CASIO G-SHOCK
by Char Baby. 04/18/19 05:23 AM
Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
55 registered members (87sammy, Anthony, 2015_PSD, A1O, Bailes1992, 6 invisible), 715 guests, and 26 spiders.
Topics287,674
Posts4,932,035
Members67,838
Most Online2,967
Mar 10th, 2019
Under valve cover pic #4721332
04/09/18 09:18 AM
04/09/18 09:18 AM
Wisconsin
emmett442 Offline OP
Wisconsin
1974 Dodge 360 with 80k on it. As far as I can tell, this was the first time it's ever been opened. Exceptional, in my opinion.
Everyone loves shaft mounted rockers!
2011 Ford Crown Victoria LX 4.6L V8 auto
2009 Chevrolet Malibu LT 2.4L I4 auto
1974 Dodge D200 360 V8 4 speed manual
Re: Under valve cover pic [Re: emmett442] #4721351
04/09/18 09:37 AM
04/09/18 09:37 AM
Western Ma.
rollinpete Offline
rollinpete  Offline
Western Ma.
Looks Good.
I like the older engines, so much more room. smile
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive187k miles
03 Saturn Ion 2.2 L4 5spddrive238K miles
PPHM 50/50 5w30 and Fram Ultra x 2
Currently under the influence of oil shocked2
Re: Under valve cover pic [Re: emmett442] #4721352
04/09/18 09:38 AM
04/09/18 09:38 AM
San Antonio, Texas
sasilverbullet Offline
San Antonio, Texas
Testament to how good the oils are today, compared to back then.
03 Porsche 911 Liqui Moly Leichtlauf High Tech 5w-40 & Mahle filter
14 Honda Accord 4dr EX-L 4cyl-M1 0W-20 & WIX XP
02 Chevy 5.7L van-GTX HM 10W-40 & WIX filter
Re: Under valve cover pic [Re: emmett442] #4721356
04/09/18 09:41 AM
04/09/18 09:41 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Very nice!
God Bless Our Troops
Re: Under valve cover pic [Re: rollinpete] #4721358
04/09/18 09:41 AM
04/09/18 09:41 AM
Wisconsin
Wisconsin
Originally Posted By: rollinpete
Looks Good.
You got that right. I had both covers off in 10 minutes. No exaggeration!
Re: Under valve cover pic [Re: emmett442] #4721371
04/09/18 09:53 AM
04/09/18 09:53 AM
SA
LvR Offline
LvR  Offline
SA
Lovely ................Interesting to note the difference in valve spring color on the exhaust valves there ...............
Re: Under valve cover pic [Re: LvR] #4721381
04/09/18 09:58 AM
04/09/18 09:58 AM
Wisconsin
Wisconsin
That's because mopar started using valve rotators on the exhaust valves, whcih requires a shorter spring (notice the difference between the retainers). So the springs are actually different between intake and exhaust, denoted by their colors.
Re: Under valve cover pic [Re: emmett442] #4721401
04/09/18 10:18 AM
04/09/18 10:18 AM
N.C.
gman2304 Offline
gman2304  Offline
N.C.
Only 80,000 miles in 44 years. Shouldn't it be clean, even with minimal OCI's?
Re: Under valve cover pic [Re: emmett442] #4721411
04/09/18 10:26 AM
04/09/18 10:26 AM
Wisconsin
Wisconsin
On a carbed engine, with (according to records) most of the miles accumulated on 1970's and early 1980's vintage motor oils, low mileage garauntees nothing.
Lots of low mileage vintage motors out there that are crud factories.
Re: Under valve cover pic [Re: emmett442] #4721457
04/09/18 11:05 AM
04/09/18 11:05 AM
US
JLTD Offline
JLTD  Offline
US
Looks fabulous and will run for 500k if you keep changing the oil...your truck?
I use the overseas owner's manual to choose my oil.
Using AMSOIL
Hers: 2008 Jeep Liberty 146k, SS 5w30/Amsoil
His: 2015 4Runner 53k, OE 5w30/Wix
Re: Under valve cover pic [Re: emmett442] #4721472
04/09/18 11:15 AM
04/09/18 11:15 AM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
Those were very good engines. Looks like someone has overhauled the carb and choke well. It's been almost four decades since I used lacquer thinner to overhaul a carb. Had to be careful with that product but it sure did clean up gasoline residue.
Re: Under valve cover pic [Re: Yah-Tah-Hey] #4721519
04/09/18 11:38 AM
04/09/18 11:38 AM
Wisconsin
Wisconsin
I did. When I got it, the truck ran pretty poorly. It was clear that, after it's slumber, someone had been cluelessly fiddling with the carb trying to wake the truck back up. I discovered the power valve passage nearly blocked up with crud and some incorrect linkage (accel pump worked when throttle was RELEASED. LOL). Now, it starts and runs almost as good as fuel injection in any temp!
My cleaner of choice for carbs is Alconox. It's almost like magic in that it's an extremely effective cleaner but is also gentle on the equipment! I simply make a boiling pot, throw in my disassmbled carb and components, let soak for a while, remove, agitate, let soak again, blow out, reassemble. Sparkling almost like new.
Re: Under valve cover pic [Re: emmett442] #4721521
04/09/18 11:39 AM
04/09/18 11:39 AM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
80K I would expect them to be clean.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: Under valve cover pic [Re: emmett442] #4721528
04/09/18 11:43 AM
04/09/18 11:43 AM
in the shop
sw99 Offline
sw99  Offline
in the shop
I have seen some pretty nasty small blocks over the years. This is one of the best ones I have seen. Looks fantastic.
2016 Nissan Versa S 1.6L
2018 Subaru Outback 2.5i
2019 Ford F250 6.7L CCSB
Re: Under valve cover pic [Re: emmett442] #4721616
04/09/18 12:53 PM
04/09/18 12:53 PM
Southeast
meep Offline
meep  Offline
Southeast
yes that's great. Our '57 283 needed a rebuild at ~80,000 and it was gross inside and out. Those rockers and rocker shaft are solid, thick metal.
-m
2018 F150
2015 crv (wifey!)
