Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
22 registered members (billt460, Aero540T, ctechbob, dlundblad, avi1777, 2 invisible), 512 guests, and 57 spiders.
Topics286,171
Posts4,903,555
Members67,572
Most Online2,967
Mar 10th, 2019
1997 Chevrolet Cavalier low idle surging #4724996
04/12/18 06:44 PM
04/12/18 06:44 PM
USA
97prizm Offline OP
97prizm  Offline OP
USA
I'm back,
I fixed the coolant issue, it was a bad coolant cap,but now a biggie. Yesterday out of the blue I started the car turned it off then turned it back on. It started surging, low idle 5-600 rpm sometimes wouldn't rev above 4000 rpm. At first my dad thought a bad vacuum hose. I sprayed starter fluid all over, with no increase in rpm. I've heard the crank or throttle position sensor can go bad. All help would be great.
If at first you don't succeed fail fail again. (Waldorf and Statler.)
1997 Geo Prizm
1984 Mazda RX-7 Spec 7
Re: 1997 Chevrolet Cavalier low idle surging [Re: 97prizm] #4725002
04/12/18 06:55 PM
04/12/18 06:55 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
I just worked on a '97 last week - wouldn't idle at all. As soon as I started spraying carb cleaner down into the throttle body it started getting better, so I removed and cleaned it thoroughly which fixed it. Commsnded idle is very low, barely above 600 when warm.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: 1997 Chevrolet Cavalier low idle surging [Re: 97prizm] #4725446
04/13/18 07:48 AM
04/13/18 07:48 AM
Western Ma.
rollinpete Offline
rollinpete  Offline
Western Ma.
Could be your (IAC) idle air control valve. Here's a video on how to check it. (It may help) also you could try cleaning your maf sensor. Good Luck.
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive187k miles
03 Saturn Ion 2.2 L4 5spddrive238K miles
PPHM 5w30 and Fram Ultra x 2
Currently under the influence of oil shocked2
Re: 1997 Chevrolet Cavalier low idle surging [Re: 97prizm] #4725559
04/13/18 09:29 AM
04/13/18 09:29 AM
USA
mk378 Offline
mk378  Offline
USA
When you put it in gear and are moving, does it drive OK?
"won't rev over 4000 rpm" is not the IACV.
Re: 1997 Chevrolet Cavalier low idle surging [Re: 97prizm] #4725924
04/13/18 03:49 PM
04/13/18 03:49 PM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
A clogged injector can cause surging, hesitation, etc. Sounds like a fuel issue to me.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: 1997 Chevrolet Cavalier low idle surging [Re: 97prizm] #4726302
04/13/18 10:07 PM
04/13/18 10:07 PM
Florida
artificialist Offline
Florida
Failing ignition coil pack?
2010 Lancer Ralliart Sportback
Re: 1997 Chevrolet Cavalier low idle surging [Re: artificialist] #4726408
04/14/18 05:00 AM
04/14/18 05:00 AM
South Central PA (Fulton Co)
Delta Offline
Delta  Offline
If it's the 2.2 I would agree. Quite common on those engine.
'17 VW GTI 2.0T - 6MT - 14K - PPE 5w40
'15 Camry SE - 2.5 - 22K - PP 0w20
'99 S10 - 2.2 5MT - 159K - PP 10w30
