Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
80 registered members (aquariuscsm, avi1777, alarmguy, Astro_Guy, arowbat, AndyB, 9 invisible), 917 guests, and 51 spiders.
Topics286,106
Posts4,902,697
Members67,563
Most Online2,967
Mar 10th, 2019
DIY Low Cooland Level Sensor #4722507
04/10/18 08:45 AM
04/10/18 08:45 AM
Azerbaijan
NICAT Offline OP
NICAT  Offline OP
Azerbaijan
I Had some bad experiences with overheated engines.
Even though i check the coolant level , and try to and watch the temperature gauge regularly, sometime leak can be significant enough to make engine run out of coolant just in a few hours once it started.
And as far as i know, the temperature gauge just reads the coolant temperature. Once the coolant level is low, the sensor is in mid air. So once temperature gauge is displaying high, means you are out of coolant (if you are lucky enough to see it in time).
In my bmw there is coolant sensor in coolant reservoir. It alarms once the level is low.
But in my Daewoo, there is no sensor. and temperature gauge is so small.
I have an aditional bmw coolant level sensor. i can retrofit it into my reservoir, or even change the reservoir for extra safety.
But anyone idea about how the sensor work ?
I think, while the sensor is inside the water, the circuit is completed. But i need an alarm when there is no water. Not when there is.
Anyone have idea about how to set alarm when circuit is open.
Re: DIY Low Cooland Level Sensor [Re: NICAT] #4722517
04/10/18 08:57 AM
04/10/18 08:57 AM
Canada
camrydriver111 Offline
Canada
Even if you got it to work it's a waste of time IMO.
The Daewoo probably uses an overflow tank, while the BMW uses an expansion tank.
It is possible to have lots of coolant in the overflow tank, but have an empty system, so adding a sensor to it isn't really useful.
When you check the coolant in the Daewoo you need to check both radiator and overflow tank.
BITOG or: How I Learned to Stop Worrying and Love the Extended OCI
