Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Coated rotors
by supton. 01/17/19 07:51 PM
Good samaritan
by JLTD. 01/17/19 07:15 PM
Doing suspension work. Need alignment?
by HawkeyeScott. 01/17/19 05:45 PM
100mg CBD Cannabis Gel
by Al. 01/17/19 05:36 PM
Electric Car "Green Test"
by redbone3. 01/17/19 05:06 PM
Want to try a uoa
by Dylan1303. 01/17/19 04:56 PM
Happy Birthday, Betty White!
by eljefino. 01/17/19 04:20 PM
Fram Ultra for Ecoboost 2.7
by Purpfox. 01/17/19 04:10 PM
Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
Dickerson888, Frisky, polarisman340, jfradella, Bigyetti83
66964 Registered Users
124 registered members (Aero540T, 4WD, 69Torino, AdditiveOCD, 2015_PSD, 9 invisible), 1,710 guests, and 49 spiders.
Topics296,750
Posts4,958,214
Members66,964
Most Online2,577
Jan 14th, 2019
Dodge Caravan Power Steering Hose #4722980
04/10/18 05:41 PM
04/10/18 05:41 PM
Ceciltucky Maryland
Oldtom Offline OP
Oldtom  Offline OP
Ceciltucky Maryland
I am trying to change the power steering reservoir on a 2003 Dodge Caravan. The large diameter ( about 1/2 inch ID ) return line is "welded" to the original plastic reservoir after 15 years of underhood temperatures. A replacement power steering hose is 107 dollars so I am trying to reuse the existing hose. Any suggestions on how to remove this hose without damaging it? I have tried working a thin flat screwdriver and icepick between the plastic fitting and the hose. Would a hair dryer help?
Thank you in advance for any advice.
Re: Dodge Caravan Power Steering Hose [Re: Oldtom] #4722991
04/10/18 05:54 PM
04/10/18 05:54 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
There's a tool meant for this. It's similar to what you've been using but is basically an ice pick that hooks backwards. Might be worth the $10 to try one.
Re: Dodge Caravan Power Steering Hose [Re: Oldtom] #4723015
04/10/18 06:12 PM
04/10/18 06:12 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Wyr
God bless
Re: Dodge Caravan Power Steering Hose [Re: Oldtom] #4723027
04/10/18 06:25 PM
04/10/18 06:25 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
Silicone spray can be used as a penetrant on "rubber" hoses.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Dodge Caravan Power Steering Hose [Re: Oldtom] #4723029
04/10/18 06:25 PM
04/10/18 06:25 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Get some cheap plier covers, wet the connection down with WD40 and twist the hose back and forth.
If you can lift the hose slightly shoot some WD40 in there and continue to twist while pulling.
WD 40 works better than anything I have tried on rubber hose, rubber parts and O rings and will not damage the rubber,
http://www.searshardwarestores.com/produ...BSABEgJ7sfD_BwE
Re: Dodge Caravan Power Steering Hose [Re: Oldtom] #4723623
04/11/18 11:50 AM
04/11/18 11:50 AM
Ceciltucky Maryland
Oldtom Offline OP
Oldtom  Offline OP
Ceciltucky Maryland
THANK YOU TO EVERYONE WHO POSTED. I got a pick set at Harbor Freight and was able to work the hose off. Trav, I did not get to use the WD 40 as the connection was leaking a lot of PS fluid which helped lubricate things. Anyway, I am back on the road and the power steering whine has gone from " Cat in a clothes dryer " to a low hum.
I will do a couple drain and fills with ATF+4 and take a long test drive before taking any long trips.
