Boiler/baseboard valve corrosion
by wormwood1978. 01/18/19 09:24 AM
Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
(NEW) STP S3675 Cut Open
by rooflessVW. 01/17/19 10:00 PM
Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
88 registered members (14Accent, 240_Ed, 97f150, Al, 69GTX, Alfred_B, 4 invisible), 2,003 guests, and 60 spiders.
Topics296,776
Posts4,958,684
Members66,969
Most Online2,577
Jan 14th, 2019
Page 1 of 3 1 2 3
Best oil for Honda EU7000IS Generator #4725421
04/13/18 06:31 AM
04/13/18 06:31 AM
NY
Oilnewb1 Offline OP
Oilnewb1  Offline OP
NY
Hey guys, I'm located in climate zone 5 where our temperatures range from -10F to 100F. I'm a little confused as to which oil I should run year round. My intentions were to use the Honda Power Equipment oil which is designed for small engines however, it is not synthetic so I was considering running 10w30.Am I better off running Honda non-synthetic 5w30 year round?
Also, should I switch to synthetic after the first oil change or is it better to just stick with the Honda 4cycle oil? If I do switch to synthetic, is it safe to switch to 5w30 at this time as I understand synthetic 5w30 has a much broader temle range than Dino 5w30
Which brand of synthetic do you guys recommend? I know a lot of you to say stick with small engine oils and not automotive such as Amsoil 4 stroke but this particular generator has a catalytic converter so I don't know how that affects things.
I understand that using 5w30 in winter and 10w30 in summer is ideal but it's not practical for an item that gets used infrequently and needs to be ready at a moments notice.
The generator is stored in my garage that stays around 40F but I'm assuming that may be irrelevant if it was outside for a few minutes before starting in sub-zero weather or when doing an oil change. The generator dealer I purchased from recommended 5w30 for year round use but I'm concerned about it being inadequate for the hotter months when it easily pushes up over 90.
I appreciate the information!
Re: Best oil for Honda EU7000IS Generator [Re: Oilnewb1] #4725450
04/13/18 06:52 AM
04/13/18 06:52 AM
Ohio
Dave Sherman Offline
Ohio
If you're after synthetic, go with Rotella T5 10W-30. Heavy duty engine oil is a popular choice for air cooled small engines. Could go with Rotella T6 5W-40, I run that in my generator year round.
2015 Honda Pilot EX AWD Valvoline 0W-20 Bosch filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: Best oil for Honda EU7000IS Generator [Re: Oilnewb1] #4725470
04/13/18 07:15 AM
04/13/18 07:15 AM
California
MadAmos Offline
MadAmos  Offline
California
I have been using Mobil 1 10w-30 mine is stored in my barn and sees 20-110 degrees F runs great and never uses any oil with 50 hour changes.
2000 Ford F250 7.3
1999 Miata
2014 Cadillac ELR
2017 Cruze RS Hatchback 6MT
Re: Best oil for Honda EU7000IS Generator [Re: Oilnewb1] #4725496
04/13/18 07:37 AM
04/13/18 07:37 AM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
From the owners manual for your temperature range, Honda specs 10w30 and should meet SJ or higher specs. That would mean SN which has superseded SJ. Synthetic is a great choice. There are excellent offerings from all the major oil producers. The container should say SN on the SPE symbol and the word synthetic. Want a name? How about Pennzoil Platinum but theyíre are lots of others.
I donít want to start anything here but the people from Honda are pretty smart and I donít see why you would want to bother stray from their recommendation.
An automotive oil is fine. Rotella T-5 Is not SN rated. There is a Rotella T6 SN rated 10W-30.
If you want the job done right......do it yourself.
Re: Best oil for Honda EU7000IS Generator [Re: Oilnewb1] #4725524
04/13/18 08:01 AM
04/13/18 08:01 AM
wi
dave123 Offline
dave123  Offline
wi
Amsoil Small engine oil
Re: Best oil for Honda EU7000IS Generator [Re: Snagglefoot] #4725545
04/13/18 08:21 AM
04/13/18 08:21 AM
NY
Oilnewb1 Offline OP
Oilnewb1  Offline OP
NY
So you guys think it's safe to use 10w30 year round as long as the generator and oil are stored in my garage which never goes below 40 degrees regardless of how cold it is outside?
Am I better off just sticking with the Honda Power Equipment oil even though it's not synthetic? Thanks.
Re: Best oil for Honda EU7000IS Generator [Re: Oilnewb1] #4725553
04/13/18 08:26 AM
04/13/18 08:26 AM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
I run T6 5W40 year round as well in my generator, but I also buy it by the pail for the Tractor and ATV and anything else that needs oil except my DD's.
07 Focus ZXW, 5spd manual, 218km M1 5W30
18 Outback 2.5 CVT 15km 0W20
Re: Best oil for Honda EU7000IS Generator [Re: Oilnewb1] #4725573
04/13/18 08:41 AM
04/13/18 08:41 AM
Yes, 10w30 is perfectly fine in the conditions you describe. Also, youíll probably never wear out that generator so itís almost a moot point. The Honda Power Equipment oil is fine in my opinion.
Re: Best oil for Honda EU7000IS Generator [Re: Oilnewb1] #4725574
04/13/18 08:41 AM
04/13/18 08:41 AM
wi
dave123 Offline
dave123  Offline
wi
Absolutely
Re: Best oil for Honda EU7000IS Generator [Re: Oilnewb1] #4725598
04/13/18 09:01 AM
04/13/18 09:01 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
Mobil 1, 10W-30 will easily meet the needs of that engine in nearly all temperatures. As will any synthetic 5W-40 diesel oil, such as Mobil 1, 5W-40 Turbo Diesel Truck.
Both oils will flow at 30-40 below zero, so there will not be any issue with your location and cold weather performance. For any generator, a few minutes warm up at zero load is always nice to the engine.
By the way, that generator has an excellent engine, known to last decades with reasonable maintenance.
Re: Best oil for Honda EU7000IS Generator [Re: Oilnewb1] #4725606
04/13/18 09:08 AM
04/13/18 09:08 AM
NY
Oilnewb1 Offline OP
Oilnewb1  Offline OP
NY
Thanks for all the input. How long would you guys recommend running on the Dino oil before switching over to synthetic?
Re: Best oil for Honda EU7000IS Generator [Re: Cujet] #4725611
04/13/18 09:13 AM
04/13/18 09:13 AM
Agree. Mobil 1, 5-40 Turbo Diesel Truck oil is SN rated. Since the OP wantís to preserve his catalytic converter he should make sure any choice of a diesel oil is SN rated as some arenít.
Re: Best oil for Honda EU7000IS Generator [Re: Oilnewb1] #4725624
04/13/18 09:25 AM
04/13/18 09:25 AM
NY
Oilnewb1 Offline OP
Oilnewb1  Offline OP
NY
Since the owner's manual states using 5w30, 10w30,or straight 30, I'd probably rather stick to those. At least during the warranty period.
Is there any harm in me using the 5w30 over 10w30 and when should I make the switch from Dino to synthetic? Thanks a lot!
Re: Best oil for Honda EU7000IS Generator [Re: Oilnewb1] #4725628
04/13/18 09:27 AM
04/13/18 09:27 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
I believe in using a high quality syn oil of sufficient viscosity, and changing OPE oil by hours only. Modern synthetic oils, especially diesel oils, have a high TBN (total base number) and effectively prevent acid formation for many, many years in seasonally used gasoline engines.
I use 5W-40 TDT in my Kawasaki powered water pump (and many other engines) here in South Florida. I use M1, 15W-50 in my Subaru powered generator, which gets operated at 100% load for days at a time after hurricanes, heating water and running the central AC.
I see no need for seasonal or yearly oil changes with low hour utilization. It's the combustion byproducts that contaminate the oil, which happens only with sufficient use. Once broken in, 100 hour oil changes are just fine.
As far as "harm" with oil choice, I tend to choose the highest viscosity that is practical here in South Florida (failure to do so has resulted in extensive failures) . Remember, viscosity is what protects your engine. The higher quality synthetics all flow well at cold temps, with M1, 5W or 10W 30 won't matter, as they are nearly identical. High HTHS (viscosity at elevated temps, 150 degC ) is important in air cooled engines operated in high temps. And this is where the choice of a good synthetic will help.
Re: Best oil for Honda EU7000IS Generator [Re: Oilnewb1] #4725669
04/13/18 10:07 AM
04/13/18 10:07 AM
I noticed the owners manual is not definitive on the change over temp. Thereís no harm in using 5-30 but Honda is clear that 10-30 is preferred unless you have cold temps. If you were planning on starting the generator at -20 F then by all means use 5w30. Edit: Your owners manual says first oil change should be 20 hrs or one month. Subsequent changes, every 100 hours, but some folks recommend every 50 hours. You can decide that.
Page 1 of 3 1 2 3
