Is This Possible?
CCI
New Mexico USA
GMC Vortec 5.7, 16 years old, 155K miles.
Coolant has never been changed, system has never been flushed until today.
Could a coolant system flush and fresh coolant make the truck run smoother?
Possible. Especially if the old coolant lost it's pH balance.
Coolant contains additives called buffers that keep it at a neutral pH. When these chemicals become depleted, the pH can’t be controlled. This is not a gradual process. The pH rises dramatically in a short period of time the moment the buffers are fully depleted. This is when replacing the coolant at the recommended interval is critical.
Coolant flush can't hurt. especially at that age. May or may not improve the smoothness.
I'd be looking at vacuum lines and intake gaskets. A little pirate air can make a big difference in how nicely an engine runs.
Clean throttle body and idle air control valve (IACV), if present.
If plugs are old, clean, check gaps, and replace if needed.
Run a few tanks of fuel system cleaner and change fuel filter if not done recently.
Are you getting a general roughness, or is there more of a distinct miss under certain conditions?
Increased electrical conductivity of old coolant can mess with electrical sensors on your engine. That could be why it runs smoother with the new coolant.
Water pump is original, fuel filter and plugs were changed at 120K, bottle of Techron prior to last fill up, truck was running OK for its age. Not my truck, owner is pro driver with CDL-A, this truck has the original U-joints and brake pads and it gets worked.
Owner reported after very long overdue coolant flush yesterday that the truck runs smoother. I thought, well, anything is possible, I don't know why, but I certainly know where to ask. Thank you all for your responses!
What did the effluent look like? Lots of crud?
Might have been localized hot spots, not near enough to the knock sensor to retard timing?
Might just be a coincidence, too
As a rule, it won't necessarily make it run smoother..
.. but it will very likely end up making it last longer.
As others have said, though, if the coolant was in REALLY bad shape, crudded up, etc.. and causing hot spots, or making the thermostat stick open and causing the engine to run colder than it should, then yeah.. a coolant flush and refill could help it run better.
