air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
40 registered members (carlprop, clinebarger, Ag76, Bailes1992, czbrian, 1 invisible), 767 guests, and 62 spiders.
Topics286,440
Posts4,908,215
Members67,622
Most Online2,967
Mar 10th, 2019
Page 1 of 6 1 2 6
Extended OCI : "Just Say No" - If You Drive GDI #4722413
04/10/18 06:55 AM
04/10/18 06:55 AM
GA.
ChrisD46 Offline OP
ChrisD46  Offline OP
GA.
2017 Hyundai Sonata 2.4L GDI engine in signature calls for OCI of 3,750 (severe) and 7,500 (highway) with 5W20 , 5W30 or 10W30 allowed (depending on ambient temperatures) . *Thinking about doing a 10,000 mile OCIon a GDI engine - I say think again : The first reason is the fuel dilution issue of GDI engines as by 3,000 ~ 4,000 miles after an oil change - it becomes a significant consideration . The 2nd reason is due to the increased impurities a GDI engine creates which ends up back in the oil which I believe find themselves in the vapors that land on intake valves and create carbon deposits which are difficult to clean . Additionally , I'm not sure even a Blackstone test with TBN measurements tells you all you need to know IF you drive a GDI engine - the fuel dilution number may be the most critical . So , I say if you drive a GDI engine - only use synthetic in the recommended rating , with the lowest NOACK and error towards reducing your OCI's rather than extending them ... Your thoughts ?
2017 Hyundai Sonata 2.4L GDI 4 cylinder
2010 Hyundai Elantra 2.0L 4 cylinder
2007 Kia Sedona 3.8L 6 cylinder
Re: Extended OCI : "Just Say No" - If You Drive GDI [Re: ChrisD46] #4722416
04/10/18 06:59 AM
04/10/18 06:59 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
All that above...plus additionally dont use oily CAFE water...but Sae40 oils...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Extended OCI : "Just Say No" - If You Drive GDI [Re: ChrisD46] #4722431
04/10/18 07:21 AM
04/10/18 07:21 AM
Michigan
Greggy_D Offline
Greggy_D  Offline
Michigan
I just did 10,000 miles on an Ecoboost with MC 5w-20. The oil life monitor was down to 2%.
I think the engineers know what they are doing.
Greggy D.
Re: Extended OCI : "Just Say No" - If You Drive GDI [Re: ChrisD46] #4722445
04/10/18 07:41 AM
04/10/18 07:41 AM
FL, USA
gregk24 Offline
gregk24  Offline
FL, USA
I think it depends on the car manufacturer. Hyundai GDI's seem to tear up oil in short order. I have seen UOA on VW direct injected and turbo'd engines running to 10K and great results. Same goes for Ford and their EcoBoost line.
2012 Honda Accord EX-L K24z3
56,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
44,xxx miles
Castrol Edge 0w40 / OEM filter
Re: Extended OCI : "Just Say No" - If You Drive GDI [Re: ChrisD46] #4722447
04/10/18 07:42 AM
04/10/18 07:42 AM
Mississippi
Speak2Mountain Offline
Mississippi
I do about 6k on an early adopter GDI, Lexus IS
My routine:
1) Lotsa highway miles and high speeds
2) Lower NOACK, heavier oils. Heavy 5w30 or lighter 5w40
3) Fuel additives w/PEA and TT fuels
4) Change out Positive Crankcase Ventilation valve
5) Limit stop and go
Re: Extended OCI : "Just Say No" - If You Drive GDI [Re: Greggy_D] #4722468
04/10/18 07:57 AM
04/10/18 07:57 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I hope the engineers know what they are doing.
Fixed it. They probably do but unfortunately they are not the only ones involved in making that decision.
Re: Extended OCI : "Just Say No" - If You Drive GDI [Re: ChrisD46] #4722472
04/10/18 08:02 AM
04/10/18 08:02 AM
Florida
SilverSnake Offline
SilverSnake  Offline
Florida
I am with you. I change the oil on our BMW 330i every 6 months or 5000 miles, whichever comes first.
2016 Charger, 6.4L-485 HP (PUP 0W-40)
2017 BMW 330i, 2L-248 HP (BMW 0W-20)
2018 Jeep GC, 5.7L-360 HP (PUP 5W-20)
2008 20KW Generac (Amsoil 10W-30/30)
Re: Extended OCI : "Just Say No" - If You Drive GDI [Re: ChrisD46] #4722474
04/10/18 08:08 AM
04/10/18 08:08 AM
MI
doitmyself Offline
doitmyself  Offline
MI
Is the main purpose of GDI to increase fuel efficiency? If so, I wonder how the numbers work out regarding the cost of more frequent oil changes vs. better fuel economy. Not just in our pocketbook, but also in the amount of total resources consumed.
Having said that, are the supposed GDI problems real? I thought things have been improved.
Re: Extended OCI : "Just Say No" - If You Drive GDI [Re: Trav] #4722480
04/10/18 08:13 AM
04/10/18 08:13 AM
Northern Ontario, Canada
Danno Offline
Danno  Offline
All that Ford wants is that the truck is perceived as having a low maintenance requirement and that makes it past warranty without a major failure.
Past warranty - They Don't Care ......
Having run 1,000s of Fords in a fleet, this comes from 1st hand experience.
If it was my truck and I wanted to keep it past warranty, I would change it at 5,000 mile and use a 5W-30 D1G2 synthetic oil.
That OCI might reduce my concerns re: the history on the cam chain problems for the 3.5L EB
2016 Sorento SX V6 AWD
2015 KIA RIO SX
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
Re: Extended OCI : "Just Say No" - If You Drive GDI [Re: ChrisD46] #4722483
04/10/18 08:19 AM
04/10/18 08:19 AM
So. Calif.
turnbowm Offline
turnbowm  Offline
So. Calif.
Fuel dilution in Hyundai/Kia GDI engines is a good reason to choose 5W30 or 10W30 over 5W20. Also, a synthetic with low volatility (NOACK) to minimize carbon buildup on intake valves is why some people use 10W30 instead of 5W30. I use "normal" operating conditions for required (7,500mi/1yr) OCI on my Kia 2.4L GDI using PUP 5W30 and OEM oil filter. Will probably switch to PUP 10W30 next oil change.
2015 Kia Optima EX 2.4L GDI
2015 Chevy Volt
Re: Extended OCI : "Just Say No" - If You Drive GDI [Re: ChrisD46] #4722492
04/10/18 08:26 AM
04/10/18 08:26 AM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
OP, do you have a UOA for YOUR driving profile and YOUR engine to substantiate the fuel dilution claims?
Re: Extended OCI : "Just Say No" - If You Drive GDI [Re: Trav] #4722494
04/10/18 08:28 AM
04/10/18 08:28 AM
Michigan
Greggy_D Offline
Greggy_D  Offline
Michigan
Please do not change the words in my quote. That is not what I said.
Greggy D.
Re: Extended OCI : "Just Say No" - If You Drive GDI [Re: Danno] #4722503
04/10/18 08:42 AM
04/10/18 08:42 AM
Canada
camrydriver111 Offline
Canada
I don't think that is the case, especially considering they initially lost business to the Japanese due to reliability...
Yes, I'm sure they care less once it's out of warranty but it's not in Ford's best interest for the engine to fail right after warranty either.
BITOG or: How I Learned to Stop Worrying and Love the Extended OCI
Re: Extended OCI : "Just Say No" - If You Drive GDI [Re: ChrisD46] #4722504
04/10/18 08:43 AM
04/10/18 08:43 AM
CT USA
theeagleflies Offline
CT USA
right now, working with 5k mi, 6 month OCI; OLM in the teens.... below 20%. so far 18.2k miles on the car.
Also have an E2 catch can installed that grabs about an ounce every 1k mi.
i noticed upon emptying the 10 qts of oil into the oil pan; the whole garage stinks. seemingly much more so than with past port injected cars with 7.5k mi OCI.
not very scientific; but something is different.
mulling over doing 4k mi OCI since my driving has increased a little; 3 changes per year.... oil is cheap enough.
for me, cost has never been a consideration for oil changes, more of a what makes sense for me and my schedule than anything else.
i am also thinking that without a lab full of organic and inorganic analytical instrumentation it is not possible to really know everything about the oil.
2016 2SS Camaro SS; M6, NPP, MRC
Elite E2, Edge Ti 5w30
Re: Extended OCI : "Just Say No" - If You Drive GDI [Re: ChrisD46] #4722531
04/10/18 09:11 AM
04/10/18 09:11 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
I've never gone past 5K miles on any vehicle, Port or Direct Injected.
Depending on specs recommended in the Owner's Manual, i've used Conventional, Blends and Synthetics with no issue.
18 KIA Sportage 2.4 AWD
M1HM 10W30, OEM
ST SYN 5W30, ST9688 (next)
13 Hyundai Santa Fe Sport 2.0T
PPeL 5W30, OEM
M1HM 10W30, OEM (next)
Page 1 of 6 1 2 6
