13/18 09:31 AM
Illinois
javacontour Offline
javacontour  Offline
Illinois
I DIY'ed this job on a 18' wide door for ~$70-80 and an hour of my time. I bought the winding rods and two springs at Menards which is figured in the price quoted above.
Not hard at all and less dangerous than swapping springs and struts on your car.
But if you don't feel confident after watching any number of YouTube videos showing how to do it, by all means, hire out the job.
network down, IP packets delivered via UPS -BOFH
Re: My Garage Door Spring Has Sprung [Re: Gebo] #4725645
04/13/18 09:42 AM
04/13/18 09:42 AM
nh
judsonj Offline
judsonj  Offline
nh
I totally agree with having a pro do it. When one of mine broke the guy came in less than an hour and replaced it and also safety wired all four springs so if they broke they wouldn't go flying like this one did. Cost me less than $200.
