Old washer change torque?
New England
Just wondering if reusing your old drain plug washer has any effect on torque values. I’m guessing it’s very minimal but something to think about
I have re-used old drain plug washer on a few occasions. I don't recommend it but if I must do it, I won't lose sleep over it either. Assuming my torque wrench is calibrated spot on, then I might just put another lb-ft more than what's called for. As long as I don't see any drips of oil from the drain plug, I'll call it a day.
I've used the same combo wrench for years on my drain plugs so I have a good feel for when everything is tight enough. I reused a crush washer once and it caused a leak. I had to go back and snug up the plug an extra 1/16th of a turn to stop the leak. A new crush washer wouldn't have needed that extra snugging up.
The torque spec is based on not stripping the threads. If it leaks when properly torqued, you need a new washer.
When I have reused them I just flip them around. When you have to pry them off the plug threads then I change them.
I've reused them. Never used a torque wrench. Just get it good and snug.
I have never replaced my washers....ever. And I use my arm for my calibrated torque wrench. Never have had a leak.
Same here... still serviceable = still in service!
I have never "torqued" an automotive drain plug in my life.
I know when to stop - most jiffy shops stops when it's about 3% away from stripping the threads out!
Flip the washer around... or if its copper, heat it (dull red glow) and let it cool slowly. I always replace them (have a huge assortment), but for the odd size I don't have and in a pinch... I'll try and reuse.
