Tires That Last Forever...
Nice long file strokes on the first belt. Really short light pressure strokes on the second. Not even the same kind of belt. Might fool the youngsters.
I call Bee Ess.
First off, most tires use up their tread before the sidewalls crack and become unusable.
Secondly, if you're doing something so that the tread doesn't wear out, it sounds like a perfect way to end up in a tree or ditch in the rain or cold. According to their YouTube comments it doesn't effect traction. I'm not buying it, that's just not how things work.
I wonder if they recommend this on motorcycle tires too?
First saw that stuff recommended by a rubber boat specialist vendor. Its billed as protection against UV and ozone, both significant threats here.
Given that my tyres age-out before they wear out, I'd buy it, but AFAIK you can't get it here.
I used sunflower oil a few times but became concerned that it might weaken the tyre structure (it noticably softened a crunchy radiator hose) so I stopped using it two or three years ago.
Occaisionally think about starting again but havn't so far.
Wish I still had my autocross car and timing equipment, I'd be willing to test the idea. Treat both tires on one side of the car and not the other two. Run a lengthy skidpad test in one direction and then in the other controlling as many variables as possible. You should be able to find out very quickly the grip and wear difference.
If this goes viral, I bet the guy's inbox is going to be flooded with messages from lawyers offering to be retained for when someone tries this, wrecks, and sues the guy for recommending it.
Looks like more of an ad for 303 than anything else. It might make the tire sidewalls shine for a couple of weeks, but as for reducing treadwear LOL!! That is more than a far reach. I have never put tire shine stuff on my tires and quite frankly do not care if they are shiny or not. None of my vehicles are ever going to be in a car show. I have seen 303 around , it is right next to the ArmorAll type products.
Straight out of Consumer Report Aug 23 2016. "We have not tested any of these products, but we did ask for feedback from Bridgestone, Continental, and Michelin. The clear consensus was that today’s car tires are formulated to resist the harmful effects of UV light and ozone.
Continental did not recommend use of lubricants or chemicals to the tire, and Michelin said tires should be cleaned with soap and water. Bridgestone said their tires have antioxidants and waxes in the tire to protect them from the environment. A dull appearance may occur overtime, but this is just the waxes migrating to the surface and actually helps protect the tire."
I can recall a few friends of mine who used Armor all on every rubber and plastic part on the car including the dash and seats. In most cases it seemed to cause the plastic dash to crack. Also made the vinyl seats very very slippery. I recall a kid go sliding out of the passenger side of a vehicle while they were spinning cookies in the HS parking lot
This may just work. Plasticizer is something well known. It could make the rubber or plastic it is applied to more flexible and less brittle so that tiny pieces don't break off as much.
Originally Posted By: Virtus_Probi
Arizonia tires?
Arizonian Tires, sold by Discount Tire (a shop chain store), really made by Cooper Tires. I could have sworn back in the 80's or 90's that Kelly Tires made Arizonians, so maybe Cooper bought the name now.(??) They might be the cheap made-in-China tires even though Cooper is the owner.
Shouldn't need a lengthy test to show grip difference. You'd be able to pull more lateral G's in one direction than the other.
Wear it'd depend, if there is an effect, on the mechanism.
If its just a lubrication effect (so grip and wear were inversely related), then it might show up in short term testing, though if the stuff gets absorbed then the timing might be critical.
If, OTOH, its primarily UV/Ozone protective effect, then it might not show up on practical timescales.
I thought of trying this type of "endless corner" testing when I was doing the sunflower oil treatment, but never got around to it.
I did do some half-assed emergency stop testing after standing overnight post-treatment, just to make sure it hadn't become very dangerous, and if anything it seemed to stop a bit better.
Perhaps the rubber was softened and got a bit stickier. The tyres, IIRC, were about 8 years old so probably fairly hard.
I stood right next to a Peter O'Toole type Peter O'Toole at Leeds University Union bar once, yet I am not Irish, nor a film star.
Right. And these companies did not say "Our tyres are lousy, and need protected by aftermarket products".
Surprise!
I believe Armor all is shiny stuff with an organic solvent carrier, so it seems quite likely it would attack rubber and plastic. IIRC 303 claims not to and might be silicone based.
I'm not saying 303 works, never used it. I'm saying your stated reasons for knocking it (other than general scepticism, which is appropriate) aren't valid.
ROFL, this video is jokes. If there is one place to not save money, Id say its on tires, something that impacts how well your brakes bring you to a stop in an emergency situation. Sure, spraying some sort of treatment on a tire might reduce the friction on the tire, but how many miles do you think that coating wears off?
1st: it will reduce traction. Its the equivalent of spraying tire shine on your tire tread, if you ever read a bottle, it clearly states to avoid that as it can become dangerous. I highly doubt it will double the useful life of any tires. Even if it helped you save on new tires for 5000 miles, it likely wouldn't be worth the risk to your life and others. Tire shine fades off my sidewalls in 2 weeks, what makes you think it will reduce wear on the tread longer than 5 minutes? Only 2 possibilities here, less friction on tires less grip = less wear. Many other ways Id rather use to save money. Maybe the salesman should learn to be a better salesman so he can afford new tires every 100k miles instead HAHAHA.
I do not use them but anyone who does would be prudent to use some common sense. Never any real proof that those products do much more than make rubber,vinyl and plastic shine for a little while . The notion that some spray on product is going to extend treadwear is beyond laughable. If that were the case every truck and taxi company would be using the stuff. But people can use it if they wish .no one is stopping them. Make your own judgement, but if major tire companies see no need for it why would a consumer?Most people that use products like that are detailers or people who enter vehicles in car shows. ((Right. And these companies did not say "Our tyres are lousy, and need protected by aftermarket products")) Well DUH!! Given the high of tires today, there should be no need to spray on any aftermarket "magic juice". Never confuse skepticism for common sense.
Chemicals and different "preps" are huge in the dirt racing industry, there are actually companies dedicated to developing tire prep chems that enhance grip and make tires wear better so Its not Impossible but I think the claims are a little much for this stuff...
Look up a company called "trackTac" I knew the chemist there pretty well and did lots of testing for them in my dirt karting days. They make some neat products that have amazing effects on tires.
Interesting. Think I heard of a winter-time snow/ice traction enhancer that basically mixed fine sand with rubber to paint on tread just for those times when you have the car in the garage and are about to drive out on icey roads that day.
