4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
88 registered members (4WD, AlaskaMike, 2010Civic, AdditiveOCD, agpatel, 69Torino, 10 invisible), 1,579 guests, and 68 spiders.
Topics286,042
Posts4,901,383
Members67,551
Most Online2,967
Mar 10th, 2019
Shops sometimes over-torque lug nuts #4720310
04/08/18 08:47 AM
04/08/18 08:47 AM
San Antonio, TX
jorton Offline OP
jorton  Offline OP
San Antonio, TX
Can over-torqued lug nuts cause ride issues at high speeds? At 80 my new tires feel like they're bouncing.
Yokohama Avid Touring S
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
Re: Shops sometimes over-torque lug nuts [Re: jorton] #4720312
04/08/18 08:49 AM
04/08/18 08:49 AM
ME
eljefino Offline
eljefino  Offline
ME
Rarely but IF you have lug-centric (aftermarket) rims without centering rings AND if they ran the first lug home hard before putting the rest on the rim could be cocked on the hub face making a bad ride.
Re: Shops sometimes over-torque lug nuts [Re: jorton] #4720320
04/08/18 09:01 AM
04/08/18 09:01 AM
Alberta
tcp71 Offline
tcp71  Offline
Alberta
Overtightened lug nuts can cause warping of the rotors and vibrations. Especially tightened along one side first.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: mobil 0w40 (varies)
Re: Shops sometimes over-torque lug nuts [Re: jorton] #4720331
04/08/18 09:10 AM
04/08/18 09:10 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Some ham fisted idjit over torqued the Rat's front studs until they stretched and spun in the hub. I had to split the nuts on 3 studs to get the LF wheel off
Thick oil is better grin2
Re: Shops sometimes over-torque lug nuts [Re: tcp71] #4720342
04/08/18 09:21 AM
04/08/18 09:21 AM
San Antonio, TX
jorton Offline OP
jorton  Offline OP
San Antonio, TX
Is rotor warp permanent or will it return to normal when I re-torque? Does over-torquing have similar effect on rear drums?
- Mario Andretti
Re: Shops sometimes over-torque lug nuts [Re: jorton] #4720362
04/08/18 09:49 AM
04/08/18 09:49 AM
St. Catharines Ontario Canada
03s Offline
03s  Offline
Wheel nut torque specs
http://www.jegs.com/images/photos/300/326/326-wheelnuttorquespecs.pdf
or check your owners manual
2005 Chevrolet Optra
Canadian Tire MotoMaster F1 Premium Synthetic / F1 High Mileage 5w-30
Mobil 1 m1-101
Re: Shops sometimes over-torque lug nuts [Re: 03s] #4720382
04/08/18 10:09 AM
04/08/18 10:09 AM
San Antonio, TX
jorton Offline OP
jorton  Offline OP
San Antonio, TX
Thanks for the chart. I replaced 2 piece nuts on the jeep with one piece Dorman nuts yesterday.
- Mario Andretti
Re: Shops sometimes over-torque lug nuts [Re: jorton] #4720391
04/08/18 10:22 AM
04/08/18 10:22 AM
Winnipeg
Uphill_Both_Ways Offline
Winnipeg
Last year, thanks to over-torquing, the vibrations grew so bad I replaced all the rotors (after trying to live with it for six months). The next day I bought a torque wrench.
The chain where I bought the tires offers free wheel rotations, so now, as soon as the car is back in the parking lot after a rotation, I loosen every nut, then give the wrench a workout. A hundred kilometres later I do it again, all of it a real pain in the winter — and elsewhere.
I'll never buy tires there again. But now, because of the wrench, I don't have to take any tire shop's word for it — and I won't.
2008 Impala 3.5
Re: Shops sometimes over-torque lug nuts [Re: jorton] #4720397
04/08/18 10:32 AM
04/08/18 10:32 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
It’s permanent.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Shops sometimes over-torque lug nuts [Re: jorton] #4720399
04/08/18 10:35 AM
04/08/18 10:35 AM
Texas
4WD Online confused
4WD  Online Confused
Texas
Son’s F150 has 89k and a couple weeks after Firestone put a set of AT’s on … got a brake warning...
Pulled both a F/R wheel to check pads (truck bought used, no history) and the factory wrench had no chance.
(Son is 6-3’ and 260) …even with a longer cross wrench it took all either of us had to break them = crazy … and all dozen we took off were like that …
Put the cross wrench in the truck …
Re: Shops sometimes over-torque lug nuts [Re: Uphill_Both_Ways] #4720491
04/08/18 11:52 AM
04/08/18 11:52 AM
San Antonio, TX
jorton Offline OP
jorton  Offline OP
San Antonio, TX
You just can't trust anyone. It's never too late to try to do things right.
- Mario Andretti
Re: Shops sometimes over-torque lug nuts [Re: jorton] #4720526
04/08/18 12:38 PM
04/08/18 12:38 PM
Minnesota
Lapham3 Offline
Lapham3  Offline
Minnesota
I just don't let anyone touch lug nuts or drain plugs. The most important fasteners usually cranked on by the lowest paid young fellas too often thinking about girls, ect and not what they're doing.
Re: Shops sometimes over-torque lug nuts [Re: jorton] #4720584
04/08/18 01:55 PM
04/08/18 01:55 PM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
Shops always over-torque lug nuts. FTFY smile
The only exceptions I know of are DT and Walmart, and possibly a small number local/regional places.
Re: Shops sometimes over-torque lug nuts [Re: jorton] #4720616
04/08/18 02:32 PM
04/08/18 02:32 PM
New England
Virtus_Probi Offline
New England
The indy tire shop I like hand torques wheels and makes customers sign a little slip saying they will come back for a retorque in about 100 miles.
I just take care of it with my own torque wrench, and there are almost always a couple of nuts that actually need it. I have noticed the same thing when I swap my own wheels.
2014 Forester XT, 95000 miles
Last Change;
M1 0W30 AFE d1G2
Tokyo Roki 15208AA170 filter
Re: Shops sometimes over-torque lug nuts [Re: jorton] #4723551
04/11/18 11:52 AM
04/11/18 11:52 AM
Canada
camrydriver111 Offline
Canada
How does a rotor warp by over torquing? It's a thick slab of cast iron.
I think you would damage the threads, studs/bolts, or the wheel before damaging the rotor.
BITOG or: How I Learned to Stop Worrying and Love the Extended OCI
