NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
104 registered members (advocate, 69Torino, 4WD, 53' Stude, 69GTX, A310, 13 invisible), 1,794 guests, and 39 spiders.
Topics296,896
Posts4,961,146
Members66,997
Most Online2,688
Jan 19th, 2019
Page 1 of 6 1 2 6
You're About To Drive Cross Country... #4723574
04/11/18 11:07 AM
04/11/18 11:07 AM
Virginia
Globalksp Offline OP
Virginia
So, you get itchy feet and want to hop in the car and drive cross country from Virginia to California because, why not!?
You drive a 2007 Honda Fit, 5 Speed with 113,000 on the clock and multiple, A+ UOA's. Within the past year, you've changed the plugs, coils, and you'll put on new brakes before you leave and your roadside service is active. The car hasn't given you any trouble and the tires have 'enough' tread on them to make the round trip.
What else would you do in preparation? What spare parts would you pack (considering you're driving during a weekend) considering you can repair most things yourself?
Thanks!
2007 Honda Fit Sport Manual
Re: You're About To Drive Cross Country... [Re: Globalksp] #4723578
04/11/18 11:13 AM
04/11/18 11:13 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Make sure the spare is full of air, change out the pcv valve with an oem unit esp if the original is still in there.
Check fluid levels often during the trip. Wax the front end, get some Poorboys Bug Squash which also removes road tar. Available on Autogeek.com
Re: You're About To Drive Cross Country... [Re: Globalksp] #4723583
04/11/18 11:20 AM
04/11/18 11:20 AM
CA
The Critic Offline
The Critic  Offline
CA
Make sure the cooling system is in good shape. That will be your weakest link in a 10 yr old car. The radiator and t-stat are most suspect.
2011 Toyota Prius - 181k - M1 EP/EP HM Mix 0W-20
2007 Honda Accord 2.4 - 134K - Mobil 1 EP HM 5W-30
Re: You're About To Drive Cross Country... [Re: Globalksp] #4723584
04/11/18 11:21 AM
04/11/18 11:21 AM
Cincinnati, OH USA
CincyDavid Offline
CincyDavid  Offline
Cincinnati, OH USA
Drive to the closest airport and just buy a ticket for a direct flight. My sciatic nerve pain just starts twitching at the thought of a long car ride like that. My parents are in their 80s and drive back and forth between southern Arizona dna Cincinnati several times a year...1800 miles in 3 days. I can'e even imagine.
06 Kia Sportage EX greenish gold(ugliest color ever)
11 Jeep Grand Cherokee Limited HEMI Mineral Gray
14 Honda Accord LX metallic black
17 VW Jetta SE black
Re: You're About To Drive Cross Country... [Re: Globalksp] #4723586
04/11/18 11:22 AM
04/11/18 11:22 AM
CA
The Critic Offline
The Critic  Offline
CA
If it is an option, I would seriously consider renting a car. Rentals are so cheap nowadays and in situations like this, it is better to be driving a new car that can be quickly replaced if anything goes south.
Re: You're About To Drive Cross Country... [Re: Globalksp] #4723587
04/11/18 11:22 AM
04/11/18 11:22 AM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
Probably nothing, unless there's some common part that fails and stops the car? Is your battery very old? We had an alternator go out once and the battery was 8 years old, so it was probably the cause.
I'd just have a look underneath to make sure nothing important is leaking, check the fluids up top, and go enjoy the trip!
Also schedule some time for detours along the way, we've driven to the west coast a couple times and my only regret was not having enough time to see more things.
07 Focus ZXW, 5spd manual, 218km M1 5W30
18 Outback 2.5 CVT 15km 0W20
Re: You're About To Drive Cross Country... [Re: Globalksp] #4723594
04/11/18 11:26 AM
04/11/18 11:26 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
I can see the allure of driving cross country but I would rent a car and fly back. That return trip may seem SUPER long.
Re: You're About To Drive Cross Country... [Re: Globalksp] #4723596
04/11/18 11:27 AM
04/11/18 11:27 AM
Pittsburgh,PA U.S.A.
JimPghPA Online content
JimPghPA  Online Content
Use an inferred temperature gauge to check the temperature on the brakes right after you have driven it for several miles.
Sometimes when you put new brake-shoes on the pistons on the caliper or wheel cylinder has rust in an area that was not being used and is now being used, and this causes the caliper or wheel cylinder to not completely release when the brake is not being applied. This causes the brakes to rub more than normal and causes the brakes to get too hot. This is tricky to catch because it can rub enough to create the excess heat, but not hard enough to cause the wheel to not turn. This can cause the brakes to over-heat and if they get hot enough with the speeds seen when driving on a highway, the brake fluid can get hot enough to boil and create gas in the brake system that makes the brakes not work.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: You're About To Drive Cross Country... [Re: Globalksp] #4723597
04/11/18 11:30 AM
04/11/18 11:30 AM
Phoenix, Arizona - USA
SirTanon Offline
SirTanon  Offline
...make sure I have plenty of water and other drinks loaded into a decent cooler. I get thirsty on long trips.
Also, I'd make sure I have something that I can use to locate any necessary gas stations, etc.. along the way, in case I need to dispose of any of that used water.
I also keep a small rubbermaid tote in my trunk that holds some towels, a couple quarts of oil, a 2l bottle of water for the radiator, and a small socket and wrench set, as well as a couple screwdrivers, a flat plug/patch kit, and a couple of hose clamps.. just in case. Oh yeah, and a partially-used roll of duct tape in case I need to emergency patch a hose.
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 268,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 61,000mi
Re: You're About To Drive Cross Country... [Re: SirTanon] #4723607
04/11/18 11:36 AM
04/11/18 11:36 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Jumper cables and some Depends.
Re: You're About To Drive Cross Country... [Re: Globalksp] #4723617
04/11/18 11:46 AM
04/11/18 11:46 AM
SF Bay Area
y_p_w Offline
y_p_w  Offline
SF Bay Area
If you have the basic tools needed to do it, spare belts. Basically everything including A/C and accessory belt. I'm not sure what drives what on a Fit, but it's probably just two belts.
I don't really know how to do it myself, but having suffered a snapped belt before, this is apparently the one cheap part breaking that could leave you stranded in the middle of nowhere. The belts (OEM quality from Bando or Gates) sell for less than $30 for the set if you price shop.
Re: You're About To Drive Cross Country... [Re: Globalksp] #4723619
04/11/18 11:49 AM
04/11/18 11:49 AM
Globalksp, your statement of "put on new brakes before you leave" is what has me concerned because in the rare time that new brakes have the failure to completely release and causes an over-heat problem it is right after the brakes were changed that this problem occurs.
JimPghPa
Re: You're About To Drive Cross Country... [Re: Globalksp] #4723621
04/11/18 11:50 AM
04/11/18 11:50 AM
NJ
Leo99 Offline
Leo99  Offline
NJ
I'd hop in and go. It's only 3000 miles. Why would 3000 miles in 2 days be more stressful on your car than 3000 miles in 2 months?
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: You're About To Drive Cross Country... [Re: The Critic] #4723622
04/11/18 11:50 AM
04/11/18 11:50 AM
Canada
Lolvoguy Offline
Lolvoguy  Offline
Canada
thankyou
Beat me to it!
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: You're About To Drive Cross Country... [Re: Globalksp] #4723625
04/11/18 11:52 AM
04/11/18 11:52 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
You guys have no adventure.
Nothing wrong with OPs car. Id do this in my Jeep or truck worry free.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Page 1 of 6 1 2 6
