A neighbor of mine used an automotive-type oil in his ATV and now he has slight clutch slippage. Will the glaze wear off over time? Is there any other solution besides new clutch plates?
It's a late model Suzuki that has separate holes for engine, gearbox, and clutch. I don't know the extent of the slippage. He say's its liveable for now. So If I'm hearing you guys correctly, it isn't the friction modifier that is the glaze, it simply creates the conditions for slippage thereby causing the glaze?quote:
Originally posted by wileyE:
what kind of atv? sometime the baskets are adjustable for plate wear, springs can get weak, cable mis adjusted could be pulling when the bars are turned, many reasons it could be slipping.
Is it worse when it's hot? Do the plates break loose well with the clutch engaged, does it snick from N to 1st, or clunk with the bike nudging forward?
Do you even realize that Mobil's Motorcycle oils and 'some' other brands of motorcycle oils DO in fact contain moly?quote:
Originally posted by KBFXDLI:
If your friend used an automotive engine oil with moly in it that is what the glaze is. Oil with moly additives should never be used in a wet clutch. Lots of people get away with it but those clutch plates are trashed. You'll never get the moly coating off without ruining the plates. IMO
Mobil1Vtwin, Amsoil, HD Syn3 and Redline 20w50 contain no moly. Go check the researchquote:
Sorry, but you are the FUD...the use of moly in wet clutch applications is only done by people who spend lots of cash on expensive bikes then cheap out on the oil because they don't understand the difference in additive packages. Ask ANY Amsoil guy on this forum. OR better yet go live at WalMart where you came from.quote:
Originally posted by Blake Sobiloff:
Ignore KBFXDLI's FUD--there is no empirical evidence that the moly used in modern oils causes a healthy clutch to slip.
I have done some research on this and you're simply wrong again and again and your credibility is quickly disappearing. For the last year or so, Mobil’s motorcycle oils have contained moly in the add pack. ‘Bob’ the oil guy is also a motorcycle enthusiast and the oil he uses and recommends to everyone contains moly. There are many oils out there for motorcycles that DO in fact contain moly and you don’t have to look far to find this information. Rather than me posting my own VOA's, I'll just reference the VOA's that have already been posted here on BITOG. Here's a VOA Mobil MX4T, which is their motorcycle oil and it clearly shows it contains moly in the add pack.quote:
