Where to buy Extreme Green Penetration lubricant?
That's the price on the mfr website as well.
Why do you want it? Just to try it out?
FWIW that's about what you'd pay for similar products in that category. I have a bottle of CorrosionX that I paid $14 for and my Hornady One Shot is about $12 at Cabela's.
$10/4oz is a bit steep but it seems unlikely that you'll find it cheaper.
A mechanic recommend I try it. Makes the threads on spring compressors easier to turn under tension he said. BTW I've noticed Plexus Plastic Cleaner is about 10 bucks higher than the last time I bought, and you only get 13 ounces! Crazy.
Can't say about that stuff in particular. My Klann spring compresssor specifically recommends MoS2 Paste.
Not entirely sure the difference between paste and grease... But a 5% Moly grease may work.
For $10.53, Amazon will send ~14oz of CRC 03084 - dry moly lubricant.
For $30 and change, Amazon will send one pound of Jet-Lube Marine-Moly Molybdenum Disulfide Paste
There are other Moly pastes out there from Loctite and others, but all are $$$.
