New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
I need a filter cutter person
by Marco620. 03/24/19 03:21 PM
VIRGIN BOSCH D+ 3421 CUT OPEN
by 53' Stude. 03/24/19 02:45 PM
My first cut. Donaldson P502503
by BeerCan. 03/24/19 02:25 PM
Sludge and Facebook's infinite wisdom
by RDY4WAR. 03/24/19 02:05 PM
Gear lube 75W90 Synthetic GM# 88900401
by rcbob. 03/24/19 01:47 PM
Rislone Rebates
by Nickdfresh. 03/24/19 01:42 PM
IndyCar Classic at COTA
by bdcardinal. 03/24/19 12:29 PM
STP 500 at Martinsville
by bdcardinal. 03/24/19 12:27 PM
Source For Microfiber Towels
by Wrenchturner44. 03/24/19 12:26 PM
SUPREME C3-X SYNTHETIC 5W-30
by 21Rouge. 03/24/19 12:17 PM
Jcountry, CMichael, dude59, Petrolhead, stp
67608 Registered Users
107 registered members (ArrestMeRedZ, addyguy, 2004tdigls, arowbat, 2002 Maxima SE, 10 invisible), 2,213 guests, and 62 spiders.
Topics286,351
Posts4,906,907
Members67,608
Most Online2,967
Mar 10th, 2019
Is This Possible? #4725161
04/12/18 09:05 PM
04/12/18 09:05 PM
New Mexico USA
CCI Offline OP
CCI  Offline OP
New Mexico USA
GMC Vortec 5.7, 16 years old, 155K miles.
Coolant has never been changed, system has never been flushed until today.
Could a coolant system flush and fresh coolant make the truck run smoother?
Re: Is This Possible? [Re: CCI] #4725168
04/12/18 09:09 PM
04/12/18 09:09 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Maybe, but it must be linked to a previously partially blocked coolant passage ... Hot spot will cause a engine to run odd ...
Re: Is This Possible? [Re: CCI] #4725176
04/12/18 09:13 PM
04/12/18 09:13 PM
Canada
Lolvoguy Offline
Lolvoguy  Offline
Canada
Possible. Especially if the old coolant lost it's pH balance.
Coolant contains additives called buffers that keep it at a neutral pH. When these chemicals become depleted, the pH canít be controlled. This is not a gradual process. The pH rises dramatically in a short period of time the moment the buffers are fully depleted. This is when replacing the coolant at the recommended interval is critical.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Is This Possible? [Re: CCI] #4725194
04/12/18 09:25 PM
04/12/18 09:25 PM
New England
gathermewool Online content
gathermewool  Online Content
New England
Is it not runn g smoothly now?
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: Is This Possible? [Re: CCI] #4725205
04/12/18 09:39 PM
04/12/18 09:39 PM
Texas
4WD Offline
4WD  Offline
Texas
Original water pump?
Re: Is This Possible? [Re: CCI] #4725238
04/12/18 10:29 PM
04/12/18 10:29 PM
California
VeryNoisyPoet Offline
California
Coolant flush can't hurt. especially at that age. May or may not improve the smoothness.
I'd be looking at vacuum lines and intake gaskets. A little pirate air can make a big difference in how nicely an engine runs.
Clean throttle body and idle air control valve (IACV), if present.
If plugs are old, clean, check gaps, and replace if needed.
Run a few tanks of fuel system cleaner and change fuel filter if not done recently.
Are you getting a general roughness, or is there more of a distinct miss under certain conditions?
1998 V70 GLT / 202k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: Is This Possible? [Re: CCI] #4725273
04/12/18 11:25 PM
04/12/18 11:25 PM
Kentucky
Fsharp Offline
Fsharp  Offline
Kentucky
Increased electrical conductivity of old coolant can mess with electrical sensors on your engine. That could be why it runs smoother with the new coolant.
Re: Is This Possible? [Re: Fsharp] #4725378
04/13/18 06:42 AM
04/13/18 06:42 AM
New Mexico USA
CCI Offline OP
CCI  Offline OP
New Mexico USA
Water pump is original, fuel filter and plugs were changed at 120K, bottle of Techron prior to last fill up, truck was running OK for its age. Not my truck, owner is pro driver with CDL-A, this truck has the original U-joints and brake pads and it gets worked.
Owner reported after very long overdue coolant flush yesterday that the truck runs smoother. I thought, well, anything is possible, I don't know why, but I certainly know where to ask. Thank you all for your responses!
Re: Is This Possible? [Re: CCI] #4725678
04/13/18 11:14 AM
04/13/18 11:14 AM
New England
New England
What did the effluent look like? Lots of crud?
Might have been localized hot spots, not near enough to the knock sensor to retard timing?
Might just be a coincidence, too
Re: Is This Possible? [Re: CCI] #4725712
04/13/18 11:53 AM
04/13/18 11:53 AM
Phoenix, Arizona - USA
SirTanon Offline
SirTanon  Offline
As a rule, it won't necessarily make it run smoother..
.. but it will very likely end up making it last longer.
As others have said, though, if the coolant was in REALLY bad shape, crudded up, etc.. and causing hot spots, or making the thermostat stick open and causing the engine to run colder than it should, then yeah.. a coolant flush and refill could help it run better.
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 271,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 62,000mi
