Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Pics - 2005 Highlander 3.3L 158k miles
by dkryan. 01/20/19 11:21 AM
Chinese nuclear momentum
by OVERKILL. 01/20/19 10:35 AM
Winter finally arrived
by StevieC. 01/20/19 10:27 AM
Octane rating of UL94 avgas
by Altydoc. 01/20/19 09:55 AM
Any bowlers out there?
by 53' Stude. 01/20/19 08:10 AM
Future of subcompact cars?
by Char Baby. 01/20/19 07:15 AM
Are u a roller coaster fan?
by ZZman. 01/20/19 07:03 AM
DUST - a couple of short Sci Fi films
by Shannow. 01/20/19 05:46 AM
5W30 Synthetic Oils With HTHS of 3.5 ?
by ChrisD46. 01/20/19 04:02 AM
White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Rob_from_Madison, SubieSTI, ebersvc, junk1020, fairparts99
66987 Registered Users
106 registered members (02z, 97f150, 53' Stude, 17 invisible), 2,319 guests, and 37 spiders.
Topics296,880
Posts4,960,749
Members66,987
Most Online2,688
Jan 19th, 2019
Should i change my oil? #4722959
04/10/18 05:19 PM
04/10/18 05:19 PM
Washington
Dylan1303 Offline OP
Washington
Oil has 29xx miles on it. I just ported my intake. Its plastic and i used a dremel to delete some walls that where in the intake manifold. I got about 95% of the plastic shavings out. Im jw if the remaining shavings would call for a oil change. This is on my 1.4t cruze. I ported the intake and did a pcv reroute. “To fix a common pcv issue”. Oil is penn euro 0w40 and i was gonna put in penn plat d1g2 5w30
12 cruze rs 1.4t 6spd pp 5w30 tuned on 22psi
13 equinox 2.4 awd pp 5w30
Re: Should i change my oil? [Re: Dylan1303] #4722962
04/10/18 05:23 PM
04/10/18 05:23 PM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
You took a dremel to the intake while it was still on the engine?
Re: Should i change my oil? [Re: Dylan1303] #4722968
04/10/18 05:27 PM
04/10/18 05:27 PM
Washington
Washington
No i pulled the manifold
Re: Should i change my oil? [Re: Bottom_Feeder] #4722969
04/10/18 05:28 PM
04/10/18 05:28 PM
Phoenix, Arizona - USA
SirTanon Online content
SirTanon  Online Content
If you removed it before doing the work, and you cleaned it THOROUGHLY before you put it back on, then you're probably okay to wait.
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 268,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 61,000mi
Re: Should i change my oil? [Re: Dylan1303] #4722990
04/10/18 05:54 PM
04/10/18 05:54 PM
New England
gathermewool Offline
New England
Where are the other 5% of the shavings?
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: Should i change my oil? [Re: Dylan1303] #4723000
04/10/18 05:58 PM
04/10/18 05:58 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
None of the shavings found their way into the oil, trust me!
Run that oil to 8,000-9,000 easily
Re: Should i change my oil? [Re: Dylan1303] #4723097
04/10/18 07:40 PM
04/10/18 07:40 PM
Somewhere in time
Imp4 Offline
Imp4  Offline
Somewhere in time
No
2001 Mitsubishi Galant 2.4 - 160k+
Grandma's creampuff...
