Originally Posted By: SatinSilver
Yes.
Wash, rinse, soap panel again, glide sponge over surface. Then either wipe with a plush MF towel, rinse or soap panel again then rinse. Which ever method you prefer and depends on how much gunk is on the panel. Lower panels seem to be worse.
Using some Iron-X spray before hand does a great job of decontaminating the lower areas. Then clay afterwards. Helps reduce any micro-marring. You can buy it on AG with the sponge. A must on lighter colored cars in the rust belt to get rid of rail dust chemically.
Then wipe down with some rubbing alcohol so the sealant of your choice has a squeaky clean surface to bond to. Let sealant cure in garage over night/24 hrs.
Would you say the mitt cleans the surface better, or not as well as a clay bar?
