Remote Start by Android Auto App ?
by LoneRanger. 04/19/19 04:53 PM
Continental PureContact LS
by The Critic. 04/19/19 03:31 PM
Dark/Black Rear Differential Oil - UOA?
by The Critic. 04/19/19 03:25 PM
Best oil for Honda Rancher?
by jayjr1105. 04/19/19 03:20 PM
Store bought kimchi?
by Quattro Pete. 04/19/19 03:15 PM
2020 KIA Soul Turbo
by Malo83. 04/19/19 03:03 PM
erratic Speedometer
by tookien. 04/19/19 02:59 PM
Another airbag recall
by mclasser. 04/19/19 02:44 PM
Which barb fitting is less likely to leak?
by zorobabel. 04/19/19 02:36 PM
Can these bucket style tappets be reused?
by atikovi. 04/19/19 01:34 PM
Scratched My New Car. Help Me Fix
by GeorgeKaplan. 04/19/19 01:23 PM
Talk about manual labor...
by AZjeff. 04/19/19 12:42 PM
Car didn't burn an ounce of oil... 7K OCI
by jayjr1105. 04/19/19 12:13 PM
Top 6 OEM Passenger Tire Sizes in 2018
by SubLGT. 04/19/19 11:12 AM
CRC intake valve cleaner, safe to use?
by Backstache. 04/19/19 10:06 AM
'94 Grand Am Steering Column Pivot Pins
by benjamming. 04/19/19 10:02 AM
Why the need to replace suspension springs?
by WyrTwister. 04/19/19 09:47 AM
incorrect mileage on reciept
by 1978elcamino. 04/19/19 09:17 AM
Oregon PowerSharp for chainsaw
by Fitter30. 04/19/19 09:16 AM
new tire 4 years old
by 1978elcamino. 04/19/19 08:51 AM
carve200, Harteeco, fatafox, CurtC, LockCracker
67850 Registered Users
95 registered members (bernau, bdcardinal, bbhero, ArrestMeRedZ, Bill_W, 17 invisible), 2,155 guests, and 32 spiders.
Topics287,749
Posts4,933,806
Members67,850
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Why Are Air Filters Important? #4720487
04/08/18 11:44 AM
04/08/18 11:44 AM
NW Ohio
Jim Allen Offline OP
NW Ohio
I'll tell ya...
The air intake system is the only connection between your engine's crankcase and the outside world. It's the only way outside contamination can make it into the engine. It's important to long engine (and lubricant) life that the air intake system be completely sealed and use the highest efficiency filter possible... one that allows the engine to reach it's rated power. Outside contamination begets increased wear. I contend that a high efficiency air filter is a higher priority than a high efficiency oil filter... if you have to pick one over the other. For myself, I would sacrifice a little upper end power for a high efficiency filter. Of course, if you face the quandary of not enough airflow to meet power requirements, you could consider increasing the filter area.
Yes, a higher efficiency filter will show more restriction sooner than vice versa. So what? That's what a filter restriction monitor is for. In any case, the fuel economy is not effected on an EFI car due to air filter restriction until the engine can barely run and a small power loss is usually not noticed in everyday driving. Lead-foots would be more conscious of this.
So, buy the highest efficiency filter you can (look for 99% plus on coarse dust tests, which is about 97% on a fine dust test... a rare spec to see). Make sure it seals well in the housing and that there are no leaks anywhere else in the system. Install a restriction gauge and replace the filter only when it reaches the right restriction (variable, about 10" of water, 2.5kpa is the generic number). If you were performance oriented and you saw the power coming off sooner, you could change sooner. Or, if you are economy minded, you could go higher. It will vary from engine to engine, depending on how you use the vehicle and how much filter area it has.
Jim Allen
Keepin' the Good Old Days of Four Wheeling Alive
Re: Why Are Air Filters Important? [Re: Jim Allen] #4720494
04/08/18 11:57 AM
04/08/18 11:57 AM
US
Shellguy Offline
Shellguy  Offline
US
Great post Jim...alot of people I know skimp on their air filter. I will forward this to them to read. I wish we had a list of bitog approved filters..Good to see you around buddy.
2012 F-150 5.0-Pennzoil Platinum 5w30/Amsoil Eao17
Re: Why Are Air Filters Important? [Re: Jim Allen] #4720495
04/08/18 11:57 AM
04/08/18 11:57 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
Welcome back Jim. I frequently quote and link some of your prior posts on AFs (efficiency and loading relationship) and OFs (holding capacity). I know you are big fan of AF restriction gauges. Good see a new contribution from you here. thumbsup
Re: Why Are Air Filters Important? [Re: Jim Allen] #4720507
04/08/18 12:15 PM
04/08/18 12:15 PM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
Where might the best information be for this? Such as independent studies or SAE papers etc.?
Information that proves dirt entering the via the air intake is a major [perhaps the biggest] contributor to engine wear and secondly, that a used filter [not yet overly restrictive] is more efficient.
Re: Why Are Air Filters Important? [Re: Shellguy] #4720531
04/08/18 12:43 PM
04/08/18 12:43 PM
NY
demarpaint Offline
demarpaint  Offline
NY
True and a lot of people pay a lot of money for a K&N filter air intake kit, or whatever they call it. [The kind of air filter you apply their oil to and wash and reuse] to increase HP and have no clue what kind of damage they're doing to their engine. Expensive in the case of K&N can be bad too.
God Bless Our Troops
Re: Why Are Air Filters Important? [Re: demarpaint] #4720556
04/08/18 01:22 PM
04/08/18 01:22 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Sorry, but have you ever heard of a K&N causing an engine failure?
Fried MAF from over-oiling, sure. Maybe a K&N isn't 99.9% efficient at a half micron, I'll give you that... But over the course of typical ownership, what harm does it really do? Heck, even extended ownership.
"Zed's dead baby, Zed's dead."
Re: Why Are Air Filters Important? [Re: rooflessVW] #4720559
04/08/18 01:24 PM
04/08/18 01:24 PM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
Interesting test involving KnN at this site.
http://nicoclub.com/archives/kn-vs-oem-filter.html
Re: Why Are Air Filters Important? [Re: Jim Allen] #4720561
04/08/18 01:29 PM
04/08/18 01:29 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
Jim is alive!
2012 Chevy Cruze LT 1.4T - 62k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 147k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: Why Are Air Filters Important? [Re: Jim Allen] #4720564
04/08/18 01:31 PM
04/08/18 01:31 PM
Danville, Indiana
IndyFan Offline
IndyFan  Offline
Danville, Indiana
I've got a friend with a Saab 9-4, and he has run a K&N since new. He is approaching 300,000 miles, and the car runs great.
That said, the K&N is not my cup of tea. I like a high efficiency paper filter that is easy to change, and I don't like the mess or headache of oiling a filter.
I doubt a K&N, properly maintained and used, has caused an engine to wear out significantly sooner than it would have with a paper OEM filter.
18 Jeep JLUR Wrangler 3.6 18k
15 Ford Transit 120k, Reman 3.5 @85k
08 Jeep Wrangler 3.8 131k
01 Ford F150 Crew 5.4 85k
99 Mercedes E430 Sport 92k
Re: Why Are Air Filters Important? [Re: rooflessVW] #4720570
04/08/18 01:37 PM
04/08/18 01:37 PM
NY
demarpaint Offline
demarpaint  Offline
NY
I read UOA's they typically show extra wear, that's good enough for me. You've been around it has been discussed here many times, the general consensus has been they're not good. And it also fits into this topic perfectly.
Re: Why Are Air Filters Important? [Re: WobblyElvis] #4720571
04/08/18 01:38 PM
04/08/18 01:38 PM
South Carolina
eyeofthetiger Offline
South Carolina
Good link. Air filters are so generic and variable in their construction that you really have to pull each one out of the box and look.
I wish the test included a second round with a pantyhose prefilter.
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
Re: Why Are Air Filters Important? [Re: Jim Allen] #4720588
04/08/18 02:05 PM
04/08/18 02:05 PM
Canyon County Idaho
CT8 Online content
CT8  Online Content
Canyon County Idaho
The best oil filter is the air filter
2015 F150 2.7
2018 F350 6.2
Re: Why Are Air Filters Important? [Re: WobblyElvis] #4720601
04/08/18 02:18 PM
04/08/18 02:18 PM
NW Ohio
NW Ohio
So you doubt it? How can you? It's a closed system, the only way outside dirt can enter is via the intake system (well, except for ancient cars with road draft tubes). Internal normal wear and the resultant particulate contamination is a separate issue but that wear is effected, can be greatly effected, by how much dirt gets by the rings.
If you go back and look at my older posts (it will be back before 2014) I cite most of this. But yes, it came from various peer reviewed papers. See the synopsis article I did that is linked, which is a layman's overview.
Air Filters
Jim Allen
Re: Why Are Air Filters Important? [Re: eyeofthetiger] #4720641
04/08/18 03:01 PM
04/08/18 03:01 PM
Rio Rancho, NM
Pajero Offline
Pajero  Offline
Rio Rancho, NM
Pantyhose worked well when Mt. St. Helen's blew in 1980. I live in the desert (large sandbox) and installed a Snorkel. People make fun of me because they think it's for water. It's because of dust. Ever going wheelin with a bunch of 4x4...the dust is horrid. Cyclonic filters are the best for worst conditions...
Respectfully,
Pajero!
Always remember "Planned obsolescence."
1994 Montero SR 3.5 DOHC, 133,xxx
Fram Ultra/ Snorkel with Pre-filter
K-9-Co-pilot
Re: Why Are Air Filters Important? [Re: Jim Allen] #4720644
04/08/18 03:05 PM
04/08/18 03:05 PM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
Air Filters
Never said I doubt it and it makes perfect sense. I just to learn from the best sources I can, not hearsay.
Thank you for the info.
Page 1 of 3 1 2 3
