Remote Start by Android Auto App ?
by LoneRanger. 04/19/19 04:53 PM
Continental PureContact LS
by The Critic. 04/19/19 03:31 PM
Dark/Black Rear Differential Oil - UOA?
by The Critic. 04/19/19 03:25 PM
Best oil for Honda Rancher?
by jayjr1105. 04/19/19 03:20 PM
Store bought kimchi?
by Quattro Pete. 04/19/19 03:15 PM
2020 KIA Soul Turbo
by Malo83. 04/19/19 03:03 PM
erratic Speedometer
by tookien. 04/19/19 02:59 PM
Another airbag recall
by mclasser. 04/19/19 02:44 PM
Which barb fitting is less likely to leak?
by zorobabel. 04/19/19 02:36 PM
Can these bucket style tappets be reused?
by atikovi. 04/19/19 01:34 PM
Scratched My New Car. Help Me Fix
by GeorgeKaplan. 04/19/19 01:23 PM
Talk about manual labor...
by AZjeff. 04/19/19 12:42 PM
Car didn't burn an ounce of oil... 7K OCI
by jayjr1105. 04/19/19 12:13 PM
Top 6 OEM Passenger Tire Sizes in 2018
by SubLGT. 04/19/19 11:12 AM
CRC intake valve cleaner, safe to use?
by Backstache. 04/19/19 10:06 AM
'94 Grand Am Steering Column Pivot Pins
by benjamming. 04/19/19 10:02 AM
Why the need to replace suspension springs?
by WyrTwister. 04/19/19 09:47 AM
incorrect mileage on reciept
by 1978elcamino. 04/19/19 09:17 AM
Oregon PowerSharp for chainsaw
by Fitter30. 04/19/19 09:16 AM
new tire 4 years old
by 1978elcamino. 04/19/19 08:51 AM
carve200, Harteeco, fatafox, CurtC, LockCracker
67850 Registered Users
90 registered members (2015_PSD, 2009Edge, bdcardinal, bbhero, ArrestMeRedZ, 15 invisible), 2,130 guests, and 34 spiders.
Topics287,749
Posts4,933,806
Members67,850
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Would removing an oil filter hurt the gasket #4724741
04/12/18 01:35 PM
04/12/18 01:35 PM
CA, USA
paulri Online content OP
paulri  Online Content OP
CA, USA
What I really want to know is if doing this would hurt the oil filter gasketís ability to seal, if I wanted to drain the oil out, before putting that same filter back onto the engine block.
I read a bit about cold flow, and how the elastomer material in the gasket might deform (or conform to any irregularities), but I went out and looked at the gasket on one used oil filter (waiting for a trip to the local household hazardous waste), and another one on a new oil filter, and the gasket on the used oil filter actually looked flatter than the new one did. In other words, Iím not seeing any gross deformities that might make the old gasket bad to use, if I wanted to use that filter for a second OCI.
I'd rather not leave 6-plus ounces of oil in my filters (which would be the case if I were to drain the oil, but leave the filter on), but I'm thinking about draining the oil out of the filter, and then re-using it. However, I'd sure as heck hate to splatter oil gradually over 50-100 miles because of a leaking gasket.
2005 Toyota Sienna LE; 163,000 miles
2006 Toyota Highlander Hybrid 118,000 miles
Re: Would removing an oil filter hurt the gasket [Re: paulri] #4724743
04/12/18 01:37 PM
04/12/18 01:37 PM
San Rafael, CA
dogememe Offline
dogememe  Offline
San Rafael, CA
Once you bother removing the filter I really don't see the appeal of reusing the old one. When a filter costs from $2 to $10 depending on what you use, if you already took the time and made the mess removing the old one, just install a new one.
2010 Ford Escape 2.5 ~95K Miles
Royal Purple 5W-30 ~ Wix 51348
1995 Chevy Silverado 5.7 ~277K Miles
Delo 10W-30 ~ ACDelco PF52
Re: Would removing an oil filter hurt the gasket [Re: paulri] #4724752
04/12/18 01:53 PM
04/12/18 01:53 PM
NY
demarpaint Offline
demarpaint  Offline
NY
It can, although I've done it on occasion w/o issue. But I also installed said filter and didn't over tighten it the first time. I also check for leaks whenever I install an oil filter.
God Bless Our Troops
Re: Would removing an oil filter hurt the gasket [Re: paulri] #4724757
04/12/18 01:56 PM
04/12/18 01:56 PM
Canyon County Idaho
CT8 Online content
CT8  Online Content
Canyon County Idaho
Don't waste your time draining out the oil in the oil filter.
2015 F150 2.7
2018 F350 6.2
Re: Would removing an oil filter hurt the gasket [Re: CT8] #4724762
04/12/18 01:59 PM
04/12/18 01:59 PM
CA, USA
CA, USA
I wouldn't, except for the possibilities of sand. At this point that is the only thing that would make me think that I'd be better off removing the filter and then putting it back on.
Re: Would removing an oil filter hurt the gasket [Re: paulri] #4724766
04/12/18 02:04 PM
04/12/18 02:04 PM
MURICA
maverickfhs Offline
maverickfhs  Offline
MURICA
I have done it, just make sure gasket isn't deformed and it's sticking snug/tight on the oil filter.
Although, on my Civic I have re-used the filter without worrying about oil in the filter. Just drain and refill from the top.
Good Luck thumbsup
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: Would removing an oil filter hurt the gasket [Re: paulri] #4724768
04/12/18 02:06 PM
04/12/18 02:06 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
Are oil filters really the expensive?
Re: Would removing an oil filter hurt the gasket [Re: paulri] #4724772
04/12/18 02:09 PM
04/12/18 02:09 PM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
If you want to use the same filter, just leave it on. Don't take off the filter and out the same one back on.
If you remove the filter, get a new one. They are not that expensive smile
And I haven't been able to actually drain the filter without cutting it open anyway. Some filters even have an anti-siphon valve which prevents the oil from leaving the can.
Re: Would removing an oil filter hurt the gasket [Re: paulri] #4724798
04/12/18 02:32 PM
04/12/18 02:32 PM
CA, USA
CA, USA
Every filter I have taken off has liberally poured oil out onto my driveway, until I turned it back right side up. I'm pretty darn sure the filters for my cars will give up plenty of oil, if I were to turn them upside down.
Re: Would removing an oil filter hurt the gasket [Re: paulri] #4724804
04/12/18 02:36 PM
04/12/18 02:36 PM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
Considering how much oil is trapped up in the nooks and crannies of your typical engine, going the extra step of removing, draining and reinstalling a filter is somewhat pointless. It only adds to the mess and the time underneath your car. As said above, either leave it on or just replace it outright.
Re: Would removing an oil filter hurt the gasket [Re: paulri] #4724820
04/12/18 02:46 PM
04/12/18 02:46 PM
Cajun Country, La.
BlueOvalFitter Online content
BlueOvalFitter  Online Content
Cajun Country, La.
Find a NAPA store that sells a lot of parts to farmers. Said NAPA has a huge selection of o-rings behind the counter. When you remove the filter bring the old gasket/o-ring to match it up with a new one.
Wait, I think I have a better idea; just buy a new oil filter and replace the old oil filter. What an interesting concept! smirk
2007 F150, 4.2 V6
Havoline HM 5W20, NAPA GOLD FIL-1516 MC FL-400S
Re: Would removing an oil filter hurt the gasket [Re: paulri] #4724835
04/12/18 02:56 PM
04/12/18 02:56 PM
Canada
mcwilly Offline
mcwilly  Offline
Canada
If using a Fram Ultra I remove, inspect and drain the filter then use it for a second OCI.
But thats just me, nothing to do with cost, just because I can.
I've never seen anything wrong with the gasket or any other reason not to.
2010 Subaru Sti 74,000km
2001 Toyota Echo 245,000km
Re: Would removing an oil filter hurt the gasket [Re: mcwilly] #4724851
04/12/18 03:16 PM
04/12/18 03:16 PM
Parts Unknown
UG_Passat Offline
UG_Passat  Offline
Parts Unknown
What are you inspecting? You can't inspect the filter itself, unless it's a cartridge filter. Maybe you can see the ADBV if it's torn.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Would removing an oil filter hurt the gasket [Re: paulri] #4724879
04/12/18 04:00 PM
04/12/18 04:00 PM
Ruidoso, NM USA
ammolab Offline
ammolab  Offline
Ruidoso, NM USA
My wife over filled her motorcycle A LOT once. I removed the new filter to drain the excess about four times and reinstalled empty. That filter ran a year after that with no leak.
2009 Honda CR-V
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
Re: Would removing an oil filter hurt the gasket [Re: paulri] #4724892
04/12/18 04:16 PM
04/12/18 04:16 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Bad idea IMO. You have a chanxe of creating a leak by removing and re-using the filter.
Change the oil filter or leave it on for a second OCI. That small amount of old oil won't hurt anything.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Page 1 of 3 1 2 3
