How bad is detonation?
Azerbaijan
Hi.
I am able to advance or retard igniton by turning the distributor.
The problem is that, if i adjust distributor position to guarantee that the engine will never detonate, this will result in significant performance loss.
With current ignition timing, car's performance is great, and never detonates during normal or even hard driving at a city. But while the car is full and climbing, there is mild detonation. Which happens rarely. may be once or twice in a month.
I know that the detonation is bad. But how serious is it unless it leads to pre-ignition? Just wonder if anyone experienced mild detonation for a long time, but not serious damage to the engine ?
Higher octane fuel is very expensive here
How bad do you think is a piston with a hole in it? Why not investigate the cause? Check your manual for the recommended octane to use. Check for an EGR valve/ system not working, a hotter than normal running engine, carbon buildup on piston tops, lean fuel mix or knock sensor(if equiped)problem. . A check with an analizer to check codes and fuel trims can give some clues.Blocked EGR valve or plumbing can cause preignition. You shouldn't have to deviate from timing specs or run higher than recommended octane gasoline to enjoy a quiet engine.Might help if you gave more information about your car.
While I have yet to see any "holy pistons" in a street car I have seen a few at the strip.
I once sold a 78 Trans Am to a younger guy who brought it back running rough. It had every top ring broken! 400 V8. Still ran great off idle, but crazy broken.
A little pinging is supposedly ok as per GM owners manual on a Cavalier (I think) from the 1980s. It's been a long time since I read this but it was before the days of knock sensors. I would say to retard the timing a little just to make sure you're not doing damage to your engine. You can also use colder spark plugs.
I used to use a vacuum gauge to tune my old jeep V8s because my timing was difficult to get a good shot at the marks on the crank pulley. Tune it to highest vacuum with a steady reading, After awhile I just tuned it by ear.
Generally not as bad as pre-ignition.
If you're driving a Lada RWD (AKA Zhiguli in the former USSR), which I suppose is quite likely in Azerbaijan, the earlier Mk1 version with the round headlights has a brass vernier wheel on the side of the distributor for easier manual advance or retard of the ignition.
I've read somewhere (either my Haynes manual or my owners handbook) that this was to compensate for variations in fuel octane.
I imagine it might be possible to retro-fit this to other Lada models since parts commonality is generally good across the range.
I THINK my current car (a 1986 Daihatsu) was showing intermittent pre-ignition when I bought it, and probably had been doing so for some time. I used water as a decoke (sucked into one of the vacuum lines) and it stopped doing it for about 7 years.
Recently it started running-on at switch-off, so I arranged a water manometer and additional filter restriction so it would suck in water at high revs. Isn't running-on now but I need to get or make some more distilled water to continue the treatment.
https://www.bobistheoilguy.com/forums/ub...ric#Post4620273
Needs a bit more development but the basic idea seems OK.
I had a Chevy van with a 5.0 litre V8. It would ping/detonate in warm weather on the highway. Did this for years and never failed. I was surprised it lasted so long.
This engine had a simple vacuum controlled heated air intake that would provide some warm air from the exhaust manifold even in summer. If I disconnected the heated air intake form the air filter housing, it would ping less often. If your engine pings to much and you can cool down the intake air, give it a try.
Detonation/pinging on an engine with sub-9.0:1 compression is mechanically a whole lot different than one that is over 10.5. It's one of the reasons people usually overkill octane on race engines- a low compression engine may last a very, very long time with some detonation, whereas a 14:1 engine may only last a couple seconds before a catastrophic failure.
Wow. Great answers here. Thanks
That is good news. Mine is also GM engine, G15MF.
About spark cold plugs, i think they should only help preignition but not detonation. Since detonation happens after the spark plug firing, but preignition is before. So Too hot spark plug can cause preignition, but would it also cause detonation ?
Yes. Lada is very common in my country
In my car, retarding and advancing the ignition is also very easy.
Water decoke seems to be something very interesting. However i couldn't understand the logic behind it. i will investigate it and install in my car.
How to cool down the intake air if the ambient temperature is not that cool ?
Compression ratio in my engine is 8,6:1. So does it mean that it would tolerate mild detonation better ?
The GM van I had used a thermostatically controlled air intake set around 130 degrees F. This meant that in summer with an outside temp of 95 F, the intake system would continue to add some hot air from around the exhaust manifold. Sounds odd but his is how it worked. I disconnected the power to the thermostat control so it would intake only outside air. This would help lower the frequency of detonation. Perhaps this can be done with your car perhaps not.
Doing this may cause a hesitation when the engine is cold.
Is this an older car? I thought today's computers would pull back the timing when detonation occurs.
By the way, any pinging you can hear means there is more you cannot hear.
I would try and figure it out.
If it is something like a 60's V8, you may need to alter your timing curve as well as vacuum advance.
Gas was different back then.
Good luck.
I thought, like you, that hot plugs would mostly promote pre-ignition, but I am not certain of this.
You mention above that detonation can lead to pre-ignition. The reverse is also true, and at least some Low Speed Pre-Ignition events seem to consist of detonations initiated by pre-ignition and therefore starting before the timed spark.
Although detonation and pre-ignition are still distinct and different, they now don't seem to be as separate as they classically used to be.
Its more chemistry than logic. At the high temperatures in an operating engine, in the presence of hot (incandescent) carbon, water breaks down to hydrogen and oxygen radicals which react with the carbon.
C + H2O -> CO + H2
If there is excess oxygen the carbon monoxide and hydrogen will burn, otherwise it is exhausted.
The same reaction was used to make town gas from coal (well, coke, which is coal with the hydrocarbons cooked off)
A few things you could check out. I am unsure of the exact vehicle you are referring to though. If this is an older vehicle with mechanical advance achieved using flyweights and springs, the springs could be weak causing the timing to advance too soon. The weights could be worn out and causing the timing to be over advanced. These weights pivot on small dowels and when they wear the the holes get slotted and the result is over advanced timing by a few degrees. If this vehicle has a vacuum advance there is a possibility that is was replaced at some point with the wrong part, some are limited as far as how much additional advance they can give. One poster said EGR. If this vehicle originally had EGR and now it’s not functioning the chances of pinging in the midrange increases drastically. If this vehicle is carbureted it could just be too lean in the midrange. Manufacturers took extreme measure to get these to pass emissions and who knows what’s happened to it in the last XX years. Another possibility is carbon buildup causing hot spots. Does this vehicle burn a lot of oil? Run rich? Do you baby it constantly? All of those things could contribute to your problem.
