CASIO G-SHOCK
by Char Baby. 04/18/19 05:23 AM
Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
52 registered members (Anthony, Billbert, A1O, bbhero, Bailes1992, 6 invisible), 662 guests, and 27 spiders.
Topics287,673
Posts4,932,031
Members67,838
Most Online2,967
Mar 10th, 2019
Oil looking stripe on underside of hood / GM 3.4L #4722610
04/10/18 10:41 AM
04/10/18 10:41 AM
Joplin
Cressida Offline OP
Cressida  Offline OP
Joplin
I have a Chevy Venture van, 3.4L with 180k miles. After returning from a 400 mile drive last week I was surprised to open the hood and see about a one inch wide stripe of what I initially thought was motor oil, up on the underside of the hood. It's not leaking down on the pavement below the area but there was an oily area below the harmonic balancer (on sub frame) so I believed it must have been coming from the crankshaft oil seal. So I replaced the front crankshaft oil seal and cleaned up the hood area yesterday and drove the vehicle about 5 miles last night.
I went out this morning and opened the hood only to find a fresh strip on the underside of the hood again! Looking at it more closely now, it's the color and consistency of old heavy motor oil. However, my motor oil is a clean honey colored. It's not coolant as I'm running G05 which is light amber and very thin. I checked power steering and transmission fluids and it's far too dark to be either of their colors. (I'm using a white paper towel to test these appearance differences and nothing is matching)
The serpentine drive belt does not have any of this substance on it, so it does not appear to be something that the belt is picking up and throwing upward.
Now, I'm left thinking it may be the water pump since it's mounted high up and is right below this streak line. It's an aftermarket pump that was installed about 50,000 miles ago. Does a water pump have grease in the bearing?, and perhaps the pump seal is going bad. This could allowing a small amount of coolant to mix with the grease and when it exits from the pump weep hole, it is being spun upward by the pump pulley. The mixture of the pump grease with the coolant would have this unusual appearance and would explain why it doesn't match any of the other fluids of lubricants.
Does a water pump bearing have grease, and does the above make sense that it may indeed be the early signs of a water pump that is failing? There are no unusual noises at this time...
Re: Oil looking stripe on underside of hood / GM 3.4L [Re: Cressida] #4722617
04/10/18 10:47 AM
04/10/18 10:47 AM
NJ
DevilsRule Offline
DevilsRule  Offline
NJ
Power steering pump.
Re: Oil looking stripe on underside of hood / GM 3.4L [Re: Cressida] #4722624
04/10/18 11:00 AM
04/10/18 11:00 AM
A Warm place to live in
berniedd Offline
berniedd  Offline
That happened to me too. It was the high pressure power steering hose. Leaked down a little onto a pulley and got flung onto the hood above. As a precaution, mechanic opened up the valve cover to inspect the timing belt. Good thing it was dry, otherwise it would've needed replacement too.
Re: Oil looking stripe on underside of hood / GM 3.4L [Re: Cressida] #4722638
04/10/18 11:20 AM
04/10/18 11:20 AM
USA
SOHCman Offline
SOHCman  Offline
USA
could be oil from the engine or PSP slinging on hood from belt.
I urge people not to wait 100K to change out the fluid in their transfer case units. -Kestas
Re: Oil looking stripe on underside of hood / GM 3.4L [Re: Cressida] #4722643
04/10/18 11:24 AM
04/10/18 11:24 AM
One Step Beyond
MasterSolenoid Offline
One Step Beyond
To help determine what fluid is leaking and from where.
Use the Leak detector Dye.
Pour the 'dye' in one system at a time, then check.
For Oil, Power Steering
https://shop.advanceautoparts.com/p/inte...v+leak+detector
For Coolant
2002 Ford Ranger
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Oil looking stripe on underside of hood / GM 3.4L [Re: Cressida] #4722653
04/10/18 11:33 AM
04/10/18 11:33 AM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
The AC compressors of years gone by also would leave an oil streak across the hood and other adjacent areas.None of the Toyotas or Hondas I have owned for the last thirty some years did this. Not one evidence of even a seep out of the compressor seal.
Re: Oil looking stripe on underside of hood / GM 3.4L [Re: Yah-Tah-Hey] #4722748
04/10/18 01:07 PM
04/10/18 01:07 PM
Coastal South Carolina
edwardh1 Offline
edwardh1  Offline
GM was very slow to copy the japanese seals
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
SOLVED - Oil looking stripe [Re: edwardh1] #4723070
04/10/18 08:08 PM
04/10/18 08:08 PM
Joplin
Cressida Offline OP
Cressida  Offline OP
Joplin
Thanks for the good suggestions. I carefully checked out the A/C compressor and the power steering system. I couldn't find anything so I elected to pull the water pump pulley by default. As soon as I it came off, the underside of the pulley was soaked and I could tell it was the color I was looking at. I think all the dirt and grime made it look like motor oil. Also, there was movement in the bearing that I missed when I spun it yesterday.
I went and purchased a new water pump and got it installed this afternoon. The leak / spray has stopped.
