Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
32 registered members (c502cid, alcyon, anndel, Bailes1992, Chris B., 4 invisible), 543 guests, and 56 spiders.
Topics286,442
Posts4,908,257
Members67,622
Most Online2,967
Mar 10th, 2019
New Supertech 9688 oil filter #4720918
04/08/18 08:20 PM
04/08/18 08:20 PM
RI, USA
plf Offline OP
plf  Offline OP
RI, USA
Did an oil change on wifeís 2010 Honda CR-V and new blue can filer would not fit , old supertech 9688 has fit for last 8 years. The new ones are wider/shorter than old ones . Anyone else have this problem or know which model I should be using . Thanks
2010 Honda CR-V, QS 0w-20
2014 KIA Optima LX, ST full synthetic 5w-30
Re: New Supertech 9688 oil filter [Re: plf] #4720922
04/08/18 08:27 PM
04/08/18 08:27 PM
Ontario, Canada
GSCJR Offline
GSCJR  Offline
Ontario, Canada
7317
03 3.0L 1MZ-FE QSGB 5w-30 ProSelect 21348 262KM
10 3.5L 2GR-FE CEB 0w-20 ProSelect 27047 165KM
Re: New Supertech 9688 oil filter [Re: plf] #4720924
04/08/18 08:30 PM
04/08/18 08:30 PM
The land of USA-made Subies!
SubieRubyRoo Offline
Sounds like the new ST 9688 has a 3593A can on it?
Re: New Supertech 9688 oil filter [Re: plf] #4720925
04/08/18 08:30 PM
04/08/18 08:30 PM
USA
slacktide_bitog Offline
USA
Yeah, the new 9688 is fat like Fram's 9688 and 3593 filters.
Fram's own PH9688 is fat. The Wix 51334 is also fat.
The only ST that will fit is the shorty 6607, which is too small. Pay the extra dollar for the orange can PH7317, which now uses a silicone ADBV smile
Re: New Supertech 9688 oil filter [Re: plf] #4720926
04/08/18 08:32 PM
04/08/18 08:32 PM
RI, USA
plf Offline OP
plf  Offline OP
RI, USA
Thank you. Will do my homework next time , just thought same model would fit even though designed changed. Glad I had a few extra white can filters for they also fit my KIA optima
Re: New Supertech 9688 oil filter [Re: slacktide_bitog] #4720934
04/08/18 08:38 PM
04/08/18 08:38 PM
RI, USA
plf Offline OP
plf  Offline OP
RI, USA
Good advice, will look to make the switch and will try the Fram and Maybe a carquest from advance auto. Itís to bad have been using supertechs for years on many cars and never had issues
Re: New Supertech 9688 oil filter [Re: plf] #4720952
04/08/18 09:13 PM
04/08/18 09:13 PM
Virginia
bbhero Online sick
bbhero  Online Sick
Virginia
Yeah slacktide is right on. That Fram orange with the new ADBV is a good choice indeed.
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: New Supertech 9688 oil filter [Re: plf] #4720964
04/08/18 09:19 PM
04/08/18 09:19 PM
Rio Rancho, NM
Pajero Offline
Pajero  Offline
Rio Rancho, NM
What is a new blue can filler? OEM? My Montero uses the 9688. Thanks in advance!
Respectfully,
Pajero!
Always remember "Planned obsolescence."
1994 Montero SR 3.5 DOHC, 133,xxx
Fram Ultra/ Snorkel with Pre-filter
K-9-Co-pilot
Re: New Supertech 9688 oil filter [Re: Pajero] #4720967
04/08/18 09:21 PM
04/08/18 09:21 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Respectfully,
Pajero!
Supertech filters are now made by Champ Labs, and are now a dark blue instead of the Wix made that were white.
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: New Supertech 9688 oil filter [Re: plf] #4720985
04/08/18 09:34 PM
04/08/18 09:34 PM
USA
USA
The CQ filters are no good. They are reboxed Purolators. The CQ Red is a Classic, while the CQ Blue is a P1. Both have tearing issues, and the size your Honda takes is the worst in terms of tearing.
Get the Fram PH7317 from Walmart smile
Re: New Supertech 9688 oil filter [Re: plf] #4721151
04/09/18 05:17 AM
04/09/18 05:17 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
Did an oil change on wifeís 2010 Honda CR-V and new blue can filer would not fit , old supertech 9688 has fit for last 8 years.......
That's because the 'new' Champ made 9688/3593a is a 'true' 9688/3593a application, not a downsized one like the Wix made for WM ST9688. The latter was really a 7317 application size filter, which is the spec size for a 2010 CRV.
Not sure how the '8 year' figure was determined. The Wix made for WM ST including the 9688 was only around for couple years starting in ~2016 after replacing the Puro Classic on the shelves. Before that Champ made ST, was iirc the same as current ST9688.
In any case, that's why the current ST 9688 won't fit 2010CRV. And, as there's no current ST7317 application you would have to use the shorty ST6607 if you chose to use a Super Tech filter now.
Re: New Supertech 9688 oil filter [Re: Sayjac] #4721251
04/09/18 07:55 AM
04/09/18 07:55 AM
RI, USA
plf Offline OP
plf  Offline OP
RI, USA
Sayjac good call. Should have been more specific 8 years including when supertech filters came in the black can. Miss those puro classics as well
Re: New Supertech 9688 oil filter [Re: plf] #4729293
04/16/18 08:25 PM
04/16/18 08:25 PM
New York
Marvin Offline
Marvin  Offline
New York
I have a similar confusion. I have a ST9688 on my shelf - not sure when I bought it (box says 2016). The filter is white and I don't recall which of my cars (2000 Civic or 2003 CR-V) I thought I was buying it for.
It looks like the Purolator 14610 (old ST/Fram 7317) I normally put on my CR-V but the guide in the store says 9688 is for the Civic (which I usually use a Purolator 14459 /3593A on). As mentioned above, the guide says to use ST6607 on the CR-V.
Since it's white, does it mean it's an old one and it goes on the CR-V? Or either car?
Re: New Supertech 9688 oil filter [Re: Marvin] #4729318
04/16/18 08:38 PM
04/16/18 08:38 PM
USA
USA
welcome
The white one will go on either car with no problems smile
But my choice would be to use at least the orange can Frams, which now feature a silicone ADBV
Re: New Supertech 9688 oil filter [Re: slacktide_bitog] #4729373
04/16/18 09:17 PM
04/16/18 09:17 PM
New York
Marvin Offline
Marvin  Offline
New York
welcome
Thanks! (First post but I've been following the forum for quite a while)
I always thought Fram was not well regarded around here.
