Walmart and Valvoline
by Bullwinkle007. 01/22/19 09:10 PM
Getting Our Kicks On Route 66
by 2015_PSD. 01/22/19 08:40 PM
Uploading a short film clip from an IPhone.
by Snagglefoot. 01/22/19 07:52 PM
Purolator L34631 (torn media)
by LDM. 01/22/19 07:51 PM
THIS close to getting a VDB today at TPA
by 14Accent. 01/22/19 07:48 PM
Supco Appliance Parts.
by George7941. 01/22/19 07:36 PM
Unusual Jury summons.
by Chris142. 01/22/19 06:31 PM
Vibration feeling after new tires installed?
by MONKEYMAN. 01/22/19 05:51 PM
Sudden Shake - ‘18 Accord
by Throt. 01/22/19 05:43 PM
05 Ford 500 Intake hole - melted
by Geauxtiger. 01/22/19 05:41 PM
How's K&N 1004 on Kia/Hyundai GDI
by SlavaB. 01/22/19 05:18 PM
more PSD woes with cold weather
by Donald. 01/22/19 05:10 PM
Can someone do a UOA on AmazonBasics oil?
by ThunderOne. 01/22/19 04:03 PM
Any analysis on the Mobil 1 0W-40 ESP Dexos 2?
by fnbrowning. 01/22/19 04:02 PM
Cat sick
by Eddie. 01/22/19 03:49 PM
Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
73guna, Tedee, JayF, Sam002, Binco
67013 Registered Users
73 registered members (209paulc, AdRock, 69GTX, askani79705, 11 invisible), 1,159 guests, and 41 spiders.
Topics297,006
Posts4,963,331
Members67,013
Most Online2,821
Jan 21st, 2019
Torque Wrench Question #4720742
04/08/18 03:56 PM
04/08/18 03:56 PM
Mississippi
TheLawnRanger Offline OP
Mississippi
I forgot to set my torque wrench back to zero overnight. I set it back early the next morning. Would this be enough to mess up the calibration?
'99 Cavalier 5w 30 SuperTech conventional
'11 Impala 5w 30 Magnatec full synthetic
'12 Colorado 5w 30 Magnatec full synthetic
*regular Wix oil filters for all
Re: Torque Wrench Question [Re: TheLawnRanger] #4720744
04/08/18 03:58 PM
04/08/18 03:58 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
No.
2007 Ford Fusion 236,000 miles
M1 0-20 EP
2017 Ford Fusion 62K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: Torque Wrench Question [Re: TheLawnRanger] #4720749
04/08/18 04:01 PM
04/08/18 04:01 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
No, one of mine says to keep it on its lowest setting not to set to 0.(which was news to me)
Re: Torque Wrench Question [Re: Rand] #4720760
04/08/18 04:17 PM
04/08/18 04:17 PM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
approved
The Harbor Freight torque wrenches say to do this
Re: Torque Wrench Question [Re: TheLawnRanger] #4720762
04/08/18 04:22 PM
04/08/18 04:22 PM
Mississippi
Mississippi
I keep it at the lowest setting which I think is zero with the tension loosened.
Re: Torque Wrench Question [Re: TheLawnRanger] #4720792
04/08/18 04:44 PM
04/08/18 04:44 PM
USA
SOHCman Offline
SOHCman  Offline
USA
taking it down to zero or at least the lower 10% of the range is best practice.
I urge people not to wait 100K to change out the fluid in their transfer case units. -Kestas
Re: Torque Wrench Question [Re: TheLawnRanger] #4721070
04/08/18 10:25 PM
04/08/18 10:25 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
As everyone says, don't fret over it, and a little above zero.
If you are really worried about it ... some people are that way ... you can take it to a machine shop and have them (re-)calibrate it, it's a simple job, won't cost much. Were it me, I'd wait a couple of years and do it then, though.
Worst thing you can do is drop it. (Even then you are probably OK, depending, but not for certain). Keep in in the case when not in use.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Torque Wrench Question [Re: TheLawnRanger] #4721269
04/09/18 07:21 AM
04/09/18 07:21 AM
Connecticut, USA
bmwpowere36m3 Offline
Connecticut, USA
We keep them at 20% of scale at work (aerospace). At home I've kept anywhere from 0 to 20%, it doesn't really matter. I also send them out once in a while for calibration.
Some wrenches shouldn't not be brought down to zero or below their scale (mechanism inside will loosen), other is won't matter, and even others will have a stop to prevent you from backing off too much.
Re: Torque Wrench Question [Re: bmwpowere36m3] #4721304
04/09/18 07:58 AM
04/09/18 07:58 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
That's why I use split beams you don't have to do anything with them after using it.
Re: Torque Wrench Question [Re: TheLawnRanger] #4722426
04/10/18 06:12 AM
04/10/18 06:12 AM
MI
doitmyself Offline
doitmyself  Offline
MI
Sturdevant Richmont presents an argument that "some" torque wrench designs will allow the wrench to become uncalibrated if set to zero and all spring pressure is relieved.
http://www.srtorque.com/error-proofing-t...-quality-score/
"When taking pressure off the spring, the design may allow the wrench to relieve pressure on the torque block. This can allow the torque block to disorient, shift. Some wrenches can be set to zero pressure on the spring or have the handle further away from the spring. Not only can the torque block disorient, it can even fall out of place in the wrench.
If the torque block disorients, calibration is lost. Repeatability becomes an issue because the block no longer functions as designed. Typically in the tilt block design, the block itself is not square. That means when the tilt block is reoriented and is on it's side, the torque value has changed without you knowlege."
Re: Torque Wrench Question [Re: TheLawnRanger] #4722446
04/10/18 06:41 AM
04/10/18 06:41 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I have an Craftsman Digitorque Wrench and it says to keep it set to 25% capacity. If accidentally left above 50% for more than a few hours set the wrench to the lowest setting and leave it here for a few minutes before using it. Calibration should be checked after 10,000 cycles. I've had this wrench since the early 90's and it is still accurate, checking it against a beam style wrench.
God Bless Our Troops
Re: Torque Wrench Question [Re: Trav] #4722754
04/10/18 12:14 PM
04/10/18 12:14 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
Yep, split beam is the way to go for anything I need torqued!
