Hi everyone,
My idle isn't as smooth as it should be.
I have replaced the usual culprits and have done all the usual tests with no result.
Would the best option be to take the car to a mechanic who has an oscilloscope to diagnose this?
Car is a 2003 Mitsubishi Diamante.
Items replaced:
Fuel filter, injectors serviced, ignition module, spark plugs, spark leads, distributor cap and button
Tests conducted:
Compression test, vacuum test, vacuum leak test, ECU and all sensor test (all sensors reading within normal parameters)
Items replaced:
Tests conducted:
