1984 fury 318.
by red7404. 01/20/19 10:48 PM
Dual Wrench (Humor)
by StevieC. 01/20/19 10:33 PM
Got A Tip For Everyone
by NYEngineer. 01/20/19 10:30 PM
Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
37 registered members (Cornershop, citationxeleven, c502cid, Ag76, billt460, 4 invisible), 964 guests, and 30 spiders.
Topics296,903
Posts4,961,303
Members66,997
Most Online2,688
Jan 19th, 2019
How bad is detonation? #4721135
04/09/18 03:22 AM
04/09/18 03:22 AM
Azerbaijan
NICAT Offline OP
NICAT  Offline OP
Azerbaijan
Hi.
I am able to advance or retard igniton by turning the distributor.
The problem is that, if i adjust distributor position to guarantee that the engine will never detonate, this will result in significant performance loss.
With current ignition timing, car's performance is great, and never detonates during normal or even hard driving at a city. But while the car is full and climbing, there is mild detonation. Which happens rarely. may be once or twice in a month.
I know that the detonation is bad. But how serious is it unless it leads to pre-ignition? Just wonder if anyone experienced mild detonation for a long time, but not serious damage to the engine ?
Higher octane fuel is very expensive here smile
Re: How bad is detonation? [Re: NICAT] #4721145
04/09/18 04:05 AM
04/09/18 04:05 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
How bad do you think is a piston with a hole in it? Why not investigate the cause? Check your manual for the recommended octane to use. Check for an EGR valve/ system not working, a hotter than normal running engine, carbon buildup on piston tops, lean fuel mix or knock sensor(if equiped)problem. . A check with an analizer to check codes and fuel trims can give some clues.Blocked EGR valve or plumbing can cause preignition. You shouldn't have to deviate from timing specs or run higher than recommended octane gasoline to enjoy a quiet engine.Might help if you gave more information about your car.
The "thinking" man's friend.
Re: How bad is detonation? [Re: NICAT] #4721174
04/09/18 04:55 AM
04/09/18 04:55 AM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
While I have yet to see any "holy pistons" in a street car I have seen a few at the strip.
I once sold a 78 Trans Am to a younger guy who brought it back running rough. It had every top ring broken! 400 V8. Still ran great off idle, but crazy broken.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: How bad is detonation? [Re: NICAT] #4721189
04/09/18 05:10 AM
04/09/18 05:10 AM
The land of USA-made Subies!
SubieRubyRoo Offline
Check the vacuum advance and other things and try to clean out any carbon buildup. Read this:
Detonation Basics
Re: How bad is detonation? [Re: NICAT] #4721223
04/09/18 06:21 AM
04/09/18 06:21 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Breaks pistons,rings and wipes out rod bearings.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: How bad is detonation? [Re: NICAT] #4721228
04/09/18 06:30 AM
04/09/18 06:30 AM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
A little pinging is supposedly ok as per GM owners manual on a Cavalier (I think) from the 1980s. It's been a long time since I read this but it was before the days of knock sensors. I would say to retard the timing a little just to make sure you're not doing damage to your engine. You can also use colder spark plugs.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: How bad is detonation? [Re: NICAT] #4721247
04/09/18 06:51 AM
04/09/18 06:51 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
I used to use a vacuum gauge to tune my old jeep V8s because my timing was difficult to get a good shot at the marks on the crank pulley. Tune it to highest vacuum with a steady reading, After awhile I just tuned it by ear.
Thick oil is better grin2
Re: How bad is detonation? [Re: NICAT] #4721260
04/09/18 07:14 AM
04/09/18 07:14 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Generally not as bad as pre-ignition.
If you're driving a Lada RWD (AKA Zhiguli in the former USSR), which I suppose is quite likely in Azerbaijan, the earlier Mk1 version with the round headlights has a brass vernier wheel on the side of the distributor for easier manual advance or retard of the ignition.
I've read somewhere (either my Haynes manual or my owners handbook) that this was to compensate for variations in fuel octane.
I imagine it might be possible to retro-fit this to other Lada models since parts commonality is generally good across the range.
I THINK my current car (a 1986 Daihatsu) was showing intermittent pre-ignition when I bought it, and probably had been doing so for some time. I used water as a decoke (sucked into one of the vacuum lines) and it stopped doing it for about 7 years.
Recently it started running-on at switch-off, so I arranged a water manometer and additional filter restriction so it would suck in water at high revs. Isn't running-on now but I need to get or make some more distilled water to continue the treatment.
https://www.bobistheoilguy.com/forums/ub...ric#Post4620273
Needs a bit more development but the basic idea seems OK.
Re: How bad is detonation? [Re: NICAT] #4721268
04/09/18 07:21 AM
04/09/18 07:21 AM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
I had a Chevy van with a 5.0 litre V8. It would ping/detonate in warm weather on the highway. Did this for years and never failed. I was surprised it lasted so long.
This engine had a simple vacuum controlled heated air intake that would provide some warm air from the exhaust manifold even in summer. If I disconnected the heated air intake form the air filter housing, it would ping less often. If your engine pings to much and you can cool down the intake air, give it a try.
Re: How bad is detonation? [Re: NICAT] #4721282
04/09/18 07:35 AM
04/09/18 07:35 AM
NJ
JLawrence08648 Offline
NJ
I have had a hole in a 2 cycle Yamaha piston from detonation.
Re: How bad is detonation? [Re: NICAT] #4721283
04/09/18 07:35 AM
04/09/18 07:35 AM
Detonation/pinging on an engine with sub-9.0:1 compression is mechanically a whole lot different than one that is over 10.5. It's one of the reasons people usually overkill octane on race engines- a low compression engine may last a very, very long time with some detonation, whereas a 14:1 engine may only last a couple seconds before a catastrophic failure.
Re: How bad is detonation? [Re: NICAT] #4721333
04/09/18 08:20 AM
04/09/18 08:20 AM
Azerbaijan
NICAT Offline OP
NICAT  Offline OP
Azerbaijan
Wow. Great answers here. Thanks
That is good news. Mine is also GM engine, G15MF.
About spark cold plugs, i think they should only help preignition but not detonation. Since detonation happens after the spark plug firing, but preignition is before. So Too hot spark plug can cause preignition, but would it also cause detonation ?
Yes. Lada is very common in my country smile
In my car, retarding and advancing the ignition is also very easy.
Water decoke seems to be something very interesting. However i couldn't understand the logic behind it. i will investigate it and install in my car. smile
How to cool down the intake air if the ambient temperature is not that cool ?
Compression ratio in my engine is 8,6:1. So does it mean that it would tolerate mild detonation better ?
Re: How bad is detonation? [Re: NICAT] #4721349
04/09/18 08:35 AM
04/09/18 08:35 AM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
The GM van I had used a thermostatically controlled air intake set around 130 degrees F. This meant that in summer with an outside temp of 95 F, the intake system would continue to add some hot air from around the exhaust manifold. Sounds odd but his is how it worked. I disconnected the power to the thermostat control so it would intake only outside air. This would help lower the frequency of detonation. Perhaps this can be done with your car perhaps not.
Doing this may cause a hesitation when the engine is cold.
Re: How bad is detonation? [Re: NICAT] #4721366
04/09/18 08:49 AM
04/09/18 08:49 AM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
Is this an older car? I thought today's computers would pull back the timing when detonation occurs.
By the way, any pinging you can hear means there is more you cannot hear.
I would try and figure it out.
If it is something like a 60's V8, you may need to alter your timing curve as well as vacuum advance.
Gas was different back then.
Good luck.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: How bad is detonation? [Re: NICAT] #4721432
04/09/18 09:42 AM
04/09/18 09:42 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
I thought, like you, that hot plugs would mostly promote pre-ignition, but I am not certain of this.
You mention above that detonation can lead to pre-ignition. The reverse is also true, and at least some Low Speed Pre-Ignition events seem to consist of detonations initiated by pre-ignition and therefore starting before the timed spark.
Although detonation and pre-ignition are still distinct and different, they now don't seem to be as separate as they classically used to be.
Its more chemistry than logic. At the high temperatures in an operating engine, in the presence of hot (incandescent) carbon, water breaks down to hydrogen and oxygen radicals which react with the carbon.
C + H2O -> CO + H2
If there is excess oxygen the carbon monoxide and hydrogen will burn, otherwise it is exhausted.
The same reaction was used to make town gas from coal (well, coke, which is coal with the hydrocarbons cooked off)
