Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Pics - 2005 Highlander 3.3L 158k miles
by dkryan. 01/20/19 11:21 AM
Chinese nuclear momentum
by OVERKILL. 01/20/19 10:35 AM
Winter finally arrived
by StevieC. 01/20/19 10:27 AM
Octane rating of UL94 avgas
by Altydoc. 01/20/19 09:55 AM
Any bowlers out there?
by 53' Stude. 01/20/19 08:10 AM
Future of subcompact cars?
by Char Baby. 01/20/19 07:15 AM
Are u a roller coaster fan?
by ZZman. 01/20/19 07:03 AM
DUST - a couple of short Sci Fi films
by Shannow. 01/20/19 05:46 AM
5W30 Synthetic Oils With HTHS of 3.5 ?
by ChrisD46. 01/20/19 04:02 AM
White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Rob_from_Madison, SubieSTI, ebersvc, junk1020, fairparts99
66987 Registered Users
103 registered members (02z, 97f150, 53' Stude, 16 invisible), 2,314 guests, and 36 spiders.
Topics296,880
Posts4,960,749
Members66,987
Most Online2,688
Jan 19th, 2019
Page 1 of 3 1 2 3
2018 Toyota Tacoma TRD Off-road. #4724684
04/12/18 11:28 AM
04/12/18 11:28 AM
New Braunfels
Bryanccfshr Online content OP
Bryanccfshr  Online Content OP
New Braunfels
Just reporting that I sold 1of my 4 runners and bought a taco. The reason is that I will be using the vehicle for consultant wrk with reimbursable mileage.
I looked at the ford half tons with eco boost engines and Tundras.
Initial quality of the fords seemed spotty. Some of the assembly was not complete of interior panels and the dealer was having to fix things in make ready. they did drive well. What I really didn’t like was the predicted rate of depriciation rate they would take as I would take putting them to work. The predicted maintenance was also higher. (Kbb)
The tundra is huge! And the gas mileage was unacceptable and would cut into my Margin so it was out.
My need was a 4wheel drive to access some new acreage, roads are mogul to dirt and sand. Initially looking at 3k miles a month. The taco has lower depriciation with miles, lower cost of maintenance and the estimated gas mileage and road safety features sold me.
Lane departure, blind spot monitoring and adaptive cruise control are nice when you are logging a lot of miles on country roads and fatigue management becomes paramount.
Initial 50 mile trip home from the dealer netted a computer reported 24.5 mpg. Even if that’s 10%off it’s good.
The 2gr-fks engine has finally won me over. I was initially resistant to this direct and port injected modified dual Otto/Atkinson cycle engine, but it is basically a gr engine just like the 2gr fe and the 1gr fe with some additions.There are a lot of complaints about premature upshifts with this vehicle, the trick is to stay on the throttle. The engine likes to rev, and people used to the 1gr will instinctively let up on the throttle as the refs climb and this promotes an instant upshift. If you steadily tip into the throttle as you accelerate it does not do that. Maybe Toyota updated the ecu a bit but it drives better than the 2017 I test drove last year.
As far as build quality, it is A partially open Channel ladder frame instead of the boxed frame on my beefier 4 runner. However for the environment I will be using it, this is a mileage burner and comfort, economy and capability ruled my decision.
Getting the off-road vs the Pro was a value decision. It will get me through anything I should encounter while working.
I will report how it holds up to use.
2018 Trd Pro 4Runner
2018 Tacoma off-road
Dealer 0w20 to M1 0w40 FS -it depends
Re: 2018 Toyota Tacoma TRD Off-road. [Re: Bryanccfshr] #4724705
04/12/18 11:47 AM
04/12/18 11:47 AM
New Braunfels
New Braunfels
Still on the dealer sight. I paid a little less. Link for pics
https://www.durangomotorcompany.com/new/...668bf47cb1d.htm
Re: 2018 Toyota Tacoma TRD Off-road. [Re: Bryanccfshr] #4724709
04/12/18 11:52 AM
04/12/18 11:52 AM
PimTac Offline
PimTac  Offline
Congratulations on the new Tacoma. I’m sure you will get many years of use out of it. On the upshift topic, I find the same situation on the Mazda. A firm throttle helps versus a featherfoot style yet the mpg hasn’t suffered. Your transmission will learn your style and adapt to it.
Do you plan on doing any oil analysis on this truck? Usually Toyota uoa’s are pretty boring, even if breaking in.
Cannot see signatures any longer so it doesn’t matter.
Re: 2018 Toyota Tacoma TRD Off-road. [Re: Bryanccfshr] #4724712
04/12/18 11:53 AM
04/12/18 11:53 AM
PA,US
HemiHawk Offline
HemiHawk  Offline
PA,US
Love the color. It sounds like maybe they improved the TCU or ECU to improve drive-ability. The 2016 I had drove really poorly... But there were supposedly TSBs for the trans tuning.
That extra fuel economy will certainly help driving 3k miles a month. So will having a nicely optioned vehicle to sit in for long periods of time. Do you have the tools to get at the oil filter or will it be dealer serviced?
2016 Nissan Frontier Pro4x
2017 VW GTI sport
1995 Mustang GTS
Re: 2018 Toyota Tacoma TRD Off-road. [Re: PimTac] #4724721
04/12/18 12:01 PM
04/12/18 12:01 PM
New Braunfels
New Braunfels
Thank you! Eventually as an in warranty quality and fit for purpose of maintenance check. The duty will have a lot of road miles, but also a lot of dirty dusty roads and severe conditions running 4wd to access locations. I will run the severe duty maintenance cycle and analyze after the 2nd or third Oci.
Re: 2018 Toyota Tacoma TRD Off-road. [Re: HemiHawk] #4724722
04/12/18 12:03 PM
04/12/18 12:03 PM
New Braunfels
New Braunfels
I will take advantage of the provided maintenance plan but do drain and refills myself at 5k miles . I have an oil filter wrench for the gr engines in my toolbox.
Thanks!
Re: 2018 Toyota Tacoma TRD Off-road. [Re: Bryanccfshr] #4724739
04/12/18 12:31 PM
04/12/18 12:31 PM
Virginia Beach
Astro14 Online content
Astro14  Online Content
Virginia Beach
Nice truck!
Great choice. I’m certain it will serve you well.
32 Packard 15W40
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: 2018 Toyota Tacoma TRD Off-road. [Re: Bryanccfshr] #4724763
04/12/18 01:01 PM
04/12/18 01:01 PM
Canyon County Idaho
CT8 Online content
CT8  Online Content
Canyon County Idaho
Toyotas are nice.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 2018 Toyota Tacoma TRD Off-road. [Re: Bryanccfshr] #4724853
04/12/18 02:19 PM
04/12/18 02:19 PM
Nashville, TN via Memphis
john_pifer Offline
john_pifer  Offline
What oil filter setup does this engine have?
It’s not on top like the 1GR-FE?
16 WRX - PPPP
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 198K
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
Re: 2018 Toyota Tacoma TRD Off-road. [Re: Bryanccfshr] #4724890
04/12/18 03:11 PM
04/12/18 03:11 PM
Ceciltucky Maryland
Oldtom Offline
Oldtom  Offline
Ceciltucky Maryland
Congrats on the awesome truck. I have driven Toyotas since 1984 and had good luck with them. I have one concern, Road Salt. If you live in a road salt area have the underside sprayed with Fluid Film or something similar each fall. I bought the Kellesport spray gun for Fluid Film and it works fantastic.
Re: 2018 Toyota Tacoma TRD Off-road. [Re: Bryanccfshr] #4724902
04/12/18 03:35 PM
04/12/18 03:35 PM
john_pifer Offline
john_pifer  Offline
Surely Toyota’s frame supplier has been threatened up one side and down the other if the new truck frames aren’t properly coated/protected!
16 WRX - PPPP
Re: 2018 Toyota Tacoma TRD Off-road. [Re: Bryanccfshr] #4724909
04/12/18 03:48 PM
04/12/18 03:48 PM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
I know the 16 and 17 has shifting issues with the trans. Some folks use a pedal commander to resolve the issue. Have my 15 for almost two years and love the truck.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: 2018 Toyota Tacoma TRD Off-road. [Re: Bryanccfshr] #4724998
04/12/18 05:45 PM
04/12/18 05:45 PM
Southern VA
klt1986 Offline
klt1986  Offline
Southern VA
Really like that color. That truck will last you a long time!
Wife: 08 Honda CR-V 4WD, M1 5W-20
Me: 11 Toyota Tundra DC 4WD 5.7L, PP 5W-30
Me Work: 06 Ford Explorer 4WD 4.0L, Pennzoil 5W-30
Son: 14 Toyota Corolla S, M1 AFE 0W-20
Re: 2018 Toyota Tacoma TRD Off-road. [Re: Bryanccfshr] #4725016
04/12/18 06:06 PM
04/12/18 06:06 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Better access for treatment, though it could create more rot-traps.
That sounds like a feature that would be worth keeping an eye on.
Re: 2018 Toyota Tacoma TRD Off-road. [Re: Bryanccfshr] #4725048
04/12/18 06:42 PM
04/12/18 06:42 PM
WI.
dblshock Offline
dblshock  Offline
WI.
Some people have difficulty focusing.. you take your Toyota monies to a Toyota dealer for a nice car/truck that's engineered correctly...good work!
16 Civic Coupe Touring 38k
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Falken Wildpeak AT3W
Page 1 of 3 1 2 3
