Been without a accurate fuel gauge for quite a while. I was afraid to fix it because I thought it would mean a new pump and the hassle of dropping the tank.
To my surprise GM made a fuel pump access port in the trunk and the sensor can be bought alone.
The repair wasn't hard but the stupid rubber gasket was too thick to allow the fuel pump to go down far enough to twist the locking ring back down. We wasted a lot of time messing around and ended up putting the old one back on. Problem solved and gas gauge works!
