Collective car nouns, real and imagined
by MrHorspwer - 07/04/20 08:44 AM
Motorcraft FL-820S, ~9000 miles
by robertcope - 07/04/20 08:42 AM
FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
2-year old oil 124 Spider
by DAC17 - 07/03/20 07:57 PM
New to us van
by ram_man - 07/03/20 07:22 PM
original '05 Chrysler trans pan gasket material ?
by visitor - 07/03/20 06:16 PM
rock auto can't ship to Calif????
by 928 - 07/03/20 06:04 PM
2001 Silverado 1500 T-Case Fluid
by Blang - 07/03/20 05:53 PM
Best style of condenser?
by ddeflyer - 07/03/20 05:17 PM
Advance Auto now selling Die Hard Batteries
by Kira - 07/03/20 05:01 PM
Ontario Nuclear update - Part 2
by OVERKILL - 07/03/20 04:36 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
95 registered members (2015_PSD, 2004tdigls, 4WD, aba4430, ABN_CBT_ENGR, andyd, 5 invisible), 1,683 guests, and 23 spiders.
Topics307,401
Posts5,310,426
Members71,843
2013 Dodge Ram Dually, w/6.7, what oil? #4724680 04/12/18 12:23 PM
sasilverbullet Offline OP
For a friend, did a search and couldn't find the answer...
2013 Dodge Ram Dually with the 6.7L cummins, he pulls a 40ft fifth wheel a lot!
What weight, type and oci would you guys recommend? Amsoil says a 5w-40. Oh, and he lives in New Jersey, but pulls all over the country...
03 Porsche 911 Driven DT-40 5w-40 & Mahle filter
14 Honda Accord 4dr EX-L 4cyl-M1 5W-30 & WIX
02 Chevy 5.7L van-GTX HM 10W-40 & WIX
Re: 2013 Dodge Ram Dually, w/6.7, what oil? [Re: sasilverbullet] #4724717 04/12/18 12:58 PM
Chris142 Online Content
Online Content
Rotella 5w40
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: 2013 Dodge Ram Dually, w/6.7, what oil? [Re: sasilverbullet] #4724719 04/12/18 12:59 PM
A
AlaskaMike Offline
A
If it were my truck for conventional oil it would be either Chevron Delo 400 or Rotella T 15w40. If I wanted synthetic it would be the 5w40 synthetic versions of the previous two brands. I'd be fine with Amsoil 5w40 as well.
For OCI, start with 5000 miles. If he wants to extend that, then lengthen as indicated by oil analysis.
Re: 2013 Dodge Ram Dually, w/6.7, what oil? [Re: sasilverbullet] #4724735 04/12/18 01:18 PM
Dodgetracker Offline
15w40 any brand that meets Cummins spec 20081 or 20086. Or any 5w40 or 10w30 that meets the same.
7500 OCI is what my manual states but I think newer trucks go 15000 or 6 months whichever happens first.
2008 Dodge Ram 2500 4x4 6.7 CTD 68RFE.
2004 Jeep Wrangler 4x4 4L Straight 6 Auto.
Re: 2013 Dodge Ram Dually, w/6.7, what oil? [Re: sasilverbullet] #4724742 04/12/18 01:35 PM
02SE Offline
Per an ex-Cummins engineer who is a member here, I'm running Rotella 5w40 or 15w40, in my '17 Dually which is used to pull a heavy 45' 5th wheel toy hauler. The manufacturers suggested OCI is 15k or 6 months, whichever occurs first. For the foreseeable future, I'll be doing oil changes based on time.
Re: 2013 Dodge Ram Dually, w/6.7, what oil? [Re: sasilverbullet] #4724793 04/12/18 02:26 PM
R
racin4ds Offline
R
Isn't there only "one" approved or "suggested" oil for use in the Cummins engines?
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
'13 Passat TDi SE+Nav
Re: 2013 Dodge Ram Dually, w/6.7, what oil? [Re: sasilverbullet] #4724838 04/12/18 02:59 PM
F
FermeLaPorte Offline
F
Mobil Delvac
Re: 2013 Dodge Ram Dually, w/6.7, what oil? [Re: racin4ds] #4724877 04/12/18 03:58 PM
B
bullwinkle Offline
B
That would be Valvoline Premium Blue Extreme 5W40, another excellent choice. Pretty much any big name HDEO in 5W40, 15W40, or even 10W30 would work just fine. I'm a pretty big fan of Mobil Delvac 1 ESP (& older non-ESP) 5W40-but the fact I picked up a pretty big amount of it from AZ for $1/quart a couple years back factors in to that!
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: 2013 Dodge Ram Dually, w/6.7, what oil? [Re: sasilverbullet] #4724973 04/12/18 06:13 PM
B
BrianF Offline
B
I am running PetroCan Duron 10w30 semi synthetic in mine. CES 20086 approved.
2006 Trailblazer LT. QSUD, Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30, Baldwin BT7349.
1993 GMC 1500. QSAD, Fram PH5
Re: 2013 Dodge Ram Dually, w/6.7, what oil? [Re: racin4ds] #4725740 04/13/18 12:27 PM
I
InhalingBullets Offline
I
It was Valvoline Premium BLue, but now in 2018 the owners manual says this:
Engine Oil Viscosity (SAE Grade)
In ambient temperatures above 0F (-18C), we recommend
you use SAE 15W-40 engine oil such as Mopar, Shell
Rotella and Shell Rimula that meets FCA Material Standard
MS-10902 and the API CK-4 engine oil category is required.
Products meeting Cummins CES 20081 may also be used.
The identification of these engine oils is typically located
on the back of the oil container.
In ambient temperatures below 0F (-18C), we recommend
you use SAE 5W-40 synthetic engine oil such as Mopar,
Shell Rotella and Shell Rimula that meets FCA Material
Standard MS-10902 and the API CK-4 engine oil category is
required.
'16 Toyota Prius 4
'15 Honda Accord Sport
'14 Victory Cross Country Tour
'13 Toyota Prius 3
Re: 2013 Dodge Ram Dually, w/6.7, what oil? [Re: racin4ds] #4753574 05/10/18 10:11 PM
L
LeeinDallas Offline
L
Valvoline Premium Blue 5w-40. No other oil has the Cummins endorsement and recommendation.
Re: 2013 Dodge Ram Dually, w/6.7, what oil? [Re: sasilverbullet] #4753578 05/10/18 10:15 PM
K
Killer223 Online Content
Online Content
K
any diesel rated oil of the correct grade for the climate you live. walmart oil is good, rotella, valvoline, any of them will be JUST FINE!!!
19 accord 6sp 2.0T
04 5.9 cummins
95 12V NV4500.
11 ranger 4.0
18 crf450RX
19 Talon
17 Pioneer 1k.
Re: 2013 Dodge Ram Dually, w/6.7, what oil? [Re: LeeinDallas] #4753975 05/11/18 09:25 AM
J
jayg Offline
J
Well, that they paid for on the bottle to make it more expensive. There are other oils that meet the Cummins 20086 spec that are often cheaper. Its just an endorsement. Thats like saying Gatorade is the official drink of MLB. If Ichiro drank a Powerade he would still be fine.
Heres a list of 40+ options.
http://lubritecinc.com/PDF/CES%2020086(2).pdf
And 20087 specs:
http://lubritecinc.com/PDF/CES%2020087C.pdf
Get the cheapest one thats synthetic and on sale.
2019 Toyota Prius E-AWD- TGMO 0w16
2017 Ram 1500 Ecodiesel- CP Triton ECT 5w40
1973 Datsun 240Z 10w30- VWC from '73
...and a bunch of old motorcycles
Re: 2013 Dodge Ram Dually, w/6.7, what oil? [Re: sasilverbullet] #4754557 05/11/18 09:06 PM
Dak27 Offline
I'd say Shell Rotella products, due to availability and pricing at Walmart stores across the U.S.. Walmart carries pretty much the full line of Rotella products, but not so much with Chevron Delo and Mobil Delvac products.
Rotella products are the "highest priced" of the "Big Three" brands at Walmart, but not by a wide margin, and they're still very reasonably priced compared the major auto parts store's pricing that I've checked.
Re: 2013 Dodge Ram Dually, w/6.7, what oil? [Re: Dak27] #4756146 05/13/18 05:48 PM
P
PiperOne Offline
P
I don't know about that. Just about every WalMart I go to (and I travel a lot) carries regular, syn blend, and full syn Delo (blue,grey and silver jugs) and many will carry all 3 in both gallons and 2.5 gal jugs.
HDEO in Diesel Engines. No spark plugs here.
