I am trying to change the power steering reservoir on a 2003 Dodge Caravan. The large diameter ( about 1/2 inch ID ) return line is "welded" to the original plastic reservoir after 15 years of underhood temperatures. A replacement power steering hose is 107 dollars so I am trying to reuse the existing hose. Any suggestions on how to remove this hose without damaging it? I have tried working a thin flat screwdriver and icepick between the plastic fitting and the hose. Would a hair dryer help?
Thank you in advance for any advice.
