I have a big dog diablo mp commercial mower with the Kawasaki FX850V engine. The mower is used once or twice a week, but it is run at max capacity for 4-5 hours nonstop each time. I want to get the best protection possible for the engine. I will be using rotella t6 for the oil, but I'm not sure about the filter. The recommended filter is the Kawasaki 49065-7010. I want to know if I should stick with that one or use the fram ultra xg4967 that it cross references to. Also, would a larger xg7317 work for this application? And what is the bypass valve pressure on the ultra, and would that even matter with the synthetic media?
Another topic: would using an oversized filter affect flow rate, oil pressure, or pressure differential across the media? This question is also about using an xg3600 instead of xg3614 on my car.
