(NEW) STP S3675 Cut Open
by rooflessVW. 01/17/19 10:00 PM
Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Coated rotors
by supton. 01/17/19 07:51 PM
Good samaritan
by JLTD. 01/17/19 07:15 PM
Doing suspension work. Need alignment?
by HawkeyeScott. 01/17/19 05:45 PM
100mg CBD Cannabis Gel
by Al. 01/17/19 05:36 PM
Electric Car "Green Test"
by redbone3. 01/17/19 05:06 PM
Want to try a uoa
by Dylan1303. 01/17/19 04:56 PM
Happy Birthday, Betty White!
by eljefino. 01/17/19 04:20 PM
Fram Ultra for Ecoboost 2.7
by Purpfox. 01/17/19 04:10 PM
Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
Dickerson888, Frisky, polarisman340, jfradella, Bigyetti83
66964 Registered Users
91 registered members (Baracoa, advocate, 14Accent, 2015_PSD, Astro14, ArrestMeRedZ, 10 invisible), 1,639 guests, and 36 spiders.
Topics296,757
Posts4,958,275
Members66,964
Most Online2,577
Jan 14th, 2019
Cub Cadet vs Toro Push Mower #4720364
04/08/18 08:52 AM
04/08/18 08:52 AM
Clarence NY
jims5600 Offline OP
jims5600  Offline OP
Clarence NY
Looking to pick up a gas push mower to be used basically for trimming,flower beds,tree areas etc
Looking at a Cub Cadet sc300 or a Toro 20377. Seem fairly close in specs.,but Im no mower pro.
What say you,or can you recommend something under $300?
Thanks
Re: Cub Cadet vs Toro Push Mower [Re: jims5600] #4720375
04/08/18 09:02 AM
04/08/18 09:02 AM
wv
krismoriah72 Offline
wv
Why do you need a self propelled mower for such a small job?
I have a pretty large area to cut that i cannot get to with my rider. My troy bilt with the Honda engine has been a tough one. I think i am on the 8th year of abuse on it.
Re: Cub Cadet vs Toro Push Mower [Re: jims5600] #4720381
04/08/18 09:07 AM
04/08/18 09:07 AM
Nowthen, MN
KD0AXS Online content
KD0AXS  Online Content
Nowthen, MN
Between the two, I'd probably lean toward the Toro. At least it has a name brand engine instead of the no name Chinese engines that MTD uses. (Cub Cadet is made by MTD) I'm sure the Kohler on the Toro is probably Chinese too though.
Realistically, for what you're going to be using it for I would look on Craigslist for a used mower under $100.
Re: Cub Cadet vs Toro Push Mower [Re: jims5600] #4720388
04/08/18 09:14 AM
04/08/18 09:14 AM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
I have a Toro Recycler with a 22 inch deck. It has the “Personal Pace” bar to control the speed. Takes a bit of getting used to because if you push on the bar too hard it really wants to take off. It’s much better than the old school hand grip to control the speed. The Honda 160 starts on the first pull. I’d recommend it.
If you want the job done right......do it yourself.
Re: Cub Cadet vs Toro Push Mower [Re: jims5600] #4720427
04/08/18 09:52 AM
04/08/18 09:52 AM
IL
Vern_in_IL Offline
Vern_in_IL  Offline
IL
Honda Push mowers are the best, but they are more than $300. But, the Honda has some power, it will not choke if you get it into high grass.
I would go with the Toro.
Re: Cub Cadet vs Toro Push Mower [Re: jims5600] #4720448
04/08/18 10:04 AM
04/08/18 10:04 AM
Missouri
David2431 Offline
David2431  Offline
Missouri
I looked it up and the Toro 20377 looks like one I owned from Home Depot --- FOR ABOUT TWO WEEKS!
I have a yard that takes about an hour to mow and the front wheel drive drove me crazy, even on the flats. If you have any kind of slope, forget it. You'll be more tired from fighting to steer the [censored] thing than mowing.
The engine did start right up, I'll give it that.
Returned it for my money back.
Re: Cub Cadet vs Toro Push Mower [Re: David2431] #4720466
04/08/18 10:24 AM
04/08/18 10:24 AM
Absolutely. If you have hills, go for rear wheel drive. Same if you often cut tall grass. You can tip it back and still move forward.
Re: Cub Cadet vs Toro Push Mower [Re: jims5600] #4720467
04/08/18 10:26 AM
04/08/18 10:26 AM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Get something that is NOT self propelled for trim work. Doing trim work means you'll change directions all the time, in which you will be going backwards more than you think, changing directions, negating the purpose, making it harder actually due to dealing with the self propelled.
If you don't need to bag: https://www.mowersdirect.com/Honda-HRS216PKA/p62543.html
If you need to bag: https://www.toro.com/en/homeowner/walk-behind-mowers/21-push-mower-21320
Me: 13' VW GTI 3 door 6 speed manual
Wanted: 2019 Ford Ranger
Re: Cub Cadet vs Toro Push Mower [Re: jims5600] #4720474
04/08/18 10:32 AM
04/08/18 10:32 AM
UT
BHopkins Offline
BHopkins  Offline
UT
If it were me, I'd go with the Toro.
I've got a Toro push 20053 that I've been using for 0ver 10 years now, and I have never had a problem with it. Right now, I can't see why it won't last another 10 years.
Cub Cadet equipment is not what it was 20 years ago. As mentioned above, it is now made by MTD, just like Troy-Bilt, Yard Man, Bolens. So unless you are buying one of their upper level machines, then there are better options.
2013 Subaru Outback 2.5i - Idemitsu 0W-20 & Mobil 1 filter
2007 Mercedes SL550 - M1M 5W-40 & MB OEM filter
Re: Cub Cadet vs Toro Push Mower [Re: jims5600] #4720497
04/08/18 10:57 AM
04/08/18 10:57 AM
NJ
JLawrence08648 Offline
NJ
Get a used mower, next by a cheap mower, Toro is one of the best, MTD is not.
Re: Cub Cadet vs Toro Push Mower [Re: Snagglefoot] #4720504
04/08/18 11:13 AM
04/08/18 11:13 AM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
+1
My Toro has the janky Tecumseh GTS 6.5 but still cuts and self propels really well. Best part is I only paid $25 for it
Re: Cub Cadet vs Toro Push Mower [Re: jims5600] #4720695
04/08/18 03:00 PM
04/08/18 03:00 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
3hp B+S engine on a 19" deck. Cheapest mower out there.
Thick oil is better grin2
Re: Cub Cadet vs Toro Push Mower [Re: andyd] #4720965
04/08/18 08:20 PM
04/08/18 08:20 PM
IL
Vern_in_IL Offline
Vern_in_IL  Offline
IL
and it WILL constantly stall in high grass! Honda GCV engines will keep trucking and will not stall.
Re: Cub Cadet vs Toro Push Mower [Re: jims5600] #4721154
04/09/18 04:22 AM
04/09/18 04:22 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
As long as you are just trimming,those would be ok.For overall yard mowing, I would get something better than a $300 mower. The Toro recycler in that price range is not very good from personal experience, mulches poorly and is under powered.. The more expensive recycler 2 is a much better mower.
The "thinking" man's friend.
Re: Cub Cadet vs Toro Push Mower [Re: jims5600] #4721170
04/09/18 04:48 AM
04/09/18 04:48 AM
Georgia
MParr Offline
MParr  Offline
Georgia
Husqvarna has two push mowers in their lineup. Both have high rear wheels. One comes with a Honda engine and the other comes with a Briggs & Stratton. Model numbers: 7021P and LC121P. You may have to buy at your local Husqvarna dealer. Be aware that cheap self propelled mowers have cheap, flimsy transmissions.
2013 KIA Optima EX 2.4L. Now: QSUD 5W30 & STP S2808ML
2017 Ford Escape SE 2.0T Now: Mobil 1 5W30 & NAPA Gold 1348
