Should i change my oil?
Washington
Oil has 29xx miles on it. I just ported my intake. Its plastic and i used a dremel to delete some walls that where in the intake manifold. I got about 95% of the plastic shavings out. Im jw if the remaining shavings would call for a oil change. This is on my 1.4t cruze. I ported the intake and did a pcv reroute. “To fix a common pcv issue”. Oil is penn euro 0w40 and i was gonna put in penn plat d1g2 5w30
